[petsc-users] [petsc-maint #136411] PETSc Execution Error
Barry Smith
bsmith at mcs.anl.gov
Wed Oct 17 13:45:12 CDT 2012
Paul,
With this type of problem you need to get a handle on exactly where the floating point exception appeared. This is done by running the debug version of the code in a debugger and asking the debugger to catch floating point exceptions (how to do this depends on the debugger). Once you see exactly where the floating point except ion comes from (for example a divide by zero, square root of a negative number etc) that can lead to seeing how to avoid it.
Note to developers, we should have an answer for this in PETSc FAQ.
Barry
On Oct 17, 2012, at 9:18 AM, Paul Cruise <paul.cruise.paul at gmail.com> wrote:
> [0]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Floating point exception!
> [0]PETSC ERROR: Vec entry at local location 0 is not-a-number or infinite at beginning of function: Parameter number 2!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13 15:42:00 CDT 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: /gpfs/home/swayamjyoti_s/slepc-3.3/src/eps/examples/tutorials/Test/ex1f on a arch-linu named merlinc12 by swayamjyoti_s Tue Oct 16 11:47:26 2012
> [0]PETSC ERROR: Libraries linked from /gpfs/home/swayamjyoti_s/petsc-3.3/arch-linux2-c-debug/lib
> [0]PETSC ERROR: Configure run at Tue Aug 21 15:47:21 2012
> [0]PETSC ERROR: Configure options --with-fc=ifort --download-f-blas-lapack --download-mpich
> [0]PETSC ERROR: [0]PETSC ERROR: Libraries linked from /gpfs/home/swayamjyoti_s/petsc-3.3/arch-linux2-c-debug/lib
> [0]PETSC ERROR: MatMult() line 2081 in /gpfs/home/swayamjyoti_s/petsc-3.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: STApply_Shift() line 41 in src/st/impls/shift/shift.c
> [0]PETSC ERROR: STApply() line 67 in src/st/interface/stsolve.c
> [0]PETSC ERROR: EPSFullLanczos() line 179 in src/eps/impls/krylov/krylov.c
> [0]PETSC ERROR: [0]PETSC ERROR: STApply() line 67 in src/st/interface/stsolve.c
> [0]PETSC ERROR: EPSSolve_KrylovSchur_Symm() line 58 in src/eps/impls/krylov/krylovschur/ks-symm.c
> [0]PETSC ERROR: EPSSolve() line 130 in src/eps/interface/solve.c
> [0]PETSC ERROR: /gpfs/home/swayamjyoti_s/slepc-3.3/src/eps/examples/tutorials/Test/ex1f on a arch-linu named merlinc13 by swayamjyoti_s Tue Oct 16 11:47:26 2012
> [0]PETSC ERROR: [0]PETSC ERROR: MatMult() line 2081 in /gpfs/home/swayamjyoti_s/petsc-3.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0]PETSC ERROR: [0]PETSC ERROR: [0]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: /gpfs/home/swayamjyoti_s/slepc-3.3/src/eps/examples/tutorials/Test/ex1f on a arch-linu named merlinc22 by swayamjyoti_s Tue Oct 16 11:47:26 2012
> [0]PETSC ERROR: [0]PETSC ERROR: /gpfs/home/swayamjyoti_s/slepc-3.3/src/eps/examples/tutorials/Test/ex1f on a arch-linu named merlinc22 by swayamjyoti_s Tue Oct 16 11:47:26 2012
> [0]PETSC ERROR: [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: [0]PETSC ERROR: Configure options --with-fc=ifort --download-f-blas-lapack --download-mpich
> [0]PETSC ERROR: /gpfs/home/swayamjyoti_s/slepc-3.3/src/eps/examples/tutorials/Test/ex1f on a arch-linu named merlinc25 by swayamjyoti_s Tue Oct 16 11:47:26 2012
> Hello PETSc Users,
> I have a problem while execution of a PETSc code, please find attached the
> error file. There are no errors during compilation. Could someone please
> look into it & advise the source of error.
> Regards,
> Paul
> Hello PETSc Users,
> I have a problem while execution of a PETSc code, please find attached the error file. There are no errors during compilation. Could someone please look into it & advise the source of error.
> Regards,
> Paul
