[petsc-users] A qustion of PETSc
Sat May 26 09:26:20 CDT 2012
On Sat, May 26, 2012 at 2:22 PM, w_ang_temp <w_ang_temp at 163.com> wrote:
> Hello,Matt
>     Thanks again.
>     What you said("Use -ksp_type preonly -pc_type lu") means that I should
> use a direct solver.And I am puzzled.
Okay, you want to remove variables from the investigation. You say there is
a difference between
the parallel and serial solve. We do this all the time, so it is not a bug.
It is an issue of understanding.
First, take away the tolerance issues:
  -ksp_rtol 1.0e-15 -ksp_converged_reason -ksp_monitor_true_residual
and send output of the serial and parallel run.
   Matt
>     (1)I think this problem (single processor is ok and more than one are
> problematic)is typical,but I cannot
> find useful infomation both in the manual and the petsc-users.So can you
> give me some explanation for this
> phenomenon.
>     (2)When I use -pc_type lu,the error message is "Matrix format mpiaij
> does not have a built-in PETSc LU!".
>     (3)The manual says that "This approach prevents the user from the
> unexpected surprise of having a
> corrupted matrix after a linear solve"(P72).So do you mean the problem of
> mine is here?
>     (4)Generally I want to use the iterative approach other than the
> direct method.
>     As a beginne r,I have to learn more about the manual.And also I think
> an experienced senior will be a more
>  useful help for me because I have gotten stuck on this problem for more
> than a week.
>      Thanks.                                Jim
> >At 2012-05-26 20:17:42,"Matthew Knepley" <knepley at gmail.com> wrote:
> >Use -ksp_type preonly -pc_type lu.
>  >  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120526/4cc8acfd/attachment-0001.html>
