[petsc-users] two-level Schwarz: PCMG or PCComposite
Fri May 11 11:24:10 CDT 2012
   Yes,  src/ksp/pc/impls/composite/composite.c
On May 11, 2012, at 8:21 AM, Hui Zhang wrote:
> On May 11, 2012, at 2:55 PM, Barry Smith wrote:
>> If this is what you want to do then just use the PCCOMPOSITE. Use PC_COMPOSITE_SYMMETRIC_MULTIPLICATIVE
>>  Barry
> Aha, I see.  Thank you, Barry!
> Just one more question on PCCompositeAddPC:  is firstly added PC also firstly applied,
> i.e. the order of applying PC's is the same as the order of PCCompositeAddPC ?
>> On May 11, 2012, at 6:26 AM, Hui Zhang wrote:
>>> I want to implement the two-level Schwarz method.  Let us denote P as the one-level
>>> Schwarz projection and P_0 as the coarse projection.  If I want the hybrid form of
>>> preconditioned system as follows:
>>>   (I-P_0) P (I-P_0)
>>> which is suitable:  PCMG or PCComposite?  It seems to me that PCComposite is good.
>>> But PCMG is not suitable because it can only implement the following form:
>>>   (I-P) P_0 (I-P)
>>> Any opinions?  Thanks!
