[petsc-users] seg fault with VecGetArray
Mohammad Mirzadeh mirzadeh at gmail.com
Sat May 12 03:37:04 CDT 2012
Also, if it matters, this is in serial. petsc version is petsc-dev and is
compiled with g++ and OpenMPI. Also, OpenMPI is NOT installed by PETSc
configure.
On Sat, May 12, 2012 at 1:33 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Hi guys,
> I'm having a really weird issue here! My code seg faults for certain
> problem size and after using gdb I have been able to pinpoint the problem
> to a VecGetArray call. Here's a series of things I have tried so far
> 1) -on_error_attach_debugger -----> unsuccessful; does not launch debugger
> 2) -start_in_debugger -------> unsuccessful; does not start debugger
> 3) attaching debugger myself -----> code runs in debugger and seg faults
> when calling VecGetArray
> 4) using ierr=VecGetArray;CHKERRQ(ierr) ------> PETSc does not produce
> error messages; the code simply seg faults and terminates
> 5) checking the values of ierr inside the debugger ---------> They are all
> 0 up untill the code terminates; I think this means petsc does not generate
> error?
> 6) checking for memory leak with valgrind -----------> All I get are leaks
> from OpenMPI and PetscInitialize and PetscFinalize; I think these are
> just routine and safe?
> What else can I try to find the problem? Any recommendation is really
> appreciated!
> Thanks,
> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120512/a22744fa/attachment.htm>
