[petsc-users] Multigrid Vcycle.
Abdul Hanan Sheikh hanangul12 at yahoo.co.uk
Fri May 25 12:12:31 CDT 2012
Dear all,
Are you seeing the memory used by those vectors being a significant part of the overall memory usage of the program?
To this question, I think yes.
Is it also normal, number of vectors is dependent upon how many levels used ?
I experienced this. When I increase levels in PCMG, number of vectors used (created and destroyed) increases.
Abdul .
>________________________________
> From: Jed Brown <jedbrown at mcs.anl.gov>
>To: Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>; PETSc users list <petsc-users at mcs.anl.gov>
>Sent: Thursday, 24 May 2012, 22:06
>Subject: Re: [petsc-users] Multigrid Vcycle.
>On Thu, May 24, 2012 at 2:29 PM, Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk> wrote:
>Thanks for early response Jed!,
>>I fixed outer Krylov as PREONLY so it does not use any vectors (I guess).
>>Standard Vcycle includes 1 pre and 1 post smoothing.
>>KSP-Richardson + PC-Jacobi are ingredients for pre-smoothing and  post smoothing.
>>To my understanding, 2 Vectors are used by KSP Richardson + 1 Vector is used by PC-Jacobi
>>at pre and post smoothing. This makes 6 vectors at each level and for 5 levels, they should be 30!
>DMSetUp_DA_nD creates and destroys two vectors as part of its set up process. There is also a scaling vector associated with restriction (so that restriction and prolongation can use the same matrix, which they usually do), including a momentary work vector used to compute the scaling. So many of those vectors are not alive at once.
>Barry,
>>Do I think right ?
>>Further hint to make PCMG more memory-efficient is appreciated.
>>with warm regard, Abdul
>>>Sent: Thursday, 24 May 2012, 21:22
>>>On Thu, May 24, 2012 at 2:14 PM, Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk> wrote:
>>>Dear all,
>>>>I am quit beginner in PETSc.
>>>>I wrote a code for multigrid Vcycle (as preconditioer) by following the instructions on manual page.
>>>>I want to see how much memory a Vcycle allocates by default in terms of number of matrices and vectors.
>>>>I made a try to see by comparing with jacobi preconditioner, which surely allocates 1 vector ONLY.
>>>>It turns out that a VCycle for FIVE (5) levels including coarsest level allocates memory for 53 vectors and
>>>>subsequently it destroys too.
>>>Some of those vectors are very small due to being on the coarse level. There are also the vectors used by the outer Krylov method.
>>>>Is it normal ??
>>>>Thanks in advance,
>>>>Abdul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120525/99026ad2/attachment.html>
