[petsc-users] Fwd: Re: Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Fri May 11 08:51:23 CDT 2012
On 11/5/2012 3:30 PM, Matthew Knepley wrote:
> On Fri, May 11, 2012 at 9:24 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I have been using the GUI environment to do debugging so I am a
>     bit reluctant to learn Valgrind as its outputs seems a bit
>     daunting.  But I guess John is right. I've been spending these few
>     days learning bit by bit.
>     I realised that the error occurs in computerhs, at:
> I bet this is a beautiful Fortranism. Do you include the F90 header
> file with the interface definition?
> If not, Fortran just craps out like this. I can't stress enough how
> much time would be saved by
> switching languages to something with at least a modicum of error
> checking.
I initially used:
#include "finclude/petsc.h90"
Compilation and linking was fine in Linux and vs2008.
Now I changed it to what ex22.F was using :
#include <finclude/petscsys.h>
#include <finclude/petscvec.h>
#include <finclude/petscmat.h>
#include <finclude/petscpc.h>
#include <finclude/petscksp.h>
#include <finclude/petscdmda.h>
Compiling was ok but linking failed in Linux and VS2008:
undefined reference to `dmdavecgetarrayf90_'
I tried changing #include <finclude/petscdmda.h> to #include
<finclude/petscdmda.h90> and everything was ok in VS2008 again, giving
the right answers.
However, in Linux, I got the following error:
[wtay at hpc12:tutorials]$ /opt/openmpi-1.5.3/bin/mpif90 -c  -fPIC -g
-I/home/wtay/Lib/petsc-3.2-dev_shared_debug/include
-I/opt/openmpi-1.5.3/include    -o ex29f.o ex29f.F90
/home/wtay/Lib/petsc-3.2-dev_shared_debug/include/finclude/ftn-custom/petscdmda.h90(25):
error #5082: Syntax error, found '::' when expecting one of: ( % : . = =>
         DMDABoundaryType :: pt
/home/wtay/Lib/petsc-3.2-dev_shared_debug/include/finclude/ftn-custom/petscdmda.h90(26):
         DMDAStencilType  :: st
error #6590: This statement is not permitted as a statement within a
derived-type-def
derived-type-def
ex29f.F90(68): error #6404: This name does not have a type, and must
have an explicit type.   [DMDA_BOUNDARY_NONE]
call
DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
have an explicit type.   [DMDA_STENCIL_STAR]
call
derived-type-def
derived-type-def
derived-type-def
derived-type-def
Is there some errors in petscdmda.h90?
>    Matt
>     *call DMDAVecRestoreArrayF90(da,b,array,ierr)*
>     ==27464== Invalid write of size 8
>     ==27464==    at 0x402835: computerhs_ (ex29f.F90:119)
>     ==27464==  Address 0xfffffffffffffef0 is not stack'd, malloc'd or
>     (recently) free'd
>     ==27464==
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>     Violation, probably memory access out of range
>     [0]PETSC ERROR: Try option -start_in_debugger or
>     -on_error_attach_debugger
>     [0]PETSC ERROR: or see
>     http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
>     ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
>     to find memory corruption errors
>     [0]PETSC ERROR: likely location of problem given in stack below
>     [0]PETSC ERROR: ---------------------  Stack Frames
>     [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>     available,
>     [0]PETSC ERROR:       INSTEAD the line number of the start of the
>     function
>     [0]PETSC ERROR:       is given.
>     [0]PETSC ERROR: [0] DM user function line 0 unknownunknown
>     [0]PETSC ERROR: [0] DMComputeFunction line 2085
>     /home/wtay/Codes/petsc-dev/src/dm/interface/dm.c
>     [0]PETSC ERROR: [0] KSPSetUp line 182
>     /home/wtay/Codes/petsc-dev/src/ksp/ksp/interface/itfunc.c
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Signal received!
>     I have checked that "array" 's values are correct. This statement
>     executed without problems in VS2008. If I replace the above with
>     something like:
>     *call VecSet(b,Hy,ierr)*
>     Everything is fine in Linux.
>     Is there something wrong with *DMDAVecRestoreArrayF90*?
>     My code in the area is:
>     call
>     DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>     call DMDAVecGetArrayF90(da,b,array,ierr)
>     do j = ys,ys+ym-1
>         do i = xs,xs+xm-1
>             array(i,j) =
>     exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>         end do
>     end do
>     call VecAssemblyBegin(b,ierr)
>     call VecAssemblyEnd(b,ierr)
>     Yours sincerely,
>     TAY wee-beng
>     On 8/5/2012 9:41 PM, John Mousel wrote:
>>     TAY wee-bing,
>>     If you want to be a programmer that writes interesting and
>>     reliable code, you need to be willing to use the tools of the
>>     trade. I can't think of a bigger time-saver than Valgrind. I
>>     would suggest that you learn to use it and use it a lot. I bet it
>>     will lead you to the root of your problem pretty quickly.
