[petsc-users] Using MatSetValues to add all matrix values in 1 run
TAY wee-beng
zonexo at gmail.com
Mon Oct 1 09:36:37 CDT 2012
I'm trying to insert values into my PETSc matrix using MatSetValues.
I tried using:
/do ijk=ijk_xyz_sta,ijk_xyz_end//
// II = ijk - 1 !Fortran shift to 0-based//
// call
MatSetValues(A_semi_xyz,1,II,7,int_semi_xyz(ijk,1:7),semi_mat_xyz(ijk,1:7),INSERT_VALUES,ierr)//
//end do/
where ijk_xyz_sta/ijk_xyz_end are the starting/end index
int_semi_xyz(ijk,1:7) stores the 7 column global indices
semi_mat_xyz has the corresponding values.
This work well but I'm trying to call MatSetValues in 1 statement, it
failed. I tried:
/do ijk = 1,ijk_xyz_end-ijk_xyz_sta//
// rows(ijk) = ijk_xyz_sta + ijk - 1// !to get row's global indices
//end do//
//call
MatSetValues(A_semi_xyz,ijk_xyz_end-ijk_xyz_sta,rows,7,int_semi_xyz(ijk_xyz_sta+1:ijk_xyz_end,1:7),semi_mat_xyz(ijk_xyz_sta+1:ijk_xyz_end,1:7),INSERT_VALUES,ierr)/
but when I use MatView, the values are in the wrong locations.
May I know what's wrong?
Thanks
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121001/9e38ae66/attachment-0001.html>
