[petsc-users] Fwd: Re: Problem with fortran version of ex29 in ksp
Matthew Knepley
knepley at gmail.com
Fri May 4 18:43:43 CDT 2012
On Fri, May 4, 2012 at 5:42 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I wonder if you people are interested to include my ex29 fortran version
> in the petsc examples, which can help people who are using fortran.
Yes, we will definitely include it. Please send the source, and a
representative output with run options.
Matt
> Thanks.
> Yours sincerely,
> TAY wee-beng
> On 4/5/2012 9:28 PM, Matthew Knepley wrote:
> On Fri, May 4, 2012 at 3:24 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> On 4/5/2012 9:16 PM, Barry Smith wrote:
>>> Do an hg pull and then run make in src/mat/interface/ftn-custom/
>>> Then it should link.
>>> Barry
>>> There was a E missing from the all caps name of the function.
>> After hg pull, I did:
>> cd src//mat/interface/ftn-custom/
>> User at User-PC /cygdrive/c/temp/petsc-dev/src/mat/interface/ftn-custom
>> $ make
>> make[1]: Warning: File
>> `/cygdrive/c/temp/petsc-dev/petsc-3.2-dev_win32_vs2008/lib/libpetsc.lib(zmatregf.o)'
>> has modification time 787 s in the future
>> make[1]: Nothing to be done for `libc'.
>> make[1]: warning: Clock skew detected. Your build may be incomplete.
>> But it still can't work.
> Something is messed up with the clock on this machine.
> HOWEVER, development requires certain basic skills in order to debug
> your work. We
> cannot be the ones debugging your code. Now
> nm $PETSC_ARCH/lib/libpetsc.a | grep -i MatNullSpaceRemove
> will look for the symbol.
> Matt
>>> On May 4, 2012, at 2:11 PM, Matthew Knepley wrote:
>>> On Fri, May 4, 2012 at 3:01 PM, TAY wee-beng<zonexo at gmail.com> wrote:
>>>> On 4/5/2012 5:17 PM, Matthew Knepley wrote:
>>>>> On Fri, May 4, 2012 at 11:05 AM, TAY wee-beng<zonexo at gmail.com>
>>>>> wrote:
>>>>> On 4/5/2012 3:05 PM, Matthew Knepley wrote:
>>>>>> On Fri, May 4, 2012 at 8:59 AM, TAY wee-beng<zonexo at gmail.com>
>>>>>> wrote:
>>>>>> Hi,
>>>>>> Is there anything else I can try to get it working right?
>>>>>> The MatGetNullSpaceRemove() is missing.
>>>>> Where should I add MatGetNullSpaceRemove and what are its syntax? I
>>>>> googled but there's no results.
>>>>> Fixed in p;etsc-dev:
>>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatNullSpaceRemove.html
>>>> I just compiled the updated petsc-dev but I got the same error msg when
>>>> I use:
>>>> call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>> error LNK2019: unresolved external symbol MATNULLSPACEREMOVE referenced
>>>> in function COMPUTERHS
>>>> 1>c:\obj_tmp\ex29f\Debug\ex29f.exe : fatal error LNK1120: 1 unresolved
>>>> externals
>>>> That function is in:
>>>> src/mat/interface/ftn-custom/zmatrixf.c
>>>> Did that compile? Can you see the symbol in libpetsc.a?
>>>> Matt
>>>> Matt
>>>>> Thanks.
>>>>>> Matt
>>>>>> Thanks!
>>>>>> On 2/5/2012 10:11 PM, Matthew Knepley wrote:
>>>>>>> On Wed, May 2, 2012 at 1:55 PM, TAY wee-beng<zonexo at gmail.com>
>>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> I did a MatView and VecView on both C and Fortran, right after Mat
>>>>>>> and Vec assembly. I have attached the printout below. They are exactly the
>>>>>>> same, but yet the result is different in Neumann condition. However, the
>>>>>>> dirichlet condition gives the correct ans. Is there anything else that
>>>>>>> could be wrong even if the Mat and Vec are the same?
>>>>>>> Did you set the null space for the matrix when you have Neumann
>>>>>>> conditions?
>>>>>> Yes, for the matrix, I set as:
>>>>>> call
>>>>>> MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL_OBJECT,nullspace,ierr)
>>>>>> call MatSetNullSpace(jac,nullspace,ierr)
>>>>>> call MatNullSpaceDestroy(nullspace,ierr)
>>>>>> for the Vec,
>>>>>> call
>>>>>> !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>>>> MatNullSpaceRemove was comment out because there's error during
>>>>>> linking
>>>>>> Matt
>>>>>>> Thanks!
