[petsc-users] clarification of SNES / FormFunction
Dominik Szczerba dominik at itis.ethz.ch
Tue May 8 08:04:20 CDT 2012
> Newton-based SNES solves for snes->vec_sol_update, but evaluates at
> snes->vec_sol and using another vector inside the line search.
> If you are writing code that depends on the Vec being the same, you're doing
> it wrong.
I am currently assuming they are different and am using the "x" from
the signature to set up my A(x) and b(x). I was thinking if they are
the same (i.e. corresponding to x_n in the Newton method), I could
significantly simplify my code. But apparently "x" in the signature is
not simply x_n because of the involved line search, correct me if I am
wrong.
Dominik
