[petsc-users] Help with mpiexec
George Mathew gmnnus at gmail.com
Sat Oct 13 17:07:02 CDT 2012
On Sat, Oct 13, 2012 at 5:09 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Oct 13, 2012 at 4:07 PM, George Mathew <gmnnus at gmail.com> wrote:
>> The following command works fine:
>> mpiexec -f machinefile -n 12 hostname
> Hostname does not communicate at all. Can you run a real MPI program, such
> as cpi.c that is included in most source MPI distributions? The first call
> to MPI_Bcast() is raising an error, which strongly indicates that the MPI
> was misconfigured.
>> It displays the hostname from the 4 different machines that I have in the
>> machinefile. The MPI installation was done from the same tar file on the 4
>> hosts running identical versions of linux.
> Environment variables could still be different, for example.
That's it. MPI issue. Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121013/d80b2564/attachment.html>
