[petsc-users] output parallel matrix
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu May 31 13:42:29 CDT 2012
On Thu, May 31, 2012 at 1:40 PM, recrusader <recrusader at gmail.com> wrote:
> I am sorry that I didn't explain my purpose clearly.
> The reason I output the matrix is to reformat the matrix since I need to
> import the matrix to another program.
> Therefore, I need to first output the matrix and reformat it using other
> codes.
> if I output the matrix using PETSc Binary format, I need to find a method
> to import it to that program not using MatLoad.
Why not have the other program use MatLoad()?
This business of writing the matrix to disk as part of your workflow is
going to be a constant source of pain, limiting scalability, making
everything slow, and limiting what methods you can use.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120531/c2935439/attachment.html>
