[petsc-users] PetscFinalize()
Eleni Siampli
siaeleni at hotmail.com
Wed Oct 3 11:58:53 CDT 2012
Hello again,
It doen't work good. I have created a dll for solving the eigenPorblem (eigenSolver.dll) and I included it in my current project.
lets say that eigenSolver is the name of my class.. What I use is:
eigensolver eig;
for a lot of iterations and works fine. I call only one the PetscInitialize();
I want also to use:
eigensolver eig1;
eigensolver eig2;
I call only once PetscInitialize(); for each eig1 and eig 2.
I have the same error as before.
Why does it give me the same error?I call only once the PetscInitialize().
Thanks a lot in advance,
Helen
Date: Fri, 28 Sep 2012 20:23:20 -0400
To: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PetscFinalize()
On Fri, Sep 28, 2012 at 5:09 PM, Eleni Siampli <siaeleni at hotmail.com> wrote:
Thank you for the answer. Problem solved, but now I have another one:
After a lot of iterations (around 246) It gives me the following error:
[0]PETSC ERROR: Petsc has generated inconsistent data!
[0]PETSC ERROR: No more room in array, limit 256
recompile src/sys/objects/destroy.c with larger value for MAXREGFIN
Do you have any idea about this problem?
You are also calling PetscInitialize() a bunch of times. Its intended for just one.
Matt
Helen
Date: Fri, 28 Sep 2012 11:17:51 -0400
On Fri, Sep 28, 2012 at 11:16 AM, Eleni Siampli <siaeleni at hotmail.com> wrote:
Hey all,
I would like to solve the eigenvalue problem.
My code is working for 2 loops and give the right values, but after two loops it gives me the following error:
[0]PETSC ERROR: PetscFinalize() line 1221 in src/sys/objects/C:\cygwin\home\liyi
0000\PETSC-~1.2-P\src\sys\objects\pinit.c
[0]PETSC ERROR: SlepcFinalize() line 224 in src/sys/C:\cygwin\home\liyi0000\SLEP
C-~1.2-P\src\sys\slepcinit.c
Options have not been enabled.
You might have forgotten to call PetscInitialize().
Do you have any idea what this error mean?
You are only intended to call PetscFinalize() once, at the end of your program.
Matt
Thank you in advance,
Helen
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121003/873427e7/attachment-0001.html>
