[petsc-users] Is PCFactorSetZeroPivot() effective?
Wed May 30 18:27:30 CDT 2012
On Wed, May 30, 2012 at 7:20 PM, Jozsef Bakosi <jbakosi at lanl.gov> wrote:
> Hello,
> I have a mesh with very small cell sizes and in a Poisson equation CG solve
> with ML preconditioner I get the following error:
> [31]PETSC ERROR: --------------------- Error Message
> [31]PETSC ERROR: Detected zero pivot in LU factorization see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot
> [31]PETSC ERROR: Zero pivot row 537 value 9.41111e-13 tolerance 1e-12!
> I really would like PETSc to NOT treat matrix values lower than 1e-12 to
> be zero, so I'm trying to set the zero pivot to a lower value with
> PCFactorSetZeroPivot(), but I still get the same error message: as if
> the function call would have no effect. I also tried setting the
> zeropivot via PetscOptionsSetValue("-pc_factor_zeropivot", ...), but
> still no luck.
> Is there another way to set the zero pivot that I'm not aware of?
1) Always look at -ksp_view
2) I bet this is a subsolve, so that it would be -sub_pc_factor_zeropivot
<value>. You
    can verify by looking at -ksp_view
> Is there a way to query the zero pivot value?
3) Its printed out, 1.0e-12
   Matt
> Thanks,
> J
> Jozsef Bakosi
> Computational Physics Group (CCS-2)
> MS T006, Los Alamos National Laboratory
> Los Alamos, NM 87545, USA
> email: jbakosi at lanl.gov
> work: 505-663-5607
> fax : 505-663-5504
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120530/f2e2bcc4/attachment-0001.html>
