[petsc-users] Enquiry regarding log summary results
TAY wee-beng
zonexo at gmail.com
Wed Oct 3 15:05:45 CDT 2012
Hi Jed,
I believe they are real cores. Anyway, I have attached the log summary
for the 12/24/48 cores. I re-run a smaller case because the large
problem can't run with 12cores.
Yours sincerely,
TAY wee-beng
On 3/10/2012 5:59 PM, Jed Brown wrote:
> There is an inordinate amount of time being spent in VecScatterEnd().
> That sometimes indicates a very bad partition. Also, are your "48
> cores" real physical cores or just "logical cores" (look like cores to
> the operating system, usually advertised as "threads" by the vendor,
> nothing like cores in reality)? That can cause a huge load imbalance
> and very confusing results as over-subscribed threads compete for
> shared resources. Step it back to 24 threads and 12 threads, send
> log_summary for each.
> On Wed, Oct 3, 2012 at 8:08 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> On 2/10/2012 2:43 PM, Jed Brown wrote:
>> On Tue, Oct 2, 2012 at 8:35 AM, TAY wee-beng <zonexo at gmail.com
>> Hi,
>> I have combined the momentum linear eqns involving x,y,z into
>> 1 large matrix. The Poisson eqn is solved using HYPRE strcut
>> format so it's not included. I run the code for 50 timesteps
>> (hence 50 kspsolve) using 96 procs. The log_summary is given
>> below. I have some questions:
>> 1. After combining the matrix, I should have only 1 PETSc
>> matrix. Why does it says there are 4 matrix, 12 vector etc?
>> They are part of preconditioning. Are you sure you're using Hypre
>> for this? It looks like you are using bjacobi/ilu.
>> 2. I'm looking at the stages which take the longest time. It
>> seems that MatAssemblyBegin, VecNorm, VecAssemblyBegin,
>> VecScatterEnd have very high ratios. The ratios of some
>> others are also not too good (~ 1.6 - 2). So are these stages
>> the reason why my code is not scaling well? What can I do to
>> improve it?
>> 3/4 of the solve time is evenly balanced between MatMult,
>> MatSolve, MatLUFactorNumeric, and VecNorm+VecDot.
>> The high VecAssembly time might be due to generating a lot of
>> entries off-process?
>> In any case, this looks like an _extremely_ slow network, perhaps
>> it's misconfigured?
> My cluster is configured with 48 procs per node. I re-run the
> case, using only 48 procs, thus there's no need to pass over a
> 'slow' interconnect. I'm now also using GAMG and BCGS for the
> poisson and momentum eqn respectively. I have also separated the
> x,y,z component of the momentum eqn to 3 separate linear eqns to
> debug the problem.
> Results show that stage "momentum_z" is taking a lot of time. I
> wonder if it has to do with the fact that I am partitioning my
> grids in the z direction. VecScatterEnd, MatMult are taking a lot
> of time. VecNormalize, VecScatterEnd, VecNorm, VecAssemblyBegin 's
> ratio are also not good.
> I wonder why a lot of entries are generated off-process.
> I create my RHS vector using:
> /call
> VecCreateMPI(MPI_COMM_WORLD,ijk_xyz_end-ijk_xyz_sta,PETSC_DECIDE,b_rhs_semi_z,ierr)/
> where ijk_xyz_sta and ijk_xyz_end are obtained from
> /call MatGetOwnershipRange(A_semi_z,ijk_xyz_sta,ijk_xyz_end,ierr)/
> I then insert the values into the vector using:
> /call VecSetValues(b_rhs_semi_z , ijk_xyz_end - ijk_xyz_sta ,
> (/ijk_xyz_sta : ijk_xyz_end - 1/) , q_semi_vect_z(ijk_xyz_sta + 1
> : ijk_xyz_end) , INSERT_VALUES , ierr)/
> What should I do to correct the problem?
> Thanks
>> Btw, I insert matrix using:
>> /do ijk=ijk_xyz_sta+1,ijk_xyz_end//
>> // II = ijk - 1// !Fortran shift to 0-based//
>> // call
>> MatSetValues(A_semi_xyz,1,II,7,int_semi_xyz(ijk,1:7),semi_mat_xyz(ijk,1:7),INSERT_VALUES,ierr)//
>> //end do/
>> where ijk_xyz_sta/ijk_xyz_end are the starting/end index
>> int_semi_xyz(ijk,1:7) stores the 7 column global indices
>> semi_mat_xyz has the corresponding values.
>> and I insert vectors using:
>> call
>> VecSetValues(b_rhs_semi_xyz,ijk_xyz_end_mz-ijk_xyz_sta_mz,(/ijk_xyz_sta_mz:ijk_xyz_end_mz-1/),q_semi_vect_xyz(ijk_xyz_sta_mz+1:ijk_xyz_end_mz),INSERT_VALUES,ierr)
>> Thanks!
>> Yours sincerely,
>> TAY wee-beng
>> On 30/9/2012 11:30 PM, Jed Brown wrote:
>>> You can measure the time spent in Hypre via PCApply and
>>> PCSetUp, but you can't get finer grained integrated
>>> profiling because it was not set up that way.
>>> On Sep 30, 2012 3:26 PM, "TAY wee-beng" <zonexo at gmail.com
>>> On 27/9/2012 1:44 PM, Matthew Knepley wrote:
>>>> On Thu, Sep 27, 2012 at 3:49 AM, TAY wee-beng
>>>> <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>> Hi,
>>>> I'm doing a log summary for my 3d cfd code. I have
>>>> some questions:
>>>> 1. if I'm solving 3 linear equations using ksp, is
>>>> the result given in the log summary the total of
>>>> the 3 linear eqns' performance? How can I get the
>>>> performance for each individual eqn?
>>>> Use logging stages:
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogStagePush.html
>>>> 2. If I run my code for 10 time steps, does the log
>>>> summary gives the total or avg performance/ratio?
>>>> Total.
>>>> 3. Besides PETSc, I'm also using HYPRE's native
>>>> geometric MG (Struct) to solve my Cartesian's grid
>>>> CFD poisson eqn. Is there any way I can use PETSc's
>>>> log summary to get HYPRE's performance? If I use
>>>> boomerAMG thru PETSc, can I get its performance?
>>>> If you mean flops, only if you count them yourself and
>>>> tell PETSc using
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogFlops.html
>>>> This is the disadvantage of using packages that do not
>>>> properly monitor things :)
>>>> Matt
>>> So u mean if I use boomerAMG thru PETSc, there is no
>>> proper way of evaluating its performance, beside using
>>> PetscLogFlops?
