[petsc-users] petsc gcc intel and compilerflags
Manfred Gratt
manfred.gratt at uibk.ac.at
Tue May 8 02:32:55 CDT 2012
Hello,
when I compile petsc with --with-debugging=0 with gcc and icc in
configure there are different optimization flags set depending on
compiler. So is with gcc -O set wich means -O1 optimization. While with
icc -O3 optimisation is set. Is there a reason only icc gets the high
performance flag while gcc not? Are there any problems when some
optimizations are activated on gcc?
with greetings
Manfred
