[petsc-users] Using direct solvers in parallel
Anton Popov popov at uni-mainz.de
Tue May 15 04:34:59 CDT 2012
On 5/15/12 9:25 AM, Thomas Witkowski wrote:
> I made some comparisons of using umfpack, superlu, superlu_dist and
> mumps to solve systems with sparse matrices arising from finite
> element method. The size of the matrices range from around 50000 to
> more than 3 million unknowns. I used 1, 2, 4, 8 and 16 nodes to make
> the benchmark. Now, I wonder that in all cases the sequential umfpack
> was the fastest one. So even with 16 cores, superlu_dist and mumps are
> slower. Can anybody of you confirm this observation? Are there any
> other parallel direct solvers around which are more efficient?
> Thomas
You should definitely try PARDISO. On shared memory machine is
unbeatable by any kind of MPI-based solver, and offers functionality for
both symmetric and non-symmetric matrices. There is a version available
from MKL library.
If you're fine enough with symmetric matrices, then this thing - HSL
MA87 - is even better than PARDISO. It's a commercial solver, but it's
free for academic use.
The only "problem" I see here is that both of them are difficult to use
together with PETSc, since they're OMP-based. But difficult probably
doesn't mean impossible.
Cheers,
Anton