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> What most experimenters take for granted before they
>>>> begin their experiments is infinitely more interesting
>>>> than any results to which their experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121003/6de88454/attachment-0001.html>
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a petsc-3.3-dev_shared_rel named n12-10 with 12 processors, by wtay Wed Oct 3 21:34:22 2012
Using Petsc Development HG revision: 9883b54053eca13dd473a4711adfd309d1436b6e HG Date: Sun Sep 30 22:42:36 2012 -0500
Max Max/Min Avg Total
Time (sec): 4.407e+03 1.00084 4.405e+03
Objects: 5.680e+02 1.00000 5.680e+02
Flops: 7.375e+11 1.11505 6.777e+11 8.133e+12
Flops/sec: 1.674e+08 1.11490 1.539e+08 1.846e+09
MPI Messages: 1.460e+05 2.95457 1.080e+05 1.296e+06
MPI Message Lengths: 1.035e+10 2.02602 8.761e+04 1.136e+11
MPI Reductions: 1.571e+04 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 2.6484e+02 6.0% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 3.600e+01 0.2%
1: poisson: 1.1297e+02 2.6% 1.9050e+11 2.3% 2.900e+04 2.2% 2.173e+03 2.5% 1.215e+03 7.7%
2: momentum_x: 2.8093e+00 0.1% 2.1513e+09 0.0% 8.800e+01 0.0% 1.010e+01 0.0% 2.800e+01 0.2%
3: momentum_y: 2.8534e+00 0.1% 2.1666e+09 0.0% 8.800e+01 0.0% 1.023e+01 0.0% 2.800e+01 0.2%
4: momentum_z: 4.0213e+03 91.3% 7.9380e+12 97.6% 1.267e+06 97.7% 8.541e+04 97.5% 1.440e+04 91.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %f - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: poisson
MatMult 1053 1.0 5.4872e+01 1.3 9.42e+09 1.2 2.0e+04 1.1e+05 0.0e+00 1 1 2 2 0 44 53 69 75 0 1843
MatMultAdd 156 1.0 4.5059e+00 1.3 6.01e+08 1.2 2.7e+03 1.9e+04 0.0e+00 0 0 0 0 0 4 3 9 2 0 1358
MatMultTranspose 156 1.0 5.6541e+00 1.6 6.01e+08 1.2 2.7e+03 1.9e+04 0.0e+00 0 0 0 0 0 4 3 9 2 0 1082
MatSolve 78 0.0 4.3106e-04 0.0 6.75e+04 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 157
MatLUFactorSym 1 1.0 4.1008e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 3.5048e-05 2.9 5.53e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 158
MatConvert 4 1.0 1.9400e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 1.9127e-01 1.2 5.26e+07 1.2 7.8e+01 1.0e+05 0.0e+00 0 0 0 0 0 0 0 0 0 0 2896
MatAssemblyBegin 69 1.0 3.9459e+00 2.0 0.00e+00 0.0 2.3e+02 1.8e+04 7.4e+01 0 0 0 0 0 2 0 1 0 6 0
MatAssemblyEnd 69 1.0 1.9654e+00 1.1 0.00e+00 0.0 1.0e+03 1.6e+04 2.0e+02 0 0 0 0 1 2 0 4 1 16 0
MatGetRow 3544348 1.0 8.9238e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatGetRowIJ 1 0.0 1.6928e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 7.7009e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.7e-01 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 6.2370e-01 1.1 0.00e+00 0.0 4.3e+02 1.4e+05 9.2e+01 0 0 0 0 1 1 0 1 2 8 0
MatAXPY 4 1.0 6.2184e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 1.7033e+00 1.0 3.72e+07 1.2 4.9e+02 4.9e+04 9.6e+01 0 0 0 0 1 2 0 2 1 8 233
MatMatMultSym 4 1.0 1.2570e+00 1.0 0.00e+00 0.0 4.1e+02 3.9e+04 8.8e+01 0 0 0 0 1 1 0 1 1 7 0
MatMatMultNum 4 1.0 4.5279e-01 1.0 3.72e+07 1.2 7.8e+01 1.0e+05 8.0e+00 0 0 0 0 0 0 0 0 0 1 877
MatPtAP 4 1.0 6.5757e+00 1.0 1.16e+09 1.8 8.4e+02 1.1e+05 1.1e+02 0 0 0 0 1 6 5 3 3 9 1304
MatPtAPSymbolic 4 1.0 3.6004e+00 1.0 0.00e+00 0.0 7.5e+02 9.3e+04 1.0e+02 0 0 0 0 1 3 0 3 2 8 0
MatPtAPNumeric 4 1.0 2.9819e+00 1.0 1.16e+09 1.8 8.9e+01 2.7e+05 8.0e+00 0 0 0 0 0 3 5 0 1 1 2876
MatTrnMatMult 4 1.0 1.6466e+01 1.0 2.04e+09 1.9 4.7e+02 6.6e+05 1.2e+02 0 0 0 0 1 15 12 2 11 10 1385
MatGetLocalMat 20 1.0 6.5459e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 1 0 0 0 2 0
MatGetBrAoCol 12 1.0 1.7862e-01 2.1 0.00e+00 0.0 5.5e+02 1.4e+05 1.6e+01 0 0 0 0 0 0 0 2 3 1 0
MatGetSymTrans 8 1.0 8.3050e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 79 1.0 8.9525e-01 1.7 3.90e+08 1.0 0.0e+00 0.0e+00 7.9e+01 0 0 0 0 1 1 2 0 0 7 5139
KSPSetUp 11 1.0 1.8398e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 1 0
KSPSolve 1 1.0 1.1039e+02 1.0 1.67e+10 1.1 2.9e+04 9.7e+04 1.2e+03 3 2 2 2 8 98100100100 99 1726
VecDot 38 1.0 3.4189e+00 2.9 1.22e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 0 2 1 0 0 3 424
VecDotNorm2 19 1.0 3.2140e+00 2.7 2.44e+08 1.0 0.0e+00 0.0e+00 5.7e+01 0 0 0 0 0 2 2 0 0 5 901
VecMDot 79 1.0 5.6992e-01 2.2 1.95e+08 1.0 0.0e+00 0.0e+00 7.9e+01 0 0 0 0 1 0 1 0 0 7 4037
VecNorm 142 1.0 2.7666e+00 5.7 1.03e+08 1.0 0.0e+00 0.0e+00 1.4e+02 0 0 0 0 1 1 1 0 0 12 442
VecScale 746 1.0 1.2098e+00 2.0 2.96e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 2887
VecCopy 201 1.0 4.0863e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 741 1.0 3.8170e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 1291 1.0 4.7930e+00 2.7 1.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 2732
VecAYPX 1248 1.0 4.8211e+00 2.0 6.91e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 4 0 0 0 1692
VecAXPBYCZ 38 1.0 9.7988e-01 2.0 2.44e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 2956
VecWAXPY 38 1.0 9.6000e-01 2.5 1.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 1509
VecMAXPY 122 1.0 3.9971e-01 1.5 2.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 6802
VecAssemblyBegin 49 1.0 1.4084e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+02 0 0 0 0 1 0 0 0 0 12 0
VecAssemblyEnd 49 1.0 1.4496e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 980 1.0 7.1430e+00 3.3 4.34e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 3 0 0 0 717
VecScatterBegin 1420 1.0 2.7552e-01 3.7 0.00e+00 0.0 2.6e+04 9.0e+04 0.0e+00 0 0 2 2 0 0 0 91 84 0 0
VecScatterEnd 1420 1.0 3.7127e+0112.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 18 0 0 0 0 0
VecSetRandom 4 1.0 4.9694e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 122 1.0 2.3469e+0021.0 5.85e+07 1.0 0.0e+00 0.0e+00 1.2e+02 0 0 0 0 1 1 0 0 0 10 294
PCSetUp 2 1.0 3.5545e+01 1.0 3.60e+09 1.1 4.4e+03 1.6e+05 9.6e+02 1 1 0 1 6 31 22 15 24 79 1184
PCSetUpOnBlocks 39 1.0 2.9898e-04 1.7 5.53e+03 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 18
PCApply 39 1.0 6.6028e+01 1.1 1.20e+10 1.1 2.4e+04 8.1e+04 1.3e+02 1 2 2 2 1 56 68 82 68 11 1963
PCGAMGgraph_AGG 4 1.0 4.2616e+00 1.0 3.72e+07 1.2 2.3e+02 5.1e+04 7.6e+01 0 0 0 0 0 4 0 1 0 6 93
PCGAMGcoarse_AGG 4 1.0 1.7933e+01 1.0 2.04e+09 1.9 1.3e+03 3.4e+05 2.9e+02 0 0 0 0 2 16 12 5 16 24 1271
PCGAMGProl_AGG 4 1.0 2.2483e+00 1.0 0.00e+00 0.0 5.5e+02 6.4e+04 1.1e+02 0 0 0 0 1 2 0 2 1 9 0
