[petsc-users] Fw: Multigrid Vcycle.
Abdul Hanan Sheikh
hanangul12 at yahoo.co.uk
Thu May 24 14:30:05 CDT 2012
Thanks for early response Jed!,
>I fixed outer Krylov as PREONLY so it does not use any vectors (I guess).
>Standard Vcycle includes 1 pre and 1 post smoothing.
>KSP-Richardson + PC-Jacobi are ingredients for pre-smoothing and post smoothing.
>To my understanding, 2 Vectors are used by KSP Richardson + 1 Vector is used by PC-Jacobi
>at pre and post smoothing. This makes 6 vectors at each level and for 5 levels, they should be 30!
>Do I think right ?
>Further hint to make PCMG more memory-efficient is appreciated.
>with warm regard, Abdul
>>________________________________
>> From: Jed Brown <jedbrown at mcs.anl.gov>
>>To: Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>; PETSc users list <petsc-users at mcs.anl.gov>
>>Sent: Thursday, 24 May 2012, 21:22
>>Subject: Re: [petsc-users] Multigrid Vcycle.
>>On Thu, May 24, 2012 at 2:14 PM, Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk> wrote:
>>Dear all,
>>>I am quit beginner in PETSc.
>>>I wrote a code for multigrid Vcycle (as preconditioer) by following the instructions on manual page.
>>>I want to see how much memory a Vcycle allocates by default in terms of number of matrices and vectors.
>>>I made a try to see by comparing with jacobi preconditioner, which surely allocates 1 vector ONLY.
>>>It turns out that a VCycle for FIVE (5) levels including coarsest level allocates memory for 53 vectors and
>>>subsequently it destroys too.
>>Some of those vectors are very small due to being on the coarse level. There are also the vectors used by the outer Krylov method.
>>>Is it normal ??
>>>Thanks in advance,
>>>Abdul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120524/d508e26a/attachment.html>
