[petsc-users] question about MatXAIJSetPreallocation
Geoffrey Irving
irving at naml.us
Tue Oct 2 18:57:52 CDT 2012
On Tue, Oct 2, 2012 at 4:48 PM, Geoffrey Irving <irving at naml.us> wrote:
> The dnnz argument to MatXAIJSetPreallocation is described as
> dnnz - number of nonzero blocks per block row of diagonal part of
> parallel matrix
> To me, this implies that if the matrix has size m and the block size
> is bs, dnnz should have size m/bs. However, the loop inside the
> routine looks like
> for (i=0; i<m*bs; i++) {
> if (dnnz) sdnnz[i] = dnnz[i/bs] * bs;
> if (onnz) sonnz[i] = onnz[i/bs] * bs;
> which implies that dnnz should have m entries. Is this a bug, or am I
> misinterpreting the meaning of dnnz?
It looks like the loop hasn't changed since the beginning of
MatXAIJSetPreallocation, but the comment changed from
dnnz - number of nonzeros per row of diagonal block of parallel matrix
to
parallel matrix
in
commit abccccb5e4359792067c7bef9b175a0511adf626
Author: Jed Brown <jed at 59A2.org>
Date: Thu Mar 1 11:51:58 2012 -0600
Remove the maximum nonzero arguments from MatXAIJSetPreallocation()
I'll change my code to match the first comment and see if it works.
Geoffrey