PCGAMGPOpt_AGG 4 1.0 4.4578e+00 1.0 9.11e+08 1.1 1.3e+03 8.0e+04 2.1e+02 0 0 0 0 1 4 5 4 4 17 2310
--- Event Stage 2: momentum_x
MatMult 2 1.0 9.9061e-02 1.1 4.10e+07 1.0 4.4e+01 2.4e+05 0.0e+00 0 0 0 0 0 3 23 50 80 0 4907
MatSolve 3 1.0 1.4430e-01 1.1 6.12e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 5026
MatLUFactorNum 1 1.0 2.5046e-01 1.1 3.43e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 9 19 0 0 0 1622
MatILUFactorSym 1 1.0 1.5358e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 5 0 0 0 4 0
MatAssemblyBegin 1 1.0 2.8467e-013030.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 4 0 0 0 7 0
MatAssemblyEnd 1 1.0 2.2157e-01 1.1 0.00e+00 0.0 4.4e+01 5.9e+04 8.0e+00 0 0 0 0 0 8 0 50 20 29 0
MatGetRowIJ 1 1.0 4.0531e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.8516e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 6.5584e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 8.0632e-01 1.0 1.81e+08 1.0 4.4e+01 2.4e+05 1.2e+01 0 0 0 0 0 29100 50 80 43 2668
VecDot 2 1.0 1.6051e-02 2.0 6.42e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 4 0 0 7 4750
VecDotNorm2 1 1.0 1.5273e-02 1.7 1.28e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 7 0 0 11 9983
VecNorm 2 1.0 6.1728e-0212.2 6.42e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 1235
VecCopy 2 1.0 1.0178e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.7939e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 1.9800e-02 1.4 1.28e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 7700
VecWAXPY 2 1.0 1.6218e-02 1.4 6.42e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 4701
VecAssemblyBegin 2 1.0 2.2810e-02154.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 0 0 0 0 21 0
VecAssemblyEnd 2 1.0 9.0599e-06 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 7.9203e-04 2.3 0.00e+00 0.0 4.4e+01 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 1.6581e-0214.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 2 1.0 4.2014e-01 1.1 3.43e+07 1.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 14 19 0 0 18 967
PCSetUpOnBlocks 1 1.0 4.1998e-01 1.1 3.43e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 14 19 0 0 11 968
PCApply 3 1.0 1.4989e-01 1.1 6.12e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 4838
--- Event Stage 3: momentum_y
MatMult 2 1.0 1.0025e-01 1.1 4.14e+07 1.0 4.4e+01 2.4e+05 0.0e+00 0 0 0 0 0 3 23 50 80 0 4896
MatSolve 3 1.0 1.4338e-01 1.1 6.18e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 5107
MatLUFactorNum 1 1.0 2.6953e-01 1.1 3.46e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 9 19 0 0 0 1521
MatILUFactorSym 1 1.0 1.5543e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 5 0 0 0 4 0
MatAssemblyBegin 1 1.0 3.4289e-013174.8 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 5 0 0 0 7 0
MatAssemblyEnd 1 1.0 2.0907e-01 1.1 0.00e+00 0.0 4.4e+01 6.0e+04 8.0e+00 0 0 0 0 0 7 0 50 20 29 0
MatGetRowIJ 1 1.0 1.9073e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.8706e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 6.5596e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 8.3469e-01 1.0 1.83e+08 1.0 4.4e+01 2.4e+05 1.2e+01 0 0 0 0 0 29100 50 80 43 2596
VecDot 2 1.0 1.5645e-02 1.9 6.42e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 4 0 0 7 4873
VecDotNorm2 1 1.0 1.5150e-02 1.7 1.28e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 7 0 0 11 10064
VecNorm 2 1.0 7.3364e-02 6.5 6.42e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 1039
VecCopy 2 1.0 1.0147e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.7555e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 2.6077e-02 1.9 1.28e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 5847
VecWAXPY 2 1.0 1.6632e-02 1.5 6.42e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 4584
VecAssemblyBegin 2 1.0 1.9942e-02134.7 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 0 0 0 0 21 0
VecAssemblyEnd 2 1.0 8.1062e-06 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 7.4911e-04 2.2 0.00e+00 0.0 4.4e+01 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 1.8597e-0215.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 2 1.0 4.4319e-01 1.1 3.46e+07 1.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 15 19 0 0 18 925
PCSetUpOnBlocks 1 1.0 4.4305e-01 1.1 3.46e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 15 19 0 0 11 925
PCApply 3 1.0 1.4899e-01 1.1 6.18e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 4914
--- Event Stage 4: momentum_z
MatMult 52319 1.0 2.3522e+03 1.1 4.72e+11 1.1 9.9e+05 1.1e+05 0.0e+00 52 62 76 93 0 57 64 78 95 0 2157
MatMultAdd 8012 1.0 1.6520e+02 1.2 3.09e+10 1.2 1.4e+05 1.9e+04 0.0e+00 4 4 11 2 0 4 4 11 2 0 1902
MatMultTranspose 8012 1.0 2.4016e+02 1.4 3.09e+10 1.2 1.4e+05 1.9e+04 0.0e+00 5 4 11 2 0 5 4 11 2 0 1309
MatSolve 444110.2 4.4971e+01 1.7 8.93e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 2354
MatLUFactorNum 145 1.0 4.3540e+01 1.2 5.00e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 1362
MatILUFactorSym 1 1.0 1.5319e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 145 1.0 3.5545e+01 8.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.9e+02 1 0 0 0 2 1 0 0 0 2 0
MatAssemblyEnd 145 1.0 1.6342e+01 1.8 0.00e+00 0.0 4.4e+01 6.0e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 9.5367e-07 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.8826e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 2003 1.0 5.7039e-02 1.3 1.74e+05 0.0 0.0e+00 0.0e+00 2.0e+03 0 0 0 0 13 0 0 0 0 14 3
KSPSetUp 290 1.0 6.3499e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 194 1.0 3.7263e+03 1.0 7.20e+11 1.1 1.3e+06 8.7e+04 1.3e+04 85 98 98 97 82 93100100100 90 2130
VecDot 2244 1.0 1.6008e+02 1.9 7.21e+09 1.0 0.0e+00 0.0e+00 2.2e+03 3 1 0 0 14 3 1 0 0 16 534
VecDotNorm2 1122 1.0 1.5508e+02 1.8 1.44e+10 1.0 0.0e+00 0.0e+00 3.4e+03 3 2 0 0 21 3 2 0 0 23 1103
VecMDot 2003 1.0 4.2973e-02 1.4 8.61e+04 0.0 0.0e+00 0.0e+00 2.0e+03 0 0 0 0 13 0 0 0 0 14 2
VecNorm 5322 1.0 1.1301e+02 3.1 4.23e+09 1.0 0.0e+00 0.0e+00 5.3e+03 1 1 0 0 34 1 1 0 0 37 444
VecScale 36054 1.0 5.6512e+01 1.3 1.42e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 2965
VecCopy 10403 1.0 2.1793e+01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 35069 1.0 1.9805e+01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 66099 1.0 1.7941e+02 1.3 5.68e+10 1.0 0.0e+00 0.0e+00 0.0e+00 4 8 0 0 0 4 8 0 0 0 3736
