[petsc-users] Windows 7 32bit installation trouble
Xuefeng Li li at loyno.edu
Wed May 30 11:00:43 CDT 2012
Dear Petsc team.
I use mpich2/cygwin under my windows 7 (32bit)
computer. Petsc installation process was sucessful,
using the following command in $PETSC_DIR.
   ./configure --download-f-blas-lapack=1
PETSC_DIR and PETSC_ARC were set/exported.
   make all
went without much trouble, with some minor complaints
such as
   win32draw.c: In function .PetscDrawLine_Win32.:
   win32draw.c:279:3: warning: value computed is not used
However, when testing with
   make test
it issues the following error message.
   Running test examples to verify correct installation
   Using PETSC_DIR=/home/Friend/software/petsc-3.2-p7 and PETSC_ARCH=arch-mswin-c-opt
   Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
   See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
What is wrong in the process?
--Xuefeng Li, (504)865-3340(phone)
   Like floating clouds, the heart rests easy
   Like flowing water, the spirit stays free
        http://www.loyno.edu/~li/home
   New Orleans, Louisiana (504)865-2051(fax)
