[petsc-users] Setting up MUMPS in PETSc
Matthew Knepley
knepley at gmail.com
Tue Oct 23 17:19:10 CDT 2012
On Tue, Oct 23, 2012 at 6:15 PM, Jinquan Zhong <jzhong at scsolutions.com>wrote:
> Hong and Jed,****
> For KSPSolver, what kind of PC is the most proper ? I tested ****
> ierr = PCSetType(pc,PCREDUNDANT);CHKERRQ(ierr);****
> It worked for small complex double matrix but not for the big ones. Here
> is my set up
Did you read the documentation on this PC? At all? That it solves the
entire system on each proces?
Matt
> KSP ksp; /* linear solver context */****
> PC pc;****
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);****
> ierr =
> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);****
> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);****
> KSPSetTolerances(ksp,1.e-12,1.e-12,PETSC_DEFAULT,PETSC_DEFAULT);****
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);****
> ierr = KSPSolve(ksp,b,*x);CHKERRQ(ierr);****
> Do you see any problem?****
> Thanks,****
> Jinquan****
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Hong Zhang
> *Sent:* Tuesday, October 23, 2012 12:03 PM
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] Setting up MUMPS in PETSc****
> Jinquan:****
> I have a question on how to use mumps properly in PETSc. It appears that
> I didn’t set up mumps right. I followed the example in ****
> http://www.mcs.anl.gov/petsc/petsc-dev/src/mat/examples/tests/ex125.c.html
> This example is for our internal testing, not intended for production runs.
> Suggest using PETSc high level KSP solver which provides more flexibility.
> to set up my program. Here is my situation on using the default setting *
> PetscInt <http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscInt.html#PetscInt> icntl_7 = 5;****
> MatMumpsSetIcntl<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatMumpsSetIcntl.html#MatMumpsSetIcntl>
> (F,7,icntl_7);****
> in the example ex125.c:****
> Using KSP sover, the mumps options can be chosen at runtime,****
> e.g. ****
> ~petsc/src/ksp/ksp/examples/tutorials/ex2.c:****
> mpiexec -n 2 ./ex2 -pc_type lu -pc_factor_mat_solver_package mumps
> -mat_mumps_icntl_7 5****
> Norm of error 1.49777e-15 iterations 1****
> 1. The program work fine on all *small* models (sparse matrices
> at the order of m= 894, 1097, 31k with a dense matrix included in the
> sparse matrix). The residuals are at the magnitude of 10^-3.****
> With a direct solver, residual = 10^-3 indicates your matrix might be
> very ill-conditioned or close to singular. What do you get for |R|/|rhs| = ?
> Is this the reason you want to use a direct solver instead of iterative
> one?****
> What do you mean "31k with a dense matrix included in the sparse matrix"?*
> How sparse is your matrix, e.g., nnz(A)/(m*m)=?****
> 2. The program has some issues on *medium* size problem (m=460k
> with a dense matrix at the order of n=30k included in the sparse matrix).
> The full sparse matrix is sized at 17GB.****
> a. We used another software to generate sparse matrix by using 144
> cores: ****
> i. When
> I used the resource from 144 cores (12 nodes with 48GB/node), it could not
> provide the solution. There was a complain on the memory violation.****
> ii. When
> I used the resource from 432 cores (36 nodes with 48GB/node), it provided
> the solution. ****
> Direct solvers are notoriously memory consuming. It seems your matrix is
> quite dense, requiring more memory than 144 cores could provide. ****
> What is "another software "?****
> b. We used another software to generate the same sparse matrix by
> using 576 cores: ****
> i. When
> I used the resource from 576 cores (48 nodes with 48GB/node), it could not
> ii. When
> I used the resource from 1152 cores (96 nodes with 48GB/node), it provided
> the solution. ****
> Both a and b seem indicate that, you can use small num of cores to
> generate original matrix A, but need more cores (resource) to solve A x =b.
> This is because A = LU, the factored matrices L and U require far more
> memory than original A. Run your code using KSP with your matrix data and
> option -ksp_view****
> e.g., petsc/src/ksp/ksp/examples/tutorials/ex10.c****
> mpiexec -n 2 ./ex10 -f <matrix binary data file> -pc_type lu
> -pc_factor_mat_solver_package mumps -ksp_view****
> then you'll see memory info provided by mumps. ****
> 3. The program could not solve the *large* size problem (m=640k
> with a dense matrix at the order of n=178k included in the sparse matrix).
> The full sparse matrix is sized at 511GB.****
> a. We used another software to generate sparse matrix by using 900
> cores: ****
> i. When
> I used the resource from 900 cores (75 nodes with 48GB/node), it could not
> ii. When
> I used the resource from 2400 cores (200 nodes with 48GB/node), it STILL
> COULD NOT provide the solution. ****
> Your computer system and software have limits. Find the answers to your
> 'medium size' problems first. ****
> My confusion starts from the medium size problem:****
> · It seems something was not right in the default setting in
> ex125.c for these problems. ****
> · I got the info that METIS was used instead of ParMETIS in
> solving these problems. ****
> By default, petsc-mumps interface uses sequential symbolic factorization
> (analysis phase). Use '-mat_mumps_icntl_28 2' to switch to parallel.****
> I tested it, but seems parmetis is still not used. Check mumps manual ****
> or contact mumps developer on how to use parmetis.****
> · Furthermore, it appears that there was unreasonable demand on
> the solver even on the medium size problem. ****
> · I suspect one rank was trying to collect all data from other
> ranks. ****
> Yes, analysis is sequential, and rhs vector must be in the host :-( ****
> In general, direct solvers cannot be scaled to very large num of cores.***
> What other addition setting is needed for mumps such that it could deal
> with medium and large size problems?****
> Run your code with option '-help |grep mumps' and experiment with****
> various options, e.g., matrix orderings, nonzero-fills etc. ****
> You may also try superlu_dist. Good luck!****
> Do you guys have similar experience on that?****
> I personally never used mumps or superlu_dist for such large matrices.**
> Consult mumps developers.****
> Hong****
> Thanks,****
> Jinquan****
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121023/bcef189f/attachment.html>