VecAYPX 64096 1.0 1.9224e+02 1.3 3.55e+10 1.0 0.0e+00 0.0e+00 0.0e+00 4 5 0 0 0 4 5 0 0 0 2179
VecAXPBYCZ 2244 1.0 5.0866e+01 1.5 1.44e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 3363
VecWAXPY 2244 1.0 4.8066e+01 1.4 7.21e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 1780
VecMAXPY 4006 1.0 5.5676e-03 1.5 1.76e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 32
VecAssemblyBegin 388 1.0 2.0726e+01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+03 0 0 0 0 7 0 0 0 0 8 0
VecAssemblyEnd 388 1.0 1.4472e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 48072 1.0 2.3956e+02 1.6 2.13e+10 1.0 0.0e+00 0.0e+00 0.0e+00 5 3 0 0 0 5 3 0 0 0 1049
VecScatterBegin 68343 1.0 1.0083e+01 2.4 0.00e+00 0.0 1.3e+06 8.7e+04 0.0e+00 0 0 98 97 0 0 0100100 0 0
VecScatterEnd 68343 1.0 1.1153e+03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 19 0 0 0 0 20 0 0 0 0 0
VecNormalize 4006 1.0 5.8749e+01698.9 2.64e+05 0.0 0.0e+00 0.0e+00 4.0e+03 0 0 0 0 25 0 0 0 0 28 0
PCSetUp 290 1.0 4.3717e+01 1.2 5.00e+09 1.0 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 1 1 0 0 0 1357
PCSetUpOnBlocks 2148 1.0 4.3718e+01 1.2 5.00e+09 1.0 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 1 1 0 0 0 1357
PCApply 2438 1.0 3.1165e+03 1.0 6.24e+11 1.1 1.2e+06 8.1e+04 6.0e+03 70 83 94 87 38 76 85 96 89 42 2170
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 12 56 2093884688 0
Krylov Solver 4 13 31728 0
Vector 8 85 485916024 0
Vector Scatter 0 12 12720 0
Index Set 0 16 19283008 0
Preconditioner 0 13 12540 0
Viewer 1 0 0 0
Matrix 117 76 1488820988 0
Matrix Coarsen 4 4 2480 0
Krylov Solver 10 4 120512 0
Vector 225 175 387307616 0
Vector Scatter 31 22 23320 0
Index Set 81 74 808508 0
Preconditioner 11 4 3456 0
PetscRandom 4 4 2464 0
Matrix 1 0 0 0
Krylov Solver 1 0 0 0
Vector 10 1 1504 0
Vector Scatter 1 0 0 0
Index Set 5 2 120488 0
Preconditioner 2 0 0 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Index Set 5 2 122104 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Index Set 5 2 122096 0
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 1.03951e-05
Average time for zero size MPI_Send(): 1.1007e-05
#PETSc Option Table entries:
-log_summary
-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Mon Oct 1 11:36:09 2012
Configure options: --with-mpi-dir=/opt/openmpi-1.5.3/ --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.3-dev_shared_rel --known-mpi-shared=1 --with-shared-libraries
Libraries compiled on Mon Oct 1 11:36:09 2012 on hpc12
Machine characteristics: Linux-2.6.32-279.1.1.el6.x86_64-x86_64-with-centos-6.3-Final
Using PETSc directory: /home/wtay/Codes/petsc-dev
Using PETSc arch: petsc-3.3-dev_shared_rel
Using C compiler: /opt/openmpi-1.5.3/bin/mpicc -fPIC -wd1572 -O3 ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /opt/openmpi-1.5.3/bin/mpif90 -fPIC -O3 ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/include -I/home/wtay/Codes/petsc-dev/include -I/home/wtay/Codes/petsc-dev/include -I/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/include -I/opt/openmpi-1.5.3/include
Using C linker: /opt/openmpi-1.5.3/bin/mpicc
Using Fortran linker: /opt/openmpi-1.5.3/bin/mpif90
Using libraries: -Wl,-rpath,/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/lib -L/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/lib -lpetsc -lX11 -Wl,-rpath,/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/lib -L/home/wtay/Codes/petsc-dev/petsc-3.3-dev_shared_rel/lib -lHYPRE -Wl,-rpath,/opt/openmpi-1.5.3/lib -L/opt/openmpi-1.5.3/lib -Wl,-rpath,/opt/intelcpro-11.1.059/lib/intel64 -L/opt/intelcpro-11.1.059/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.6 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.6 -lmpi_cxx -lstdc++ -lpthread -Wl,-rpath,/opt/intelcpro-11.1.059/mkl/lib/em64t -L/opt/intelcpro-11.1.059/mkl/lib/em64t -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lmpi_f90 -lmpi_f77 -lm -lm -lifport -lifcore -lm -lm -lm -lmpi_cxx -lstdc++ -lmpi_cxx -lstdc++ -ldl -lmpi -lnsl -lutil -limf -lsvml -lipgo -ldecimal -lgcc_s -lirc -lpthread -lirc_s -ldl
./a.out on a petsc-3.3-dev_shared_rel named n12-09 with 24 processors, by wtay Wed Oct 3 21:19:36 2012
Time (sec): 3.060e+03 1.00172 3.057e+03
Flops: 3.503e+11 1.23913 2.909e+11 6.982e+12
Flops/sec: 1.145e+08 1.23763 9.515e+07 2.284e+09
MPI Messages: 1.542e+05 3.65607 9.905e+04 2.377e+06
MPI Message Lengths: 8.847e+09 2.01744 8.530e+04 2.028e+11
MPI Reductions: 1.398e+04 1.00000
0: Main Stage: 2.1590e+02 7.1% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 3.600e+01 0.3%
1: poisson: 6.7753e+01 2.2% 1.9064e+11 2.7% 6.527e+04 2.7% 2.477e+03 2.9% 1.307e+03 9.4%
2: momentum_x: 2.0559e+00 0.1% 2.1431e+09 0.0% 1.840e+02 0.0% 1.151e+01 0.0% 2.800e+01 0.2%
3: momentum_y: 1.9997e+00 0.1% 2.1583e+09 0.0% 1.840e+02 0.0% 1.167e+01 0.0% 2.800e+01 0.2%
4: momentum_z: 2.7697e+03 90.6% 6.7873e+12 97.2% 2.312e+06 97.2% 8.280e+04 97.1% 1.258e+04 90.0%
Phase summary info:
MatMult 1053 1.0 3.4221e+01 1.3 5.37e+09 1.3 4.2e+04 1.0e+05 0.0e+00 1 1 2 2 0 44 53 65 75 0 2962
MatMultAdd 156 1.0 1.6699e+00 1.5 3.58e+08 1.5 6.1e+03 1.7e+04 0.0e+00 0 0 0 0 0 2 3 9 2 0 3677
MatMultTranspose 156 1.0 4.1421e+00 3.5 3.58e+08 1.5 6.1e+03 1.7e+04 0.0e+00 0 0 0 0 0 3 3 9 2 0 1482
MatSolve 78 0.0 4.3559e-04 0.0 7.45e+04 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 171
MatLUFactorSym 1 1.0 4.1962e-05 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 3.6955e-05 4.1 6.48e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 175
MatConvert 4 1.0 1.7373e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 1.8639e-01 1.7 3.05e+07 1.4 1.7e+02 9.8e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 2980
MatAssemblyBegin 69 1.0 4.5507e+00 3.2 0.00e+00 0.0 5.3e+02 1.6e+04 7.4e+01 0 0 0 0 1 4 0 1 0 6 0
MatAssemblyEnd 69 1.0 1.4305e+00 1.2 0.00e+00 0.0 2.6e+03 1.3e+04 2.0e+02 0 0 0 0 1 2 0 4 1 15 0
MatGetRow 1821330 1.1 6.5450e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatGetRowIJ 1 0.0 1.4067e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 7.3195e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.3e-02 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 5.3315e-01 1.3 0.00e+00 0.0 3.1e+03 4.7e+04 1.8e+02 0 0 0 0 1 1 0 5 2 14 0
MatAXPY 4 1.0 3.9307e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 1.1955e+00 1.0 2.13e+07 1.3 1.1e+03 4.4e+04 9.6e+01 0 0 0 0 1 2 0 2 1 7 333
