[petsc-users] SAME_PRECONDITIONER vs. DIFFERENT_NONZERO_PATTERN
Matthew Knepley
knepley at gmail.com
Wed May 30 14:20:02 CDT 2012
On Wed, May 30, 2012 at 3:16 PM, John Fettig <john.fettig at gmail.com> wrote:
> On Wed, May 30, 2012 at 3:04 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Wed, May 30, 2012 at 1:58 PM, John Fettig <john.fettig at gmail.com>
> wrote:
> >> I have a question about the difference between SAME_PRECONDITIONER and
> >> DIFFERENT_NONZERO_PATTERN. If you solve multiple RHS's (with
> >> different initial guesses) but the matrix does not change, should you
> >> expect to get identical results with SAME_PRECONDITIONER and
> >> DIFFERENT_NONZERO_PATTERN?
> > Why are you even calling KSPSetOperators? Just call KSPSolve() for each
> > right hand side.
> What I mean is if I run the code twice, once with SAME_PRECONDITIONER
> and once with DIFFERENT_NONZERO_PATTERN, the solution for the second
> solve in the code is different. I am sure the matrix does not change.
> There are a couple of calls to MatZeroRows but I have verified that
> the diagonal is set to the exact same value both time. The difference
> in the solution is not insignificant (it is probably below the solver
> tolerance but still in the 3rd significant digit).
Is the initial residual the same. It would be helpful to see the
-ksp_monitor_true_residual
output
Matt
> John
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120530/9d25d491/attachment.html>
