[petsc-users] application of petsc to psr
    Alan Sayre
    ansayre at sbcglobal.net
    Fri May  4 19:38:24 CDT 2012
Barry,
Sorry for being imprecise. I haven't started coding anything yet with PETSc. I
have only tried the native SUNDIALS Kinsol. I have had good success using the
SUNDIALS Cvode for zero-d ode using the ABF mechanism. My purpose in posting is
to determine if the PETSc suite of tools is appropriate, there is experience
using solving similar problems, etc.
Alan
To: PETSc users list <petsc-users at mcs.anl.gov>
Sent: Fri, May 4, 2012 7:06:33 PM
Subject: Re: [petsc-users] application of petsc to psr
  Alan,
    You have a very complicated model (and presumably discretization) which
makes it difficult for us to provide coherent advice. What stage are you in your
code at using PETSc? Are you thinking about using PETSc?  Have you not started
yet? Is it running but not converging with PETSc?  There are many reasons that
Newton may not converge: see
http://www.mcs.anl.gov/petsc/documentation/faq.html#newton
  Barry
On May 3, 2012, at 8:02 PM, Alan Sayre wrote:
> Barry,
> Thanks but that is not quite what I have in mind. The existing PSR model in my
>CFD code is not converging for PSR models containing the Method of Moments using
>the ABF mechanism described as shown in the Chemkin 2006 workshop proceedings. I
>have tried KINSOL and have still not been able to get it to converge. Any
>assistance in developing a PETSC based solution algorithm is appreciated.
> thanks,
> Alan
> From: Barry Smith <bsmith at mcs.anl.gov>
> Sent: Wed, May 2, 2012 10:54:21 PM
>http://www.sandia.gov/chemkin/workshop/proceedings/Meeks_CHEMKINWorkshop2006.pdf
> On May 2, 2012, at 9:45 PM, Alan Sayre wrote:
> > I'm new to using PETSc. I need to model perfectly stirred reactors for
>chemical kinetics (10-1000 species), I welcome recommendations on how to get
>"up-to-speed". I also need to incorprate solution of the energy (temperature)
>equation and moments of soot distributions.
> > Thanks for any suggestions.
> > Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120504/29253efb/attachment.htm>
