[petsc-users] KSPBuildResidual in ex42.c
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed May 23 07:06:50 CDT 2012
On Wed, May 23, 2012 at 6:08 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> > > Yes, only the norms. As I understand now, GMRES will compute the
> > > norm of the total system residual [U,V,W,P], but I would like the
> > > norms of [U], [V], [W] and [P] residuals separated. Based on
> > > ex42, I got the impression that I have to use KSPBuildResidual.
> > Yes, the cost of building the residual (check -log_summary to see how big
> > it is) is a reason why people often avoid GMRES if they need the full
> > residual. It's directly available with GCR, for example (which is
> otherwise
> > similar in work to FGMRES) and with most of the non-residual-minimizing
> > methods.
> I find GCR to be less robust than FGMRES,
Right, it can break down in some cases that FGMRES does not.
> but ok, suppose I switch
> to GCR, how would I get the residual vector?
KSPBuildResidual(), but it's trivially fast with GCR.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120523/8075eb10/attachment.html>
