[petsc-users] petsc example with known scalability
    Matthew Knepley
    knepley at gmail.com
    Fri May 18 19:06:33 CDT 2012
On Fri, May 18, 2012 at 8:02 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Yes, I'm looking at weak scalability right now. I'm using BiCGSTAB with
> BoomerAMG (all default options except for rtol = 1e-12). I've not looked
> into MF/s yet but I'll surely do to see if I'm having any problem there. So
> far, just timing the KSPSolve, I get [0.231, 0.238, 0.296, 0.451, 0.599]
> seconds/KSP iteration for p=[1, 4, 16, 64, 256] with almost 93K nodes
> (matrix-row) per proc. Which is not bad I guess but still increased by a
> factor of 3 for 256 proc. Problem is, I don't know how good/bad this is. In
> fact I'm not even sure that is a valid question to ask since it may be very
> problem dependent.
> Something I just though about, how crucial is the matrix structure for KSP
> solvers? The nodes have bad numbering and I do partitioning to get a better
> one here.
Did you look at the number of iterates?
   Matt
> On Fri, May 18, 2012 at 4:47 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, May 18, 2012 at 7:43 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> I see; well that's a fair point. So i have my timing results obtained
>>> via -log_summary; what should I be looking into for MatMult? Should I be
>>> looking at wall timings? Or do I need to look into MFlops/s? I'm sorry but
>>> I'm not sure what measure I should be looking into to determine scalability.
>> Time is only meaningful in isolation if I know how big your matrix is,
>> but you obviously take the ratio to look how it is scaling. I am
>> assuming you are looking at weak scalability so it should remain
>> constant. MF/s will let you know how the routine is performing
>> independent of size, and thus is an easy way to see what is happening. It
>> should scale like P, and when that drops off you have
>> insufficient bandwidth. VecMDot is a good way to look at the latency of
>> reductions (assuming you use GMRES). There is indeed no
>> good guide to this. Barry should write one.
>>     Matt
>>>  Also, is there any general meaningful advice one could give? in terms
>>> of using the resources, compiler flags (beyond -O3), etc?
>>> Thanks,
>>> Mohammad
>>> On Fri, May 18, 2012 at 4:18 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, May 18, 2012 at 7:06 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>>> Hi guys,
>>>>> I'm trying to generate scalability plots for my code and do profiling
>>>>> and fine tuning. In doing so I have noticed that some of the factors
>>>>> affecting my results are sort of subtle. For example, I figured, the other
>>>>> day, that using all of the cores on a single node is somewhat (50-60%)
>>>>> slower when compared to using only half of the cores which I suspect is due
>>>>> to memory bandwidth and/or other hardware-related issues.
>>>>> So I thought to ask and see if there is any example in petsc that has
>>>>> been tested for scalability and has been documented? Basically I want to
>>>>> use this test example as a benchmark to compare my results with. My own
>>>>> test code is currently a linear Poisson solver on an adaptive quadtree grid
>>>>> and involves non-trivial geometry (well basically a circle for the boundary
>>>>> but still not a simple box).
>>>> Unfortunately, I do not even know what that means. We can't guarantee a
>>>> certain level of performance because it not
>>>> only depends on the hardware, but how you use it (as evident in your
>>>> case). In a perfect world, we would have an abstract
>>>> model of the computation (available for MatMult) and your machine (not
>>>> available anywhere) and we would automatically
>>>> work out the consequences and tell you what to expect. Instead today,
>>>> we tell you to look at a few key indicators like the
>>>> MatMult event, to see what is going on. When MatMult stops scaling, you
>>>> have run out of bandwidth.
>>>>     Matt
>>>>> Thanks,
>>>>> Mohammad
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120518/64764d49/attachment.htm>