MatMatMultSym 4 1.0 9.2042e-01 1.0 0.00e+00 0.0 9.7e+02 3.5e+04 8.8e+01 0 0 0 0 1 1 0 1 1 7 0
MatMatMultNum 4 1.0 2.8186e-01 1.0 2.13e+07 1.3 1.7e+02 9.8e+04 8.0e+00 0 0 0 0 0 0 0 0 0 1 1412
MatPtAP 4 1.0 4.3431e+00 1.0 8.45e+08 2.7 2.2e+03 9.0e+04 1.1e+02 0 0 0 0 1 6 5 3 3 8 1978
MatPtAPSymbolic 4 1.0 2.4485e+00 1.0 0.00e+00 0.0 2.0e+03 7.5e+04 1.0e+02 0 0 0 0 1 4 0 3 2 8 0
MatPtAPNumeric 4 1.0 1.8946e+00 1.0 8.45e+08 2.7 2.4e+02 2.1e+05 8.0e+00 0 0 0 0 0 3 5 0 1 1 4534
MatTrnMatMult 4 1.0 9.8843e+00 1.0 1.03e+09 3.2 1.1e+03 5.9e+05 1.2e+02 0 0 0 0 1 15 12 2 11 9 2291
MatGetLocalMat 20 1.0 5.3209e-01 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 1 0 0 0 2 0
MatGetBrAoCol 12 1.0 2.1986e-01 2.3 0.00e+00 0.0 1.2e+03 1.4e+05 1.6e+01 0 0 0 0 0 0 0 2 3 1 0
MatGetSymTrans 8 1.0 5.6299e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 79 1.0 9.2357e-01 2.1 2.00e+08 1.1 0.0e+00 0.0e+00 7.9e+01 0 0 0 0 1 1 2 0 0 6 4984
KSPSetUp 11 1.0 1.5080e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 1 0
KSPSolve 1 1.0 6.5990e+01 1.0 9.22e+09 1.2 6.5e+04 9.0e+04 1.3e+03 2 3 3 3 9 97100100100 99 2889
VecDot 38 1.0 3.3833e+00 9.7 6.22e+07 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 0 2 1 0 0 3 428
VecDotNorm2 19 1.0 3.3915e+00 7.4 1.24e+08 1.0 0.0e+00 0.0e+00 5.7e+01 0 0 0 0 0 2 2 0 0 4 854
VecMDot 79 1.0 7.9980e-01 3.8 1.00e+08 1.1 0.0e+00 0.0e+00 7.9e+01 0 0 0 0 1 1 1 0 0 6 2878
VecNorm 142 1.0 2.0564e+0011.8 5.28e+07 1.0 0.0e+00 0.0e+00 1.4e+02 0 0 0 0 1 1 1 0 0 11 595
VecScale 746 1.0 9.4111e-01 3.6 1.52e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 3713
VecCopy 201 1.0 2.6442e-01 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 741 1.0 3.9763e-01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 1291 1.0 3.2086e+00 4.0 5.70e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 4082
VecAYPX 1248 1.0 3.0970e+00 3.1 3.55e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 4 0 0 0 2635
VecAXPBYCZ 38 1.0 1.1318e+00 3.5 1.24e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 2560
VecWAXPY 38 1.0 1.0047e+00 3.5 6.22e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 1442
VecMAXPY 122 1.0 3.1358e-01 2.1 1.18e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 8674
VecAssemblyBegin 72 1.0 2.3761e-0110.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.1e+02 0 0 0 0 2 0 0 0 0 16 0
VecAssemblyEnd 72 1.0 1.7858e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 980 1.0 3.3524e+00 3.6 2.23e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 3 0 0 0 1529
VecScatterBegin 1443 1.0 3.2857e-01 5.7 0.00e+00 0.0 5.9e+04 8.4e+04 0.0e+00 0 0 2 2 0 0 0 91 84 0 0
VecScatterEnd 1443 1.0 2.1979e+0125.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 18 0 0 0 0 0
VecSetRandom 4 1.0 4.0149e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 122 1.0 1.3411e+0013.5 3.01e+07 1.1 0.0e+00 0.0e+00 1.2e+02 0 0 0 0 1 0 0 0 0 9 515
PCSetUp 2 1.0 2.2811e+01 1.0 1.83e+09 1.2 1.2e+04 1.2e+05 1.1e+03 1 1 1 1 8 34 22 19 24 80 1839
PCSetUpOnBlocks 39 1.0 2.9802e-04 1.9 6.48e+03 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 22
PCApply 39 1.0 3.5861e+01 1.1 6.76e+09 1.3 5.1e+04 7.9e+04 1.3e+02 1 2 2 2 1 51 68 78 68 10 3622
PCGAMGgraph_AGG 4 1.0 2.9758e+00 1.0 2.13e+07 1.3 4.9e+02 4.9e+04 7.6e+01 0 0 0 0 1 4 0 1 0 6 134
PCGAMGcoarse_AGG 4 1.0 1.0956e+01 1.0 1.03e+09 3.2 5.2e+03 1.8e+05 3.8e+02 0 0 0 0 3 16 12 8 16 29 2067
PCGAMGProl_AGG 4 1.0 1.1267e+00 1.0 0.00e+00 0.0 1.3e+03 5.5e+04 1.1e+02 0 0 0 0 1 2 0 2 1 9 0
PCGAMGPOpt_AGG 4 1.0 3.4058e+00 1.0 4.93e+08 1.2 2.8e+03 7.6e+04 2.1e+02 0 0 0 0 2 5 5 4 4 16 3027
MatMult 2 1.0 9.7961e-02 1.8 2.09e+07 1.1 9.2e+01 2.4e+05 0.0e+00 0 0 0 0 0 4 23 50 80 0 4962
MatSolve 3 1.0 1.1522e-01 1.7 3.10e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 4 34 0 0 0 6257
MatLUFactorNum 1 1.0 1.6440e-01 1.3 1.73e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 19 0 0 0 2448
MatILUFactorSym 1 1.0 1.3943e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 5 0 0 0 4 0
MatAssemblyBegin 1 1.0 4.3930e-014067.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 11 0 0 0 7 0
MatAssemblyEnd 1 1.0 2.0642e-01 1.2 0.00e+00 0.0 9.2e+01 5.9e+04 8.0e+00 0 0 0 0 0 10 0 50 20 29 0
MatGetRowIJ 1 1.0 5.0068e-06 5.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.8502e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 5.3131e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 6.5504e-01 1.0 9.21e+07 1.1 9.2e+01 2.4e+05 1.2e+01 0 0 0 0 0 32100 50 80 43 3272
VecDot 2 1.0 5.4927e-0210.2 3.27e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 1388
VecDotNorm2 1 1.0 5.2273e-02 6.6 6.54e+06 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 1 7 0 0 11 2917
VecNorm 2 1.0 1.5215e-0157.3 3.27e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 4 4 0 0 7 501
VecCopy 2 1.0 8.7559e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.7282e-02 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 2.3268e-02 3.2 6.54e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 6553
VecWAXPY 2 1.0 1.9122e-02 2.8 3.27e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 3987
VecAssemblyBegin 2 1.0 4.0814e-02200.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 1 0 0 0 21 0
VecAssemblyEnd 2 1.0 1.4067e-05 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 1.3988e-03 3.6 0.00e+00 0.0 9.2e+01 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 4.9311e-0226.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 2 1.0 3.1949e-01 1.6 1.73e+07 1.1 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 13 19 0 0 18 1260
PCSetUpOnBlocks 1 1.0 3.1934e-01 1.6 1.73e+07 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 13 19 0 0 11 1260
PCApply 3 1.0 1.2085e-01 1.7 3.10e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 5966
MatMult 2 1.0 9.5242e-02 1.7 2.11e+07 1.1 9.2e+01 2.4e+05 0.0e+00 0 0 0 0 0 4 23 50 80 0 5153
MatSolve 3 1.0 1.1227e-01 1.7 3.13e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 6483
MatLUFactorNum 1 1.0 1.7762e-01 1.4 1.75e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 8 19 0 0 0 2286
MatILUFactorSym 1 1.0 1.3570e-01 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 5 0 0 0 4 0
MatAssemblyBegin 1 1.0 3.2052e-013021.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 8 0 0 0 7 0
MatAssemblyEnd 1 1.0 1.9790e-01 1.2 0.00e+00 0.0 9.2e+01 6.0e+04 8.0e+00 0 0 0 0 0 9 0 50 20 29 0
