[petsc-users] PETSc Execution Error
    Jose E. Roman
    jroman at dsic.upv.es
    Wed Oct 17 09:30:44 CDT 2012
El 17/10/2012, a las 16:18, Paul Cruise escribió:
> Hello PETSc Users,
> I have a problem while execution of a PETSc code, please find attached the error file. There are no errors during compilation. Could someone please look into it & advise the source of error.
> Regards,
> Paul
> <error.txt>
This is the same error you reported three weeks ago.
Did you try our suggestions? Place a MatMult operation before the solve (and comment out the rest of the code). If the problem persists then you have a problem when creating the matrix. Check the values that you are passing in MatSetValues.
Jose
