[petsc-users] Using direct solvers in parallel
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Tue May 15 02:54:56 CDT 2012
Am 15.05.2012 09:36, schrieb Dave May:
> I have seem similar behaviour comparing umfpack and superlu_dist,
> however the difference wasn't enormous, possibly umfpack was a factor
> of 1.2-1.4 times faster on 1 - 4 cores.
> What sort of time differences are you observing? Can you post the
> numbers somewhere?
I attached my data to this mail. For the largest matrix, umfpack failed
after allocating 4 GB of memory. I have not tried to figure out what's
the problem there. As you can see, for these matrices the distributed
solvers are slower by a factor of 2 or 3 compared to umfpack. For all
solvers, I have used the standard parameters, so I have not played
around with the permutation strategies and such things. This may be also
the reason why superlu is much slower than superlu_dist with just one
core as it makes use of different col and row permutation strategies.
> However, umpack will not work on a distributed memory machine.
> My personal preference is to use superlu_dist in parallel. In my
> experience using it as a coarse grid solver for multigrid, I find it
> much more reliable than mumps. However, when mumps works, its is
> typically slightly faster than superlu_dist. Again, not by a large
> amount - never more than a factor of 2 faster.
In my codes I also make use of the distributed direct solvers for the
coarse grid problems. I just wanted to make some tests how far away
these solvers are from the sequential counterparts.
Thomas
> The failure rate using mumps is definitely higher (in my experience)
> when running on large numbers of cores compared to superlu_dist. I've
> never got to the bottom as to why it fails.
> Cheers,
> Dave
> On 15 May 2012 09:25, Thomas Witkowski<thomas.witkowski at tu-dresden.de> wrote:
>> I made some comparisons of using umfpack, superlu, superlu_dist and mumps to
>> solve systems with sparse matrices arising from finite element method. The
>> size of the matrices range from around 50000 to more than 3 million
>> unknowns. I used 1, 2, 4, 8 and 16 nodes to make the benchmark. Now, I
>> wonder that in all cases the sequential umfpack was the fastest one. So even
>> with 16 cores, superlu_dist and mumps are slower. Can anybody of you confirm
>> this observation? Are there any other parallel direct solvers around which
>> are more efficient?
>> Thomas
#rows | umfpack / 1.core | superlu / 1.core | superlu_dist / 1.core | mumps / 1.core |
49923 | 0.644 | 4.914 | 2.148 | 1.731 |
198147 | 3.992 | 41.53 | 13.05 | 10.04 |
792507 | 32.33 | 463.5 | 66.75 | 52.56 |
3151975 | 4GB limit | - | 394.1 | 303.2 |
#rows | superlu_dist / 1.core | superlu_dist / 2.core | superlu_dist / 4.core | superlu_dist / 8.core | superlu_dist / 16.core |
49923 | 2.148 | 1.922 | 1.742 | 1.705 | 1.745 |
198147 | 13.05 | 11.77 | 10.47 | 9.832 | 9.565 |
792507 | 66.75 | 61.07 | 53.58 | 49.14 | 47.06 |
3151875 | 394.1 | failed | failed | failed | failed |
#rows | mumps / 1.core | mumps / 2.core | mumps / 4.core | mumps / 8.core | mumps / 16.core |
49923 | 1.731 | 1.562 | 1.485 | 1.426 | 1.418 |
198147 | 10.04 | 8.959 | 8.468 | 8.144 | 7.978 |
792507 | 52.56 | 45.38 | 42.56 | 40.22 | 39.12 |
3151875 | 303.2 | 255.7 | 232.2 | 216.0 | 210.0 |