MatGetOrdering 1 1.0 1.7504e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 5.5541e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 6.6664e-01 1.0 9.28e+07 1.1 9.2e+01 2.4e+05 1.2e+01 0 0 0 0 0 33100 50 80 43 3238
VecDot 2 1.0 5.4068e-02 9.8 3.27e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 1410
VecDotNorm2 1 1.0 5.0182e-02 6.4 6.54e+06 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 1 7 0 0 11 3038
VecNorm 2 1.0 1.5866e-0121.8 3.27e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 4 4 0 0 7 480
VecCopy 2 1.0 9.0349e-03 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.6930e-02 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 2.2837e-02 3.0 6.54e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 6676
VecWAXPY 2 1.0 1.9680e-02 2.7 3.27e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 3874
VecAssemblyBegin 2 1.0 4.1746e-02243.9 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 1 0 0 0 21 0
VecAssemblyEnd 2 1.0 1.3113e-05 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 1.3828e-03 3.6 0.00e+00 0.0 9.2e+01 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 5.0416e-0228.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 2 1.0 3.2991e-01 1.6 1.75e+07 1.1 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 14 19 0 0 18 1231
PCSetUpOnBlocks 1 1.0 3.2973e-01 1.6 1.75e+07 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 14 19 0 0 11 1231
PCApply 3 1.0 1.1918e-01 1.7 3.13e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 34 0 0 0 6107
MatMult 44415 1.0 1.9922e+03 1.5 2.28e+11 1.3 1.8e+06 1.1e+05 0.0e+00 52 62 75 93 0 58 64 77 95 0 2169
MatMultAdd 6796 1.0 1.4178e+02 2.6 1.56e+10 1.5 2.7e+05 1.7e+04 0.0e+00 3 4 11 2 0 3 4 11 2 0 1887
MatMultTranspose 6796 1.0 3.1148e+02 5.0 1.56e+10 1.5 2.7e+05 1.7e+04 0.0e+00 6 4 11 2 0 6 4 11 2 0 859
MatSolve 3833 8.8 2.8625e+01 2.7 4.53e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 3676
MatLUFactorNum 145 1.0 3.1267e+01 1.7 2.53e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 1878
MatILUFactorSym 1 1.0 1.3837e-01 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 145 1.0 2.9783e+0114.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.9e+02 1 0 0 0 2 1 0 0 0 2 0
MatAssemblyEnd 145 1.0 1.1618e+01 2.4 0.00e+00 0.0 9.2e+01 6.0e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 3.0994e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.9623e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 1699 1.0 6.9188e-02 1.3 1.55e+05 0.0 0.0e+00 0.0e+00 1.7e+03 0 0 0 0 12 0 0 0 0 14 2
KSPSetUp 290 1.0 6.0805e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 194 1.0 2.6100e+03 1.0 3.41e+11 1.2 2.3e+06 8.5e+04 1.1e+04 85 97 97 97 80 94100100100 88 2600
VecDot 1940 1.0 2.6695e+0212.3 3.17e+09 1.0 0.0e+00 0.0e+00 1.9e+03 5 1 0 0 14 6 1 0 0 15 277
VecDotNorm2 970 1.0 2.6302e+0210.2 6.35e+09 1.0 0.0e+00 0.0e+00 2.9e+03 5 2 0 0 21 6 2 0 0 23 562
VecMDot 1699 1.0 5.7786e-02 1.7 7.65e+04 0.0 0.0e+00 0.0e+00 1.7e+03 0 0 0 0 12 0 0 0 0 14 1
VecNorm 4562 1.0 1.2351e+0213.8 1.90e+09 1.0 0.0e+00 0.0e+00 4.6e+03 2 1 0 0 33 2 1 0 0 36 359
VecScale 30582 1.0 3.7316e+01 2.8 6.19e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 3810
VecCopy 8883 1.0 1.9754e+01 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 29901 1.0 2.2141e+01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 56067 1.0 1.5246e+02 3.7 2.48e+10 1.1 0.0e+00 0.0e+00 0.0e+00 2 8 0 0 0 3 8 0 0 0 3731
VecAYPX 54368 1.0 1.8245e+02 3.3 1.55e+10 1.1 0.0e+00 0.0e+00 0.0e+00 3 5 0 0 0 3 5 0 0 0 1948
VecAXPBYCZ 1940 1.0 4.4522e+01 2.5 6.35e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 3322
VecWAXPY 1940 1.0 4.2226e+01 2.2 3.17e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 1751
VecMAXPY 3398 1.0 7.1802e-03 2.8 1.56e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 22
VecAssemblyBegin 388 1.0 1.0391e+01 7.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+03 0 0 0 0 8 0 0 0 0 9 0
VecAssemblyEnd 388 1.0 2.3527e-03 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 40776 1.0 1.8958e+02 3.9 9.28e+09 1.1 0.0e+00 0.0e+00 0.0e+00 3 3 0 0 0 3 3 0 0 0 1125
VecScatterBegin 58007 1.0 1.7609e+01 5.9 0.00e+00 0.0 2.3e+06 8.5e+04 0.0e+00 0 0 97 97 0 0 0100100 0 0
VecScatterEnd 58007 1.0 1.3547e+0315.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 29 0 0 0 0 32 0 0 0 0 0
VecNormalize 3398 1.0 6.5100e+01772.4 2.34e+05 0.0 0.0e+00 0.0e+00 3.4e+03 0 0 0 0 24 0 0 0 0 27 0
PCSetUp 290 1.0 3.1397e+01 1.7 2.53e+09 1.1 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 1 1 0 0 0 1871
PCSetUpOnBlocks 1844 1.0 3.1398e+01 1.7 2.53e+09 1.1 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 1 1 0 0 0 1871
PCApply 2134 1.0 2.1924e+03 1.2 2.99e+11 1.3 2.2e+06 7.9e+04 5.1e+03 65 83 93 86 36 72 85 96 89 41 2629
Matrix 12 56 1076276336 0
Vector 8 85 248594232 0
Index Set 0 16 9829416 0
Viewer 1 0 0 0
Matrix 117 76 734590640 0
Vector 225 175 200940576 0
Index Set 81 74 765564 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Average time to get PetscTime(): 2.14577e-07
Average time for MPI_Barrier(): 1.45912e-05
Average time for zero size MPI_Send(): 1.23382e-05
-log_summary
./a.out on a petsc-3.3-dev_shared_rel named n12-02 with 48 processors, by wtay Wed Oct 3 21:04:02 2012
Time (sec): 1.721e+03 1.00353 1.718e+03
Flops: 1.739e+11 1.26420 1.417e+11 6.803e+12
Flops/sec: 1.010e+08 1.26365 8.249e+07 3.960e+09
MPI Messages: 1.686e+05 3.29646 1.101e+05 5.285e+06
MPI Message Lengths: 8.665e+09 2.00778 7.622e+04 4.029e+11
MPI Reductions: 1.377e+04 1.00000
0: Main Stage: 2.1566e+02 12.6% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 3.600e+01 0.3%
1: poisson: 5.6307e+01 3.3% 2.1388e+11 3.1% 1.812e+05 3.4% 2.545e+03 3.3% 1.443e+03 10.5%
2: momentum_x: 1.8503e+00 0.1% 2.1267e+09 0.0% 3.760e+02 0.0% 1.058e+01 0.0% 2.800e+01 0.2%
3: momentum_y: 1.5023e+00 0.1% 2.1417e+09 0.0% 3.760e+02 0.0% 1.073e+01 0.0% 2.800e+01 0.2%
4: momentum_z: 1.4426e+03 84.0% 6.5844e+12 96.8% 5.103e+06 96.6% 7.366e+04 96.6% 1.223e+04 88.8%
Phase summary info:
MatMult 1209 1.0 2.7780e+01 1.3 3.16e+09 1.3 1.2e+05 8.9e+04 0.0e+00 1 2 2 3 0 43 55 64 77 0 4208
MatMultAdd 180 1.0 1.5880e+00 1.8 2.18e+08 1.5 1.4e+04 1.8e+04 0.0e+00 0 0 0 0 0 2 3 7 2 0 4488
MatMultTranspose 180 1.0 3.2210e+00 3.9 2.18e+08 1.5 1.4e+04 1.8e+04 0.0e+00 0 0 0 0 0 3 3 7 2 0 2212
MatSolve 90 0.0 6.0534e-04 0.0 1.18e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 196
