[petsc-users] How to set up -mat_mumps_icntl13 1 in the code?
Mon May 14 11:11:04 CDT 2012
On Mon, May 14, 2012 at 12:01 PM, Giacomo Mulas
<gmulas at oa-cagliari.inaf.it>wrote:
> Hello.
> I am relatively new to petsc and slepc. I am trying to use slepc to solve a
> sparse eigenvalue problem, in particular getting all eigenvalues in an
> interval (spectral slicing). To run in parallel, the documentation states
> that I have to specify an external linear solver, e.g. mumps, and explains
> that I can use the command line options
> -st_ksp_type preonly -st_pc_type cholesky \
> -st_pc_factor_mat_solver_**package mumps -mat_mumps_icntl_13 1
> to set everything up for it. I was indeed able to get my code to work with
> these command line options (even if I will need some additional work to
> make
> it run faster in parallel, but that's another story). However, I would
> rather like to be able to put these options in my code itself, as defaults.
The problems below are exactly why we do not advocate this strategy.
However, you
can get this effect using
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscOptionsSetValue.html
   Matt
> So far, I was able to do so for all command line options except for
> How should I do that? Here goes a snippet of the relevant code:
> (... omit creation/population of H matrix ...)
>      ierr = EPSCreate(mixpars->slepc_comm,**&eps);CHKERRQ(ierr);
>      ierr = EPSSetOperators(eps,H,PETSC_**NULL);CHKERRQ(ierr);
>      ierr = EPSSetProblemType(eps,EPS_HEP)**;CHKERRQ(ierr);
>      ierr = EPSSetTolerances(eps, tol, PETSC_DECIDE);
>      if (statesinlist>500)
>        ierr = EPSSetDimensions(eps, 500, PETSC_IGNORE, PETSC_IGNORE);
>      else
>        ierr = EPSSetDimensions(eps, statesinlist, PETSC_IGNORE,
>                                PETSC_IGNORE);
>      CHKERRQ(ierr);
>      if (statesinlist<50) ierr = EPSSetType(eps, EPSLAPACK);
>      else {
>        ierr = EPSGetST(eps,&st);CHKERRQ(**ierr);
>        ierr = STSetType(st,STSINVERT);**CHKERRQ(ierr);
>        ierr = STGetKSP(st,&ksp);CHKERRQ(**ierr);
>        ierr = KSPSetType(ksp,KSPPREONLY);
>        ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
>        ierr = PCSetType(pc, PCCHOLESKY);CHKERRQ(ierr);
>        if (mixpars->slepc_size>1) {
>          ierr = PCFactorSetMatSolverPackage(**pc,MATSOLVERMUMPS);CHKERRQ(*
> *ierr);
>          Mat F;
>          ierr = PCFactorGetMatrix(pc,&F);**CHKERRQ(ierr);
>          PetscInt icntl = 13;
>          PetscInt ival = 1;
>          ierr = MatMumpsSetIcntl(F,icntl,ival)**; CHKERRQ(ierr);
>      ierr = EPSSetFromOptions(eps); CHKERRQ(ierr);
>      ierr = EPSSetInterval(eps,
>                            (PetscScalar) currsubclass->lowtargetlimit[**
> j],
>                            (PetscScalar) currsubclass->uptargetlimit[j]**
>      CHKERRQ(ierr);
>      ierr = EPSSetWhichEigenpairs(eps, EPS_ALL); CHKERRQ(ierr);
>      ierr = EPSSolve(eps);CHKERRQ(ierr);
> The part which is commented out is what I tried to use to try to obtain the
> same effect as the -mat_mumps_icntl_13 1 command line option. However, if I
> decomment it, I get the following error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Operation done in wrong order!
> [0]PETSC ERROR: Matrix not yet factored; call after KSPSetUp() or
> PCSetUp()!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
> CDT 2011 [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> The code works fine if I comment out the lines from Mat F;
> to
> and use the command line option -mat_mumps_icntl_13 1
> Is it indeed possible to set this as a default in the code, and if yes, is
> it documented somewhere? Can someone give me a hint?
> A side issue: should I explicitly free the PC, KSP and ST I get using the
> EPSGetST(), STGetKSP() and KSPGetPC() calls respectively? I only use them to
> set up default options (instead of giving them on the command line). Or can
> I trust that EPSDestroy() will do it?
> Thanks in advance, bye
> Giacomo Mulas
> ______________________________**______________________________**_____
> Giacomo Mulas <gmulas at oa-cagliari.inaf.it>
> OSSERVATORIO ASTRONOMICO DI CAGLIARI
> Str. 54, Loc. Poggio dei Pini * 09012 Capoterra (CA)
> Tel. (OAC): +39 070 71180 248     Fax : +39 070 71180 222
> Tel. (UNICA): +39 070 675 4916
> "When the storms are raging around you, stay right where you are"
>                         (Freddy Mercury)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120514/d5b10427/attachment.htm>
