[petsc-users] Solving Ill Conditioned Problems
Matthew Knepley
knepley at gmail.com
Thu Oct 18 13:28:57 CDT 2012
On Thu, Oct 18, 2012 at 11:07 AM, Nachiket Gokhale <gokhalen at gmail.com>wrote:
> Hi,
> I am solving a Piezoelectric problem using Petsc. The structure is
> [ K_uu K_uv ]
> [K_uv ^T -K_v,v ]
> More details about the formulation: http://tinyurl.com/9hlbp4u
> K_uu has elements O(1E9) because the stiffnesses are in GPa,
> K_uv has elements O(1) because piezoelectric coefficients are of that
> order
> K_v,v has elements O(1E-9) because the dielectric constants are of
> that order.
> I am using Petsc, with pc_type LU and MUMPS for the factorization,
> -ksp_type gmres. I am not sure if my solution is converging. A typical
> solve seems to be doing this:
> 28 KSP preconditioned resid norm 5.642364260456e-06 true resid norm
> 1.228976487745e-03 ||r(i)||/||b|| 3.317409023627e-14
> 29 KSP preconditioned resid norm 5.540718271043e-06 true resid norm
> 1.228453548651e-03 ||r(i)||/||b|| 3.315997440178e-14
> 30 KSP preconditioned resid norm 1.973052106578e-03 true resid norm
> 1.220399172500e-03 ||r(i)||/||b|| 3.294256047735e-14
> 31 KSP preconditioned resid norm 1.155762663956e-17 true resid norm
> 2.447631111938e-04 ||r(i)||/||b|| 6.606955965570e-15
> Is there a right way to solve this set of equations? Is PCFieldSplit
> the recommended way?
First, you should really non-dimensionalize. You can see what this would
give
you by symmetrically scaling your problem with [ 3e4 3e-4 ], namely
everything
will be O(1).
Second, you might get something out of using FieldSplit, but its tough to
tell
without knowing more about the operators.
Matt
> Thanks,
> -Nachiket
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121018/099340b7/attachment.html>
