[petsc-users] PETSc installed without X windows on this machine
w_ang_temp w_ang_temp at 163.com
Wed May 30 08:46:29 CDT 2012
Hello Matt
     I am sorry for the vague statements.
     When use MatView() in the code, it can print the matrix by the CSR form in the terminal.
     When I try to view the matrix with the runtime option -mat_view_draw, I get the error message. I just want to draw the matrix nonzero structure.
      Thanks.
                                                 Jim
>在 2012-05-30 21:27:40,"Matthew Knepley" <knepley at gmail.com> 写道:
>On Wed, May 30, 2012 at 9:20 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>Hello
>    When I try to view a matrix with the option -mat_view_draw, I get :
>    [0]PETSC ERROR: PETSc installed without X windows on this machine proceeding without graphics.
>    But calling MatView in side the code is ok.
>Are you saying that from within the code, MatView() draws a picture in an X-window? I do not see
>how that can possibly be the case. PETSc did not compile support for that, as it says in the error
>message.
>   Matt
>    I install the libX11-dev as Matt said in one message in the petsc-users in 2008,  but the problem doesn't solved.
>    The system is ubuntu 10.04.
>    So what might be the reason?
>    Thanks.
>                                          Jim
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120530/99ec8e1b/attachment-0001.html>
