[petsc-users] Is PCFactorSetZeroPivot() effective?
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu May 31 15:12:54 CDT 2012
On Thu, May 31, 2012 at 3:08 PM, Jozsef Bakosi <jbakosi at lanl.gov> wrote:
> Using -sub_pc_factor_zeropivot does not seem to make any difference.
Run with -ksp_view and send the output. Also send the FULL error message
when it finds a zero pivot.
> > > Is there a way to query the zero pivot value?
> > 3) Its printed out, 1.0e-12
> Yeah. I mean something like PCFactorGetZeroPivot(), so I can check what
> PETSc think I'm trying to use. The above persistent error message seems
> to indicate that whatever I'm setting is not being used.
> BTW, this error seems to happen only at larger core counts. I wonder if
> that gives you a clue as to what might be the problem (e.g. what might
> cause a zeropivot).
What discretization are you using?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120531/520c1a1b/attachment-0001.html>
