[petsc-users] petsc4py and numpy
Lisandro Dalcin
dalcinl at gmail.com
Tue May 8 10:15:19 CDT 2012
On 8 May 2012 12:04, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 8, 2012 at 11:00 AM, Christian Staudt
>> a) Is there an easy and efficient way to convert a numpy.ndarray to a
>> PETSc.Vec or PETSc.Mat (and vice-versa)? (A PETSc.Vec.getArray() returns
>> a
>> numpy.ndarray, though I have found no such method for PETSc.Mat yet. )
>> If you are using dense matrices (MATDENSE) then MatGetArray() works.
>> I don't think this is implemented in petsc4py: At least, there's no method
>> PETSc.Mat.getArray()
> If you ask Lisandro for it, he will put it in.
Matt, I've never put that in just because I'm not sure how to make it
general. PETSc have many different matrix formats, and MatGetArray()
call is like a hack, where you can get very different things (the "1D"
values of an AIJ matrix, the "2D" values of a dense matrix in Fortran
order). What about MPIAIJ, what should I return to users? Can you
suggest some approach or API to implement this (I mean, how to get
arrays for the various matrix types)?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
