[petsc-users] Fwd: Re: Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Fri May 4 14:01:51 CDT 2012
On 4/5/2012 5:17 PM, Matthew Knepley wrote:
> On Fri, May 4, 2012 at 11:05 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 4/5/2012 3:05 PM, Matthew Knepley wrote:
>>     On Fri, May 4, 2012 at 8:59 AM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         Is there anything else I can try to get it working right?
>>     The MatGetNullSpaceRemove() is missing.
>     Where should I add MatGetNullSpaceRemove and what are its syntax?
>     I googled but there's no results.
> Fixed in p;etsc-dev:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatNullSpaceRemove.html
I just compiled the updated petsc-dev but I got the same error msg when
I use:
call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
error LNK2019: unresolved external symbol MATNULLSPACEREMOVE referenced
in function COMPUTERHS
1>c:\obj_tmp\ex29f\Debug\ex29f.exe : fatal error LNK1120: 1 unresolved
externals
>      Matt
>     Thanks.
>>        Matt
>>         Thanks!
>>         On 2/5/2012 10:11 PM, Matthew Knepley wrote:
>>>         On Wed, May 2, 2012 at 1:55 PM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             I did a MatView and VecView on both C and Fortran, right
>>>             after Mat and Vec assembly. I have attached the printout
>>>             below. They are exactly the same, but yet the result is
>>>             different in Neumann condition. However, the dirichlet
>>>             condition gives the correct ans. Is there anything else
>>>             that could be wrong even if the Mat and Vec are the same?
>>>         Did you set the null space for the matrix when you have
>>>         Neumann conditions?
>>         Yes, for the matrix, I set as:
>>         call
>>         MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL_OBJECT,nullspace,ierr)
>>             call MatSetNullSpace(jac,nullspace,ierr)
>>             call MatNullSpaceDestroy(nullspace,ierr)
>>         for the Vec,
>>         call
>>         *!call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)*
>>         MatNullSpaceRemove was comment out because there's error
>>         during linking
>>>            Matt
>>>             Thanks!
>>>             Fortran:
>>>             Matrix Object: 1 MPI processes
>>>               type: seqaij
>>>             row 0: (0, 2)  (1, -1)  (3, -1)
>>>             row 1: (0, -1)  (1, 3)  (2, -1)  (4, -1)
>>>             row 2: (1, -1)  (2, 2)  (5, -1)
>>>             row 3: (0, -1)  (3, 3)  (4, -1)  (6, -1)
>>>             row 4: (1, -1)  (3, -1)  (4, 4)  (5, -1)  (7, -1)
>>>             row 5: (2, -1)  (4, -1)  (5, 3)  (8, -1)
>>>             row 6: (3, -1)  (6, 2)  (7, -1)
>>>             row 7: (4, -1)  (6, -1)  (7, 3)  (8, -1)
>>>             row 8: (5, -1)  (7, -1)  (8, 2)
>>>             Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>               type: mpi
>>>             Process [0]
>>>             0.25
>>>             0.0205213
>>>             1.135e-005
>>>             0.0205213
>>>             0.00168449
>>>             9.31663e-007
>>>             1.135e-005
>>>             9.31663e-007
>>>             5.15289e-010
>>>             Vector Object:Vec_0000000084000000_1 1 MPI processes
>>>               type: mpi
>>>             Process [0]
>>>             0.14924
>>>             0.0242397
>>>             -0.0260347
>>>             0.0242397
>>>             -0.0256192
>>>             -0.0400102
>>>             -0.0260347
>>>             -0.0400102
>>>             -0.0400102
>>>             Press any key to continue . . .
>>>             C:
>>>               type: seqaij
>>>             Vector Object:Vec_0x1d3b000_0 1 MPI processes
>>>               type: mpi
>>>             Process [0]
>>>             0.25
>>>             0.0205212
>>>             1.135e-05
>>>             0.0205212
>>>             0.00168449
>>>             9.31663e-07
>>>             1.135e-05
>>>             9.31663e-07
>>>             5.15288e-10
>>>             Vector Object:Vec_0x1d3b000_1 1 MPI processes
>>>               type: mpi
>>>             Process [0]
>>>             0.139311
>>>             0.0305751
>>>             -0.0220633
>>>             0.0305751
>>>             -0.0135158
>>>             -0.042185
>>>             -0.0220633
>>>             -0.042185
>>>             -0.058449
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>             On 1/5/2012 11:54 PM, Matthew Knepley wrote:
>>>>             On Tue, May 1, 2012 at 5:48 PM, TAY wee-beng
>>>>                 Hi,
>>>>                 Do you mean my method is wrong?
>>>>                 I am following the template of ex22f,
>>>>                 where the variables are declared as :
>>>>                 PetscScalar  v(5)
>>>>                 MatStencil   row(4),col(4,5)
>>>>                 Hence,
>>>>                 for the neumann BC
>>>>                 num = 1
>>>>                                if (j/=0) then
>>>>                                    v(num) = -rho*HxdHy
>>>>                                    col(MatStencil_i,num) = i
>>>>                                    col(MatStencil_j,num) = j-1
>>>>                                    num = num + 1
>>>>                                end if
>>>>                                if (i/=0) then
>>>>                                    v(num) = -rho*HydHx
>>>>                                    col(MatStencil_i,num) = i-1
>>>>                                    num = num + 1
>>>>                                end if
>>>>                                if (i/=mx-1) then
>>>>                                    v(num) = -rho*HydHx
>>>>                                    col(MatStencil_i,num) = i+1
>>>>                                    num = num + 1
>>>>                                end if
>>>>                                if (j/=my-1) then
>>>>                                    v(num) = -rho*HxdHy
>>>>                                    col(MatStencil_j,num) = j+1
>>>>                                    num = num + 1
>>>>                                end if
>>>>                                v(num) = ((num-1)/2.0)*rho*(HxdHy +
>>>>                 HydHx)
>>>>                                print *, v
>>>>                                !num = num + 1
>>>>                                call
>>>>                 MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
>>>>                 I do not get any more out of range error.
>>>>                 However,my ans is still different from that of ex29
>>>>                 in C.
>>>>             This is very simple. You have an error in your code.
>>>>             Checking it is very simple: run the code and
>>>>             break in MatSetValues(). Make sure ex29 makes calls
>>>>             with exactly the same indices as your ex29f.
>>>>                 Matt
>>>>                 Yours sincerely,
>>>>                 TAY wee-beng
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120504/26d06297/attachment.htm>