>>     John
>>     On Tue, May 8, 2012 at 2:17 PM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         I compiled and run my code under visual studio 2008 with
>>         intel fortran. Everything works ok.
>>         However, when I tried to run the code in linux, I got the
>>         error as below. The error happens when KSPSetUp(ksp,ierr) is
>>         called.
>>         However, I am not able to print VecView or MatView to view if
>>         there's any errors. Is there any recommendation for
>>         debugging? I hope I do not need to valgrind if possible.
>>         [0]PETSC ERROR:
>>         OS X to find memory corruption errors
>>         not available,
>>         the function
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: Petsc Development HG revision:
>>         7ecdd63ec420b1659b960e65d96e822c5ac1a968  HG Date: Mon May 07
>>         21:42:26 2012 -0500
>>         [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>         [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>         shooting.
>>         [0]PETSC ERROR: See docs/index.html for manual pages.
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: ./ex29f on a petsc-3.2 named hpc12 by wtay
>>         Tue May  8 20:45:42 2012
>>         [0]PETSC ERROR: Libraries linked from
>>         /home/wtay/Lib/petsc-3.2-dev_shared_debug/lib
>>         [0]PETSC ERROR: Configure run at Tue May  8 10:47:59 2012
>>         [0]PETSC ERROR: Configure options
>>         --with-mpi-dir=/opt/openmpi-1.5.3/
>>         --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/
>>         --with-debugging=1 --download-hypre=1
>>         --prefix=/home/wtay/Lib/petsc-3.2-dev_shared_debug
>>         --known-mpi-shared=1 --with-shared-libraries
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: User provided function() line 0 in unknown
>>         directory unknown file
>>         MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>         with errorcode 59.
>>         NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>         processes.
>>         You may or may not see output from other processes, depending on
>>         exactly when Open MPI kills them.
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 5/5/2012 1:43 AM, Matthew Knepley wrote:
>>>         On Fri, May 4, 2012 at 5:42 PM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             I wonder if you people are interested to include my ex29
>>>             fortran version in the petsc examples, which can help
>>>             people who are using fortran.
>>>         Yes, we will definitely include it. Please send the source,
>>>         and a representative output with run options.
>>>           Thanks,
>>>              Matt
>>>             Thanks.
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>             On 4/5/2012 9:28 PM, Matthew Knepley wrote:
>>>>             On Fri, May 4, 2012 at 3:24 PM, TAY wee-beng
>>>>                 On 4/5/2012 9:16 PM, Barry Smith wrote:
>>>>                        Do an hg pull and then run make in
>>>>                     src/mat/interface/ftn-custom/
>>>>                         Then it should link.
>>>>                        Barry
>>>>                        There was a E missing from the all caps name
>>>>                     of the function.
>>>>                 After hg pull, I did:
>>>>                 cd src//mat/interface/ftn-custom/
>>>>                 User at User-PC
>>>>                 /cygdrive/c/temp/petsc-dev/src/mat/interface/ftn-custom
>>>>                 $ make
>>>>                 make[1]: Warning: File
>>>>                 `/cygdrive/c/temp/petsc-dev/petsc-3.2-dev_win32_vs2008/lib/libpetsc.lib(zmatregf.o)'
>>>>                 has modification time 787 s in the future
>>>>                 make[1]: Nothing to be done for `libc'.
>>>>                 make[1]: warning:  Clock skew detected.  Your build
>>>>                 may be incomplete.
>>>>                 But it still can't work.
>>>>             Something is messed up with the clock on this machine.
>>>>             HOWEVER, development requires certain basic skills in
>>>>             order to debug your work. We
>>>>             cannot be the ones debugging your code. Now
>>>>               nm $PETSC_ARCH/lib/libpetsc.a | grep -i
>>>>             MatNullSpaceRemove
>>>>              will look for the symbol.
>>>>                 Matt
>>>>                     On May 4, 2012, at 2:11 PM, Matthew Knepley wrote:
>>>>                         On Fri, May 4, 2012 at 3:01 PM, TAY
>>>>                         wee-beng<zonexo at gmail.com
>>>>                         On 4/5/2012 5:17 PM, Matthew Knepley wrote:
>>>>                             On Fri, May 4, 2012 at 11:05 AM, TAY
>>>>                             On 4/5/2012 3:05 PM, Matthew Knepley wrote:
>>>>                                 On Fri, May 4, 2012 at 8:59 AM, TAY
>>>>                                 Hi,
>>>>                                 Is there anything else I can try to
>>>>                                 get it working right?
>>>>                                 The MatGetNullSpaceRemove() is missing.
>>>>                             Where should I add
>>>>                             MatGetNullSpaceRemove and what are its
>>>>                             syntax? I googled but there's no results.