MatLUFactorSym 1 1.0 6.1035e-05 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 5.4121e-05 6.1 1.04e+04 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 191
MatConvert 4 1.0 1.3334e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 1.3946e-01 1.7 1.58e+07 1.4 4.0e+02 8.3e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 4001
MatAssemblyBegin 69 1.0 4.9522e+00 2.5 0.00e+00 0.0 1.2e+03 1.4e+04 7.4e+01 0 0 0 0 1 6 0 1 0 5 0
MatAssemblyEnd 69 1.0 1.4642e+00 1.1 0.00e+00 0.0 6.7e+03 1.0e+04 2.0e+02 0 0 0 0 1 2 0 4 1 14 0
MatGetRow 961340 1.1 4.5354e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatGetRowIJ 1 0.0 1.4782e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 7.7963e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.2e-02 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 5.2552e-01 1.2 0.00e+00 0.0 1.9e+04 1.8e+04 2.8e+02 0 0 0 0 2 1 0 10 2 20 0
MatAXPY 4 1.0 4.2417e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 1.0365e+00 1.0 1.10e+07 1.4 2.8e+03 3.7e+04 9.6e+01 0 0 0 0 1 2 0 2 1 7 386
MatMatMultSym 4 1.0 7.9752e-01 1.1 0.00e+00 0.0 2.4e+03 2.9e+04 8.8e+01 0 0 0 0 1 1 0 1 1 6 0
MatMatMultNum 4 1.0 2.5070e-01 1.1 1.10e+07 1.4 4.0e+02 8.3e+04 8.0e+00 0 0 0 0 0 0 0 0 0 1 1594
MatPtAP 4 1.0 3.2046e+00 1.0 4.77e+08 3.1 5.9e+03 6.9e+04 1.1e+02 0 0 0 0 1 6 4 3 3 7 2670
MatPtAPSymbolic 4 1.0 1.9027e+00 1.1 0.00e+00 0.0 5.3e+03 5.7e+04 1.0e+02 0 0 0 0 1 3 0 3 2 7 0
MatPtAPNumeric 4 1.0 1.3268e+00 1.0 4.77e+08 3.1 6.0e+02 1.7e+05 8.0e+00 0 0 0 0 0 2 4 0 1 1 6450
MatTrnMatMult 4 1.0 8.2181e+00 1.0 5.30e+08 4.6 2.7e+03 4.7e+05 1.2e+02 0 0 0 0 1 15 10 1 10 8 2722
MatGetLocalMat 20 1.0 3.5593e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 1 0 0 0 2 0
MatGetBrAoCol 12 1.0 2.3268e-01 2.4 0.00e+00 0.0 2.8e+03 1.2e+05 1.6e+01 0 0 0 0 0 0 0 2 3 1 0
MatGetSymTrans 8 1.0 4.9805e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 85 1.0 6.8444e-01 1.7 1.06e+08 1.1 0.0e+00 0.0e+00 8.5e+01 0 0 0 0 1 1 2 0 0 6 6731
KSPSetUp 11 1.0 1.4524e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 1 0
KSPSolve 1 1.0 5.5045e+01 1.0 5.31e+09 1.3 1.8e+05 7.4e+04 1.4e+03 3 3 3 3 10 98100100100 99 3886
VecDot 44 1.0 2.4764e+00 3.6 3.73e+07 1.1 0.0e+00 0.0e+00 4.4e+01 0 0 0 0 0 3 1 0 0 3 677
VecDotNorm2 22 1.0 2.5759e+00 4.2 7.47e+07 1.1 0.0e+00 0.0e+00 6.6e+01 0 0 0 0 0 3 2 0 0 5 1302
VecMDot 85 1.0 5.4579e-01 2.1 5.29e+07 1.1 0.0e+00 0.0e+00 8.5e+01 0 0 0 0 1 1 1 0 0 6 4221
VecNorm 157 1.0 2.4986e+0011.5 3.01e+07 1.1 0.0e+00 0.0e+00 1.6e+02 0 0 0 0 1 2 1 0 0 11 535
VecScale 854 1.0 5.2014e-01 2.8 9.18e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 7690
VecCopy 231 1.0 2.2006e-01 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 843 1.0 2.7842e-01 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 1489 1.0 1.6388e+00 2.8 3.47e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 9226
VecAYPX 1440 1.0 2.2286e+00 2.6 2.16e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 4 0 0 0 4229
VecAXPBYCZ 44 1.0 6.8125e-01 2.2 7.47e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 4924
VecWAXPY 44 1.0 7.3601e-01 2.3 3.73e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 2279
VecMAXPY 134 1.0 2.0552e-01 1.9 6.25e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 13246
VecAssemblyBegin 97 1.0 3.6385e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.8e+02 0 0 0 0 2 1 0 0 0 20 0
VecAssemblyEnd 97 1.0 3.5381e-04 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 1124 1.0 2.1477e+00 2.4 1.35e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 3 0 0 0 2740
VecScatterBegin 1672 1.0 4.9030e-01 3.5 0.00e+00 0.0 1.7e+05 7.0e+04 0.0e+00 0 0 3 3 0 1 0 92 86 0 0
VecScatterEnd 1672 1.0 1.9463e+0113.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 16 0 0 0 0 0
VecSetRandom 4 1.0 4.0139e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 134 1.0 2.1754e+0016.8 1.59e+07 1.1 0.0e+00 0.0e+00 1.3e+02 0 0 0 0 1 2 0 0 0 9 318
PCSetUp 2 1.0 1.8591e+01 1.0 9.41e+08 1.3 4.2e+04 7.0e+04 1.2e+03 1 1 1 1 8 33 19 23 22 80 2241
PCSetUpOnBlocks 45 1.0 6.5732e-04 3.5 1.04e+04 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 16
PCApply 45 1.0 2.9939e+01 1.1 4.01e+09 1.3 1.4e+05 7.0e+04 1.5e+02 2 2 3 2 1 51 70 75 71 10 5025
PCGAMGgraph_AGG 4 1.0 2.3984e+00 1.0 1.10e+07 1.4 1.2e+03 4.2e+04 7.6e+01 0 0 0 0 1 4 0 1 0 5 167
PCGAMGcoarse_AGG 4 1.0 9.2185e+00 1.0 5.30e+08 4.6 2.4e+04 7.9e+04 4.8e+02 1 0 0 0 3 16 10 13 14 33 2427
PCGAMGProl_AGG 4 1.0 9.8128e-01 1.0 0.00e+00 0.0 3.2e+03 4.6e+04 1.1e+02 0 0 0 0 1 2 0 2 1 8 0
PCGAMGPOpt_AGG 4 1.0 2.8071e+00 1.0 2.53e+08 1.2 6.8e+03 6.4e+04 2.1e+02 0 0 0 0 2 5 5 4 3 15 3682
MatMult 2 1.0 1.0542e-01 2.0 1.08e+07 1.2 1.9e+02 2.4e+05 0.0e+00 0 0 0 0 0 3 23 50 80 0 4611
MatSolve 3 1.0 8.1705e-02 2.0 1.59e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 33 0 0 0 8719
MatLUFactorNum 1 1.0 1.4021e-01 2.1 8.82e+06 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 19 0 0 0 2814
MatILUFactorSym 1 1.0 1.3817e-01 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 4 0 0 0 4 0
MatAssemblyBegin 1 1.0 7.5712e-014946.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 27 0 0 0 7 0
MatAssemblyEnd 1 1.0 1.8089e-01 1.2 0.00e+00 0.0 1.9e+02 5.9e+04 8.0e+00 0 0 0 0 0 9 0 50 20 29 0
MatGetRowIJ 1 1.0 1.0014e-0510.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 2.1192e-02 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 7 0
KSPSetUp 2 1.0 6.2056e-02 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 6.0202e-01 1.0 4.74e+07 1.1 1.9e+02 2.4e+05 1.2e+01 0 0 0 0 0 32100 50 80 43 3533
VecDot 2 1.0 4.6937e-02 3.8 1.70e+06 1.1 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 2 4 0 0 7 1624
VecDotNorm2 1 1.0 4.7157e-02 6.1 3.39e+06 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 2 7 0 0 11 3233
VecNorm 2 1.0 2.2409e-0134.8 1.70e+06 1.1 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 9 4 0 0 7 340
VecCopy 2 1.0 9.5789e-03 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.3558e-02 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPBYCZ 2 1.0 2.1303e-02 3.6 3.39e+06 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 7157
VecWAXPY 2 1.0 1.6192e-02 2.7 1.70e+06 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 4708
VecAssemblyBegin 2 1.0 5.5579e-02156.2 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 2 0 0 0 21 0
