[petsc-users] randomness from MATSOLVERPACKAGE
Hui Zhang
mike.hui.zhang at hotmail.com
Wed May 30 09:37:11 CDT 2012
> How is the matrix assembled?
In a deterministic way.
> How different?
Not very much. The last residual can vary in its trailing digits, e.g. from 6.5819e-7 to 6.5820e-7
> You should usually not expect deterministic associativity.
Ok, I see. Thanks!
> If your results are sensitive, you may be able to make it deterministic (with extra work and choice of package), but you should probably reformulate the problem
> On May 30, 2012 9:21 AM, "Hui Zhang" <mike.hui.zhang at hotmail.com> wrote:
> > I suspect there are some randomness from external matsolverpackage. I use a parallel matrix
> > as preconditioner, and the preconditioner is exactly LU factored, then I saw the KSP (gmres)
> > residuals are different from different runs.
> Besides, for sequential matrix, there is no such phenomenon, only for parallel matrix.
> > Is it true of randomness from matsolverpackage? Thanks a lot!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120530/4d713f18/attachment.html>