>>>>                             Fixed in p;etsc-dev:
>>>>                             http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatNullSpaceRemove.html
>>>>                         I just compiled the updated petsc-dev but I
>>>>                         got the same error msg when I use:
>>>>                         call
>>>>                         MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>>                         error LNK2019: unresolved external symbol
>>>>                         MATNULLSPACEREMOVE referenced in function
>>>>                         COMPUTERHS
>>>>                         1>c:\obj_tmp\ex29f\Debug\ex29f.exe : fatal
>>>>                         error LNK1120: 1 unresolved externals
>>>>                         That function is in:
>>>>                           src/mat/interface/ftn-custom/zmatrixf.c
>>>>                         Did that compile? Can you see the symbol in
>>>>                         libpetsc.a?
>>>>                             Matt
>>>>                                  Matt
>>>>                             Thanks.
>>>>                                    Matt
>>>>                                 Thanks!
>>>>                                 On 2/5/2012 10:11 PM, Matthew
>>>>                                 Knepley wrote:
>>>>                                     On Wed, May 2, 2012 at 1:55 PM,
>>>>                                     TAY wee-beng<zonexo at gmail.com
>>>>                                     Hi,
>>>>                                     I did a MatView and VecView on
>>>>                                     both C and Fortran, right after
>>>>                                     Mat and Vec assembly. I have
>>>>                                     attached the printout below.
>>>>                                     They are exactly the same, but
>>>>                                     yet the result is different in
>>>>                                     Neumann condition. However, the
>>>>                                     dirichlet condition gives the
>>>>                                     correct ans. Is there anything
>>>>                                     else that could be wrong even
>>>>                                     if the Mat and Vec are the same?
>>>>                                     Did you set the null space for
>>>>                                     the matrix when you have
>>>>                                     Neumann conditions?
>>>>                                 Yes, for the matrix, I set as:
>>>>                                 call
>>>>                                 MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL_OBJECT,nullspace,ierr)
>>>>                                     call
>>>>                                 MatSetNullSpace(jac,nullspace,ierr)
>>>>                                     call
>>>>                                 MatNullSpaceDestroy(nullspace,ierr)
>>>>                                 for the Vec,
>>>>                                 call
>>>>                                     !call
>>>>                                     call
>>>>                                 MatNullSpaceRemove was comment out
>>>>                                 because there's error during linking
>>>>                                        Matt
>>>>                                     Thanks!
>>>>                                     Fortran:
>>>>                                     Matrix Object: 1 MPI processes
>>>>                                       type: seqaij
>>>>                                     row 0: (0, 2)  (1, -1)  (3, -1)
>>>>                                     row 1: (0, -1)  (1, 3)  (2, -1)
>>>>                                      (4, -1)
>>>>                                     row 2: (1, -1)  (2, 2)  (5, -1)
>>>>                                     row 3: (0, -1)  (3, 3)  (4, -1)
>>>>                                      (6, -1)
>>>>                                     row 4: (1, -1)  (3, -1)  (4, 4)
>>>>                                      (5, -1)  (7, -1)
>>>>                                     row 5: (2, -1)  (4, -1)  (5, 3)
>>>>                                      (8, -1)
>>>>                                     row 6: (3, -1)  (6, 2)  (7, -1)
>>>>                                     row 7: (4, -1)  (6, -1)  (7, 3)
>>>>                                      (8, -1)
>>>>                                     row 8: (5, -1)  (7, -1)  (8, 2)
>>>>                                     Vector
>>>>                                     Object:Vec_0000000084000000_0 1
>>>>                                     MPI processes
>>>>                                       type: mpi
>>>>                                     Process [0]
>>>>                                     0.25
>>>>                                     0.0205213
>>>>                                     1.135e-005
>>>>                                     0.0205213
>>>>                                     0.00168449
>>>>                                     9.31663e-007
>>>>                                     1.135e-005
>>>>                                     9.31663e-007
>>>>                                     5.15289e-010
>>>>                                     Vector
>>>>                                     Object:Vec_0000000084000000_1 1
>>>>                                     MPI processes
>>>>                                       type: mpi
>>>>                                     Process [0]
>>>>                                     0.14924
>>>>                                     0.0242397
>>>>                                     -0.0260347
>>>>                                     0.0242397
>>>>                                     -0.0256192
>>>>                                     -0.0400102
>>>>                                     -0.0260347
>>>>                                     -0.0400102
>>>>                                     -0.0400102
>>>>                                     Press any key to continue . . .