VecAssemblyEnd 2 1.0 1.5020e-05 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 1.5790e-03 2.4 0.00e+00 0.0 1.9e+02 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 5.5989e-0228.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 2 1.0 3.0002e-01 2.4 8.82e+06 1.2 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 9 19 0 0 18 1315
PCSetUpOnBlocks 1 1.0 2.9975e-01 2.4 8.82e+06 1.2 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 9 19 0 0 11 1316
PCApply 3 1.0 8.5135e-02 1.9 1.59e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 33 0 0 0 8367
MatMult 2 1.0 1.0478e-01 2.0 1.09e+07 1.2 1.9e+02 2.4e+05 0.0e+00 0 0 0 0 0 4 23 50 80 0 4684
MatSolve 3 1.0 7.1359e-02 1.6 1.61e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 4 34 0 0 0 10078
MatLUFactorNum 1 1.0 1.3938e-01 1.9 8.90e+06 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 6 19 0 0 0 2856
MatILUFactorSym 1 1.0 1.1233e-01 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 5 0 0 0 4 0
MatAssemblyBegin 1 1.0 3.2594e-0124.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 13 0 0 0 7 0
MatAssemblyEnd 1 1.0 1.8197e-01 1.1 0.00e+00 0.0 1.9e+02 6.0e+04 8.0e+00 0 0 0 0 0 11 0 50 20 29 0
MatGetRowIJ 1 1.0 2.1458e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 2.0951e-02 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 6.4847e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 5.6900e-01 1.0 4.78e+07 1.1 1.9e+02 2.4e+05 1.2e+01 0 0 0 0 0 37100 50 80 43 3764
VecDot 2 1.0 4.5465e-02 3.5 1.70e+06 1.1 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 2 4 0 0 7 1677
VecDotNorm2 1 1.0 5.0043e-02 3.8 3.39e+06 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 3 7 0 0 11 3047
VecNorm 2 1.0 1.7585e-0133.5 1.70e+06 1.1 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 8 4 0 0 7 434
VecCopy 2 1.0 6.0210e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 1.7671e-02 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 1.4564e-02 2.4 3.39e+06 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 10469
VecWAXPY 2 1.0 1.6496e-02 2.7 1.70e+06 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 4621
VecAssemblyBegin 2 1.0 4.9739e-02159.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 2 0 0 0 21 0
VecAssemblyEnd 2 1.0 1.7881e-05 6.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 1.1569e-0219.1 0.00e+00 0.0 1.9e+02 2.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 5.5051e-0223.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 2 1.0 2.7300e-01 2.1 8.90e+06 1.2 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 12 19 0 0 18 1458
PCSetUpOnBlocks 1 1.0 2.7282e-01 2.1 8.90e+06 1.2 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 12 19 0 0 11 1459
PCApply 3 1.0 7.5869e-02 1.6 1.61e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 4 34 0 0 0 9479
MatMult 42907 1.0 9.8638e+02 1.3 1.13e+11 1.3 4.1e+06 9.0e+04 0.0e+00 51 62 78 92 0 61 64 81 95 0 4250
MatMultAdd 6564 1.0 7.0460e+01 2.2 7.96e+09 1.5 4.9e+05 1.8e+04 0.0e+00 2 4 9 2 0 3 4 10 2 0 3688
MatMultTranspose 6564 1.0 1.2860e+02 4.9 7.96e+09 1.5 4.9e+05 1.8e+04 0.0e+00 3 4 9 2 0 4 4 10 2 0 2021
MatSolve 3717 8.5 1.1711e+01 1.4 2.33e+09 1.2 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 8879
MatLUFactorNum 145 1.0 1.4473e+01 1.3 1.29e+09 1.2 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 3979
MatILUFactorSym 1 1.0 1.2902e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 145 1.0 2.5208e+01 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.9e+02 1 0 0 0 2 1 0 0 0 2 0
MatAssemblyEnd 145 1.0 7.4327e+00 2.4 0.00e+00 0.0 1.9e+02 6.0e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.9673e-02 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 1641 1.0 1.7774e-01 1.4 1.76e+05 0.0 0.0e+00 0.0e+00 1.6e+03 0 0 0 0 12 0 0 0 0 13 1
KSPSetUp 290 1.0 7.1497e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 194 1.0 1.3382e+03 1.0 1.68e+11 1.3 5.1e+06 7.6e+04 1.1e+04 78 97 97 97 78 93100100100 88 4920
VecDot 1882 1.0 8.1310e+01 5.0 1.60e+09 1.1 0.0e+00 0.0e+00 1.9e+03 3 1 0 0 14 3 1 0 0 15 882
VecDotNorm2 941 1.0 8.2061e+01 4.1 3.19e+09 1.1 0.0e+00 0.0e+00 2.8e+03 3 2 0 0 21 3 2 0 0 23 1748
VecMDot 1641 1.0 1.6827e-01 1.5 8.70e+04 0.0 0.0e+00 0.0e+00 1.6e+03 0 0 0 0 12 0 0 0 0 13 1
VecNorm 4417 1.0 6.4342e+01 9.1 9.63e+08 1.1 0.0e+00 0.0e+00 4.4e+03 1 1 0 0 32 1 1 0 0 36 672
VecScale 29538 1.0 1.9634e+01 3.2 3.16e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 7001
VecCopy 8593 1.0 1.0218e+01 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 28915 1.0 1.3080e+01 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 54153 1.0 6.1113e+01 3.0 1.26e+10 1.1 0.0e+00 0.0e+00 0.0e+00 2 8 0 0 0 3 8 0 0 0 8997
VecAYPX 52512 1.0 8.6173e+01 2.7 7.89e+09 1.1 0.0e+00 0.0e+00 0.0e+00 4 5 0 0 0 4 5 0 0 0 3988
VecAXPBYCZ 1882 1.0 2.8966e+01 2.1 3.19e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 4953
VecWAXPY 1882 1.0 2.8427e+01 2.1 1.60e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 2524
VecMAXPY 3282 1.0 6.8157e-03 3.1 1.77e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 26
VecAssemblyBegin 388 1.0 8.7212e+0011.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+03 0 0 0 0 8 0 0 0 0 10 0
VecAssemblyEnd 388 1.0 2.8818e-03 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 39384 1.0 8.7410e+01 2.7 4.73e+09 1.1 0.0e+00 0.0e+00 0.0e+00 3 3 0 0 0 4 3 0 0 0 2359
VecScatterBegin 56035 1.0 2.0136e+01 4.1 0.00e+00 0.0 5.1e+06 7.6e+04 0.0e+00 1 0 97 97 0 1 0100100 0 0
VecScatterEnd 56035 1.0 6.7774e+0213.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 18 0 0 0 0 22 0 0 0 0 0
VecNormalize 3282 1.0 4.7531e+01301.1 2.66e+05 0.0 0.0e+00 0.0e+00 3.3e+03 0 0 0 0 24 0 0 0 0 27 0
PCSetUp 290 1.0 1.4621e+01 1.3 1.29e+09 1.2 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 1 1 0 0 0 3939
PCSetUpOnBlocks 1786 1.0 1.4621e+01 1.3 1.29e+09 1.2 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 1 1 0 0 0 3939
PCApply 2076 1.0 1.1022e+03 1.1 1.48e+11 1.3 4.9e+06 7.0e+04 4.9e+03 61 82 93 86 36 73 85 97 89 40 5071
Matrix 12 56 568064932 0
Vector 8 85 129979032 0
Index Set 0 16 5102648 0
Viewer 1 0 0 0
Matrix 117 76 368468980 0
Vector 225 175 107847696 0
Index Set 81 74 737472 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Average time to get PetscTime(): 1.19209e-07
Average time for MPI_Barrier(): 4.45843e-05
Average time for zero size MPI_Send(): 1.93516e-05
-log_summary