>>>>>>> Fortran:
>>>>>>> Matrix Object: 1 MPI processes
>>>>>>> type: seqaij
>>>>>>> row 0: (0, 2) (1, -1) (3, -1)
>>>>>>> row 1: (0, -1) (1, 3) (2, -1) (4, -1)
>>>>>>> row 2: (1, -1) (2, 2) (5, -1)
>>>>>>> row 3: (0, -1) (3, 3) (4, -1) (6, -1)
>>>>>>> row 4: (1, -1) (3, -1) (4, 4) (5, -1) (7, -1)
>>>>>>> row 5: (2, -1) (4, -1) (5, 3) (8, -1)
>>>>>>> row 6: (3, -1) (6, 2) (7, -1)
>>>>>>> row 7: (4, -1) (6, -1) (7, 3) (8, -1)
>>>>>>> row 8: (5, -1) (7, -1) (8, 2)
>>>>>>> Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 0.25
>>>>>>> 0.0205213
>>>>>>> 1.135e-005
>>>>>>> 0.0205213
>>>>>>> 0.00168449
>>>>>>> 9.31663e-007
>>>>>>> 1.135e-005
>>>>>>> 9.31663e-007
>>>>>>> 5.15289e-010
>>>>>>> Vector Object:Vec_0000000084000000_1 1 MPI processes
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 0.14924
>>>>>>> 0.0242397
>>>>>>> -0.0260347
>>>>>>> 0.0242397
>>>>>>> -0.0256192
>>>>>>> -0.0400102
>>>>>>> -0.0260347
>>>>>>> -0.0400102
>>>>>>> -0.0400102
>>>>>>> Press any key to continue . . .
>>>>>>> C:
>>>>>>> type: seqaij
>>>>>>> Vector Object:Vec_0x1d3b000_0 1 MPI processes
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 0.25
>>>>>>> 0.0205212
>>>>>>> 1.135e-05
>>>>>>> 0.0205212
>>>>>>> 0.00168449
>>>>>>> 9.31663e-07
>>>>>>> 1.135e-05
>>>>>>> 9.31663e-07
>>>>>>> 5.15288e-10
>>>>>>> Vector Object:Vec_0x1d3b000_1 1 MPI processes
>>>>>>> type: mpi
>>>>>>> Process [0]
>>>>>>> 0.139311
>>>>>>> 0.0305751
>>>>>>> -0.0220633
>>>>>>> 0.0305751
>>>>>>> -0.0135158
>>>>>>> -0.042185
>>>>>>> -0.0220633
>>>>>>> -0.042185
>>>>>>> -0.058449
>>>>>>> Yours sincerely,
>>>>>>> TAY wee-beng
>>>>>>> On 1/5/2012 11:54 PM, Matthew Knepley wrote:
>>>>>>>> On Tue, May 1, 2012 at 5:48 PM, TAY wee-beng<zonexo at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> Do you mean my method is wrong?
>>>>>>>> I am following the template of ex22f,
>>>>>>>> where the variables are declared as :
>>>>>>>> PetscScalar v(5)
>>>>>>>> MatStencil row(4),col(4,5)
>>>>>>>> Hence,
>>>>>>>> for the neumann BC
>>>>>>>> num = 1
>>>>>>>> if (j/=0) then
>>>>>>>> v(num) = -rho*HxdHy
>>>>>>>> col(MatStencil_i,num) = i
>>>>>>>> col(MatStencil_j,num) = j-1
>>>>>>>> num = num + 1
>>>>>>>> end if
>>>>>>>> if (i/=0) then
>>>>>>>> v(num) = -rho*HydHx
>>>>>>>> col(MatStencil_i,num) = i-1
>>>>>>>> num = num + 1
>>>>>>>> end if
>>>>>>>> if (i/=mx-1) then
>>>>>>>> v(num) = -rho*HydHx
>>>>>>>> col(MatStencil_i,num) = i+1
>>>>>>>> num = num + 1
>>>>>>>> end if
>>>>>>>> if (j/=my-1) then
>>>>>>>> v(num) = -rho*HxdHy
>>>>>>>> col(MatStencil_j,num) = j+1
>>>>>>>> num = num + 1
>>>>>>>> end if
>>>>>>>> v(num) = ((num-1)/2.0)*rho*(HxdHy + HydHx)
>>>>>>>> print *, v
>>>>>>>> !num = num + 1
>>>>>>>> call
>>>>>>>> MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
>>>>>>>> I do not get any more out of range error. However,my ans is still
>>>>>>>> different from that of ex29 in C.
>>>>>>>> This is very simple. You have an error in your code. Checking it is
>>>>>>>> very simple: run the code and
>>>>>>>> break in MatSetValues(). Make sure ex29 makes calls with exactly
>>>>>>>> the same indices as your ex29f.
>>>>>>>> Matt
>>>>>>>> Yours sincerely,
>>>>>>>> TAY wee-beng
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120504/0f28dd9e/attachment-0001.htm>