>>>>                                     C:
>>>>                                       type: seqaij
>>>>                                      (4, -1)
>>>>                                      (6, -1)
>>>>                                      (5, -1)  (7, -1)
>>>>                                      (8, -1)
>>>>                                      (8, -1)
>>>>                                     Vector Object:Vec_0x1d3b000_0 1
>>>>                                     MPI processes
>>>>                                       type: mpi
>>>>                                     Process [0]
>>>>                                     0.25
>>>>                                     0.0205212
>>>>                                     1.135e-05
>>>>                                     0.0205212
>>>>                                     0.00168449
>>>>                                     9.31663e-07
>>>>                                     1.135e-05
>>>>                                     9.31663e-07
>>>>                                     5.15288e-10
>>>>                                     Vector Object:Vec_0x1d3b000_1 1
>>>>                                     MPI processes
>>>>                                       type: mpi
>>>>                                     Process [0]
>>>>                                     0.139311
>>>>                                     0.0305751
>>>>                                     -0.0220633
>>>>                                     0.0305751
>>>>                                     -0.0135158
>>>>                                     -0.042185
>>>>                                     -0.0220633
>>>>                                     -0.042185
>>>>                                     -0.058449
>>>>                                     Yours sincerely,
>>>>                                     TAY wee-beng
>>>>                                     On 1/5/2012 11:54 PM, Matthew
>>>>                                     Knepley wrote:
>>>>                                         On Tue, May 1, 2012 at 5:48
>>>>                                         PM, TAY
>>>>                                          wrote:
>>>>                                         Hi,
>>>>                                         Do you mean my method is wrong?
>>>>                                         I am following the template
>>>>                                         of ex22f,
>>>>                                         where the variables are
>>>>                                         declared as :
>>>>                                         PetscScalar  v(5)
>>>>                                         MatStencil   row(4),col(4,5)
>>>>                                         Hence,
>>>>                                         for the neumann BC
>>>>                                         num = 1
>>>>                                                        if (j/=0) then
>>>>                                                            v(num) =
>>>>                                         -rho*HxdHy
>>>>                                          col(MatStencil_i,num) = i
>>>>                                          col(MatStencil_j,num) = j-1
>>>>                                                            num =
>>>>                                         num + 1
>>>>                                                        end if
>>>>                                                        if (i/=0) then
>>>>                                                            v(num) =
>>>>                                         -rho*HydHx
>>>>                                          col(MatStencil_i,num) = i-1
>>>>                                                            num =
>>>>                                         num + 1
>>>>                                                        end if
>>>>                                                        if (i/=mx-1)
>>>>                                         then
>>>>                                                            v(num) =
>>>>                                         -rho*HydHx
>>>>                                          col(MatStencil_i,num) = i+1
>>>>                                                            num =
>>>>                                         num + 1
>>>>                                                        end if
>>>>                                                        if (j/=my-1)
>>>>                                         then
>>>>                                                            v(num) =
>>>>                                         -rho*HxdHy
>>>>                                          col(MatStencil_j,num) = j+1
>>>>                                                            num =
>>>>                                         num + 1
>>>>                                                        end if
>>>>                                                        v(num) =
>>>>                                         ((num-1)/2.0)*rho*(HxdHy +
>>>>                                         HydHx)
>>>>                                                        print *, v
>>>>                                                        !num = num + 1
>>>>                                                        call
>>>>                                         MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
>>>>                                         I do not get any more out
>>>>                                         of range error. However,my
>>>>                                         ans is still different from
>>>>                                         that of ex29 in C.
>>>>                                         This is very simple. You
>>>>                                         have an error in your code.
>>>>                                         Checking it is very simple:
>>>>                                         run the code and
>>>>                                         break in MatSetValues().
>>>>                                         Make sure ex29 makes calls
>>>>                                         with exactly the same
>>>>                                         indices as your ex29f.
>>>>                                             Matt
>>>>                                         Yours sincerely,
>>>>                                         TAY wee-beng
>>>>                                         What most experimenters
>>>>                                         take for granted before
>>>>                                         they begin their
>>>>                                         experiments is infinitely
>>>>                                         more interesting than any
>>>>                                         results to which their
>>>>                                         experiments lead.
>>>>                                         -- Norbert Wiener
>>>>                                     What most experimenters take
>>>>                                     for granted before they begin
>>>>                                     their experiments is infinitely
>>>>                                     experiments lead.
>>>>                                     -- Norbert Wiener
>>>>                                 What most experimenters take for
>>>>                                 granted before they begin their
>>>>                                 experiments is infinitely more
>>>>                                 interesting than any results to
>>>>                                 which their experiments lead.
>>>>                                 -- Norbert Wiener
>>>>                             interesting than any results to which
>>>>                             -- Norbert Wiener
>>>>                         What most experimenters take for granted
>>>>                         before they begin their experiments is
>>>>                         infinitely more interesting than any
>>>>                         results to which their experiments lead.
>>>>                         -- Norbert Wiener
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120511/7cf300cb/attachment-0001.htm>
