[petsc-users] Fwd: Re: Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Fri May 4 14:13:00 CDT 2012
On 4/5/2012 9:09 PM, John Mousel wrote:
> You have to pass PETSC_NULL_OBJECT instead of PETSC_NULL in Fortran.
> From the man pages:
> "This macro does not exist in Fortran; you must use
> PETSC_NULL_INTEGER, PETSC_NULL_DOUBLE_PRECISION, PETSC_NULL_FUNCTION,
> PETSC_NULL_OBJECT etc "
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PETSC_NULL.html#PETSC_NULL
> John
Thanks for the suggestion, but they all didn't work.
> On Fri, May 4, 2012 at 2:01 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 4/5/2012 5:17 PM, Matthew Knepley wrote:
>>     On Fri, May 4, 2012 at 11:05 AM, TAY wee-beng <zonexo at gmail.com
>>         On 4/5/2012 3:05 PM, Matthew Knepley wrote:
>>>         On Fri, May 4, 2012 at 8:59 AM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             Is there anything else I can try to get it working right?
>>>         The MatGetNullSpaceRemove() is missing.
>>         Where should I add MatGetNullSpaceRemove and what are its
>>         syntax? I googled but there's no results.
>>     Fixed in p;etsc-dev:
>>     http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatNullSpaceRemove.html
>     I just compiled the updated petsc-dev but I got the same error msg
>     when I use:
>     call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>     error LNK2019: unresolved external symbol MATNULLSPACEREMOVE
>     referenced in function COMPUTERHS
>     1>c:\obj_tmp\ex29f\Debug\ex29f.exe : fatal error LNK1120: 1
>     unresolved externals
>>          Matt
>>         Thanks.
>>>            Matt
>>>             Thanks!
>>>             On 2/5/2012 10:11 PM, Matthew Knepley wrote:
>>>>             On Wed, May 2, 2012 at 1:55 PM, TAY wee-beng
>>>>                 Hi,
>>>>                 I did a MatView and VecView on both C and Fortran,
>>>>                 right after Mat and Vec assembly. I have attached
>>>>                 the printout below. They are exactly the same, but
>>>>                 yet the result is different in Neumann condition.
>>>>                 However, the dirichlet condition gives the correct
>>>>                 ans. Is there anything else that could be wrong
>>>>                 even if the Mat and Vec are the same?
>>>>             Did you set the null space for the matrix when you have
>>>>             Neumann conditions?
>>>             Yes, for the matrix, I set as:
>>>             call
>>>             MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL_OBJECT,nullspace,ierr)
>>>                 call MatSetNullSpace(jac,nullspace,ierr)
>>>                 call MatNullSpaceDestroy(nullspace,ierr)
>>>             for the Vec,
>>>             call
>>>             *!call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)*
>>>             MatNullSpaceRemove was comment out because there's error
>>>             during linking
>>>>                Matt
>>>>                 Thanks!
>>>>                 Fortran:
>>>>                 Matrix Object: 1 MPI processes
>>>>                   type: seqaij
>>>>                 row 0: (0, 2)  (1, -1)  (3, -1)
>>>>                 row 1: (0, -1)  (1, 3)  (2, -1)  (4, -1)
>>>>                 row 2: (1, -1)  (2, 2)  (5, -1)
>>>>                 row 3: (0, -1)  (3, 3)  (4, -1)  (6, -1)
>>>>                 row 4: (1, -1)  (3, -1)  (4, 4)  (5, -1)  (7, -1)
>>>>                 row 5: (2, -1)  (4, -1)  (5, 3)  (8, -1)
>>>>                 row 6: (3, -1)  (6, 2)  (7, -1)
>>>>                 row 7: (4, -1)  (6, -1)  (7, 3)  (8, -1)
>>>>                 row 8: (5, -1)  (7, -1)  (8, 2)
>>>>                 Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>>                   type: mpi
>>>>                 Process [0]
>>>>                 0.25
>>>>                 0.0205213
>>>>                 1.135e-005
>>>>                 0.0205213
>>>>                 0.00168449
>>>>                 9.31663e-007
>>>>                 1.135e-005
>>>>                 9.31663e-007
>>>>                 5.15289e-010
>>>>                 Vector Object:Vec_0000000084000000_1 1 MPI processes
>>>>                   type: mpi
>>>>                 Process [0]
>>>>                 0.14924
>>>>                 0.0242397
>>>>                 -0.0260347
>>>>                 0.0242397
>>>>                 -0.0256192
>>>>                 -0.0400102
>>>>                 -0.0260347
>>>>                 -0.0400102
>>>>                 -0.0400102
>>>>                 Press any key to continue . . .
