[petsc-users] Fwd: PCGASMSetLocalSubdomains
Tue May 15 11:20:28 CDT 2012
On Tue, May 15, 2012 at 10:11 AM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
> Yes, see Mandel & Dorhamann' paper
> http://ccm.ucdenver.edu/reports/rep194.pdf ,
BDDC needs to solve pinned Neumann problems to build the coarse space.
There is no way to obtain those Neumann problems from an assembled matrix,
and neither PCASM or PCGASM is set up to handle that.
There is a BDDC implementation from Stefano Zampini in petsc-dev, but the
code is still not mature so you have to configure --with-pcbddc to activate
it.
> but this is for non-overlapping. For overlapping we can see Leong &
> Widlund
> http://cs.nyu.edu/web/Research/TechReports/TR2008-914/TR2008-914.pdf
This solves non-overlapping Dirichlet problems to construct the coarse
basis, then uses overlapping Dirichlet problems for the smoother. Again,
these problems are different, so it's not useful to extract the subdomain
problems from PC(G)ASM.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120515/1c42faa8/attachment.htm>
