[petsc-users] PCGASMSetLocalSubdomains
Dmitry Karpeev karpeev at mcs.anl.gov
Thu May 10 11:37:54 CDT 2012
Hui,
There've been several changes to PCGASM ahead of the new release.
Let me go back and see if it affected the convergence problem.
Dmitry.
On Thu, May 10, 2012 at 4:16 AM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
> Hi Dmitry,
> is there any news about PCGASM?
> thanks,
> Hui
> On Feb 20, 2012, at 6:38 PM, Dmitry Karpeev wrote:
> Okay, thanks.
> I'll take a look.
> Dmitry.
> On Mon, Feb 20, 2012 at 11:30 AM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
>> For reference, my results are attached.
>> asm1.txt for asm with 1 process,
>> asm2.txt for asm with 2 processes,
>> gasm1.txt for gasm with 1 process, (with the iteration numbers different
>> from others)
>> gasm2.txt for gasm with 2 processes
>> thank you,
>> Hui
>> On Feb 20, 2012, at 3:06 PM, Dmitry Karpeev wrote:
>> On Mon, Feb 20, 2012 at 12:59 AM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
>>> On Feb 20, 2012, at 12:41 AM, Dmitry Karpeev wrote:
>>> On Sun, Feb 19, 2012 at 3:08 PM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
>>>> I have a new problem: the results from ASM and GASM are different and
>>>> it seems
>>>> GASM has something wrong with SetModifySubMatrices. Numerical tests are
>>>> with
>>>> each subdomain supported only by one subdomain. There are no problems
>>>> when
>>>> I did not modify submatrices.  But when I modify submatrices, there are
>>>> problems
>>>> with GASM but no problems with ASM.
>>>> For example, I use two subdomains. In the first case each subdomain is
>>>> supported by
>>>> one processor and there seems no problem with GASM. But when I use run
>>>> my program
>>>> with only one proc. so that it supports both of the two subdomains, the
>>>> iteration
>>>> number is different from the first case and is much larger.  On the
>>>> other hand
>>>> ASM has no such problem.
>>> Are the solutions the same?
>>> What problem are you solving?
>>> Yes, the solutions are the same. That's why ASM gives the same results
>>> with one or
>>> two processors. But GASM did not.
>> Sorry, I wasn't clear: ASM and GASM produced different solutions in the
>> case of two domains per processor?
>>> I'm solving the Helmholtz equation.  Maybe
>>> I can prepare a simpler example to show this difference.
>> That would be helpful.
>> Thanks.
>> Dmitry.
>>> Dmitry.
>>>> On Feb 15, 2012, at 6:46 PM, Dmitry Karpeev wrote:
>>>> You should be able to.
>>>> This behavior is the same as in PCASM,
>>>> except in GASM the matrices live on subcommunicators.
>>>> I am in transit right now, but I can take a closer look in Friday.
>>>> Dmitry
>>>> On Feb 15, 2012, at 8:07, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
>>>> On Feb 15, 2012, at 11:19 AM, Hui Zhang wrote:
>>>> Hi Dmitry,
>>>> thanks a lot! Currently, I'm not using ISColoring. Just comes another
>>>> question
>>>> on PCGASMSetModifySubMatrices(). The user provided function has the
>>>> prototype
>>>> func (PC pc,PetscInt nsub,IS *row,IS *col,Mat *submat,void *ctx);
>>>> I think the coloumns from the parameter 'col' are always the same as
>>>> the rows
>>>> from the parameter 'row'. Because PCGASMSetLocalSubdomains() only
>>>> accepts
>>>> index sets but not rows and columns. Has I misunderstood something?
>>>> As I tested, the row and col are always the same.
>>>> I have a new question. Am I allowed to SetLocalToGlobalMapping() for
>>>> the submat's
>>>> in the above func()?
>>>> thanks,
>>>> Hui
>>>> thanks,
>>>> Hui
>>>> On Feb 11, 2012, at 3:36 PM, Dmitry Karpeev wrote:
>>>> Yes, that's right.
>>>> There is no good way to help the user assemble the subdomains at the
>>>> moment beyond the 2D stuff.
>>>> It is expected that they are generated from mesh subdomains.
>>>> Each IS does carry the subdomains subcomm.
>>>> There is ISColoringToList() that is supposed to convert a "coloring" of
>>>> indices to an array of ISs,
>>>> each having the indices with the same color and the subcomm that
>>>> supports that color. It is
>>>> largely untested, though.  You could try using it and give us feedback
>>>> on any problems you encounter.
>>>> Dmitry.
>>>> On Sat, Feb 11, 2012 at 6:06 AM, Hui Zhang <<mike.hui.zhang at hotmail.com>
>>>>> About PCGASMSetLocalSubdomains(), in the case of one subdomain
>>>>> supported by
>>>>> multiple processors, shall I always create the arguments 'is[s]' and
>>>>> 'is_local[s]'
>>>>> in a subcommunicator consisting of processors supporting the subdomain
>>>>> 's'?
>>>>> The source code of PCGASMCreateSubdomains2D() seemingly does so.
>>>>> Thanks,
>>>>> Hui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120510/8b4dfb2b/attachment.htm>