>>>>                 C:
>>>>                   type: seqaij
>>>>                 Vector Object:Vec_0x1d3b000_0 1 MPI processes
>>>>                   type: mpi
>>>>                 Process [0]
>>>>                 0.25
>>>>                 0.0205212
>>>>                 1.135e-05
>>>>                 0.0205212
>>>>                 0.00168449
>>>>                 9.31663e-07
>>>>                 1.135e-05
>>>>                 9.31663e-07
>>>>                 5.15288e-10
>>>>                 Vector Object:Vec_0x1d3b000_1 1 MPI processes
>>>>                   type: mpi
>>>>                 Process [0]
>>>>                 0.139311
>>>>                 0.0305751
>>>>                 -0.0220633
>>>>                 0.0305751
>>>>                 -0.0135158
>>>>                 -0.042185
>>>>                 -0.0220633
>>>>                 -0.042185
>>>>                 -0.058449
>>>>                 Yours sincerely,
>>>>                 TAY wee-beng
>>>>                 On 1/5/2012 11:54 PM, Matthew Knepley wrote:
>>>>>                 On Tue, May 1, 2012 at 5:48 PM, TAY wee-beng
>>>>>                     Hi,
>>>>>                     Do you mean my method is wrong?
>>>>>                     I am following the template of ex22f,
>>>>>                     where the variables are declared as :
>>>>>                     PetscScalar  v(5)
>>>>>                     MatStencil   row(4),col(4,5)
>>>>>                     Hence,
>>>>>                     for the neumann BC
>>>>>                     num = 1
>>>>>                                    if (j/=0) then
>>>>>                                        v(num) = -rho*HxdHy
>>>>>                                        col(MatStencil_i,num) = i
>>>>>                                        col(MatStencil_j,num) = j-1
>>>>>                                        num = num + 1
>>>>>                                    end if
>>>>>                                    if (i/=0) then
>>>>>                                        v(num) = -rho*HydHx
>>>>>                                        col(MatStencil_i,num) = i-1
>>>>>                                        num = num + 1
>>>>>                                    end if
>>>>>                                    if (i/=mx-1) then
>>>>>                                        v(num) = -rho*HydHx
>>>>>                                        col(MatStencil_i,num) = i+1
>>>>>                                        num = num + 1
>>>>>                                    end if
>>>>>                                    if (j/=my-1) then
>>>>>                                        v(num) = -rho*HxdHy
>>>>>                                        col(MatStencil_j,num) = j+1
>>>>>                                        num = num + 1
>>>>>                                    end if
>>>>>                                    v(num) =
>>>>>                     ((num-1)/2.0)*rho*(HxdHy + HydHx)
>>>>>                                    print *, v
>>>>>                                    !num = num + 1
>>>>>                                    call
>>>>>                     MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
>>>>>                     I do not get any more out of range error.
>>>>>                     However,my ans is still different from that of
>>>>>                     ex29 in C.
>>>>>                 This is very simple. You have an error in your
>>>>>                 code. Checking it is very simple: run the code and
>>>>>                 break in MatSetValues(). Make sure ex29 makes
>>>>>                 calls with exactly the same indices as your ex29f.
>>>>>                     Matt
>>>>>                     Yours sincerely,
>>>>>                     TAY wee-beng
>>>>>                 What most experimenters take for granted before
>>>>>                 they begin their experiments is infinitely more
>>>>>                 interesting than any results to which their
>>>>>                 experiments lead.
>>>>>                 -- Norbert Wiener
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120504/16879c44/attachment-0001.htm>
