[petsc-users] Modifying the structure of a matrix.
Andrew Spott
andrew.spott at gmail.com
Mon May 14 23:07:19 CDT 2012
I'm attempting to do a convergence study on my basis, see how large my basis need to be to make my results accurate, does that help?
-Andrew
On May 14, 2012, at 9:55 PM, Shri wrote:
> What are you trying to do by removing the rows/columns of the matrix? Are there any variables that you want to treat as constants and hence eliminating the rows and columns?
> Shri
> On May 14, 2012, at 10:51 PM, Andrew Spott wrote:
>> Is there a computational cost to using a sparse matrix that is much bigger than it should be?
>> for example, say you have a matrix that is n x n, but you only store anything in the first m rows and columns (m < n).
>> Also, would you then have to redo the matrix distribution among nodes by hand, or will PETSC do it for you?
>> Thanks for the quick reply
>> -Andrew
>> On May 14, 2012, at 9:38 PM, Jed Brown wrote:
>>> On Mon, May 14, 2012 at 9:33 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
>>> What is the best way to selectively add/remove columns/rows of a Mat?
>>> Is there a way to do it in place, or does it require essentially moving the values to a new matrix?
>>> If you only need to add/remove a small number of values, it's best to allocate for all that might be present and just store explicit zeros.
>>> To add or remove rows, you are also changing the vector size that can be multiplied against, and the data structure must be rebuilt. This is why it's frequently preferable to use MatZeroRows (or a variant) instead of removing them from the data structure.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120514/9d54f416/attachment.htm>
