[petsc-users] SNES line search
Dmitry Karpeev
karpeev at mcs.anl.gov
Wed Oct 17 16:51:15 CDT 2012
Thanks.
Dmitry.
On Wed, Oct 17, 2012 at 4:45 PM, Peter Brune <brune at mcs.anl.gov> wrote:
> Fix for the garbage in X part is in.
> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/9d679552ef45
> - Peter
> On Wed, Oct 17, 2012 at 3:34 PM, Peter Brune <prbrune at gmail.com> wrote:
>> On Wed, Oct 17, 2012 at 3:01 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>> On Wed, Oct 17, 2012 at 2:56 PM, Peter Brune <prbrune at gmail.com> wrote:
>>>> On Wed, Oct 17, 2012 at 2:40 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>>>> On Wed, Oct 17, 2012 at 2:11 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>> On Wed, Oct 17, 2012 at 2:02 PM, Shiyuan Gu <sgu at anl.gov> wrote:
>>>>>>> Hi,
>>>>>>> I am using petsc-3.3-p2. For my particular equation, for the
>>>>>>> first few iterations, the residual norm is effectively reduced and the
>>>>>>> solution X is very close to the exact solution (the residual norm is e-17).
>>>>>>> Then in the next iteration, SNES_KSPSolve(....) returns a newton step very
>>>>>>> close to zero which is correct, but the line search after it fails, and the
>>>>>>> function SNESLSCheckLocalMin_Private(...) is called. In the function
>>>>>>> SNESLSCheckLocalMin_Private(),
>>>>>>> the solution vector X is rewritten to X=J^T*F where J is the
>>>>>>> Jacobian and F is the residual. Since F is very close to zero, X is also
>>>>>>> zero which is wrong.
>>>>>>> Is there a way to skip the line search?(if the line search is not
>>>>>>> performed, there would be no problem for this particular equation). How
>>>>>>> should we handle this situation?
>>>>>> You can turn off the line search with -snes_linesearch_type basic,
>>>>>> but I recommend setting an appropriate atol and stol instead, to prevent
>>>>>> attempting to solve the system more accurately than machine precision when
>>>>>> given a good initial guess.
>>>>> Maybe it wouldn't be a bad idea to (a) not use the solution vector as
>>>>> a temporary in detecting the local minimum,
>>>> Dumping garbage into X upon failure appears to be my careless mistake.
>>>> I'll fix it in 3.3.
>>>> (b) print the norm of the last solution before bailing out of the
>>>>> Newton loop?
>>>> This can go into the -info output.
>>> Why not (also) let SNESMonitor() be called on that last solution?
>> Oh, I interpreted "norm of the solution" literally rather than "norm of
>> the function at that solution", which makes more sense. However, as it
>> quits after failing the line search and doesn't transfer the failed
>> solution over. This is indeed a divergence, so printing a failed norm
>> probably isn't the right solution. You can see what the line search is
>> doing with -snes_linesearch_monitor.
>> We changed the behavior in petsc-dev a little bit with respect to this
>> type of case, as we were seeing bad interaction between line search
>> divergence in the case of small step sizes and small-normed solutions with
>> the logic as it was in 3.3 and before. This could be that type of problem,
>> where the solution is well converged and the line search cannot make more
>> progress.
>> In any case, I'll fix the problem with writing garbage into the solution.
>> In order to truly diagnose this, output with -snes_linesearch_monitor and
>> -snes_converged reason would be nice.
>> - Peter
>> Dmitry.
>>>> - Peter
>>>>> Dmitry.
>>>>>>> Also, after the solution vector X is rewritten by
>>>>>>> SNESLSCheckLocalMin_Private(), the new residual norm is not printed on
>>>>>>> screen (which is huge for this particular problem). Since the residual
>>>>>>> norm printed on the screen is going to machine accuracy, users might think
>>>>>>> that the SNESSolve converges nicely and the returned solution is correct.
>>>>>>> This seems a bit misleading in my opinion.
>>>>>> Are you checking -snes_converged_reason?
>>>>>>> Thanks.
>>>>>>> Shiyuan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121017/06899a6d/attachment.html>
