[petsc-users] Fwd: Re: Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Fri May 4 10:05:58 CDT 2012
On 4/5/2012 3:05 PM, Matthew Knepley wrote:
> On Fri, May 4, 2012 at 8:59 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     Is there anything else I can try to get it working right?
> The MatGetNullSpaceRemove() is missing.
Where should I add MatGetNullSpaceRemove and what are its syntax? I
googled but there's no results.
Thanks.
>    Matt
>     Thanks!
>     On 2/5/2012 10:11 PM, Matthew Knepley wrote:
>>     On Wed, May 2, 2012 at 1:55 PM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         I did a MatView and VecView on both C and Fortran, right
>>         after Mat and Vec assembly. I have attached the printout
>>         below. They are exactly the same, but yet the result is
>>         different in Neumann condition. However, the dirichlet
>>         condition gives the correct ans. Is there anything else that
>>         could be wrong even if the Mat and Vec are the same?
>>     Did you set the null space for the matrix when you have Neumann
>>     conditions?
>     Yes, for the matrix, I set as:
>     call
>     MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL_OBJECT,nullspace,ierr)
>         call MatSetNullSpace(jac,nullspace,ierr)
>         call MatNullSpaceDestroy(nullspace,ierr)
>     for the Vec,
>     call
>     *!call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)*
>     MatNullSpaceRemove was comment out because there's error during
>     linking
>>        Matt
>>         Thanks!
>>         Fortran:
>>         Matrix Object: 1 MPI processes
>>           type: seqaij
>>         row 0: (0, 2)  (1, -1)  (3, -1)
>>         row 1: (0, -1)  (1, 3)  (2, -1)  (4, -1)
>>         row 2: (1, -1)  (2, 2)  (5, -1)
>>         row 3: (0, -1)  (3, 3)  (4, -1)  (6, -1)
>>         row 4: (1, -1)  (3, -1)  (4, 4)  (5, -1)  (7, -1)
>>         row 5: (2, -1)  (4, -1)  (5, 3)  (8, -1)
>>         row 6: (3, -1)  (6, 2)  (7, -1)
>>         row 7: (4, -1)  (6, -1)  (7, 3)  (8, -1)
>>         row 8: (5, -1)  (7, -1)  (8, 2)
>>         Vector Object:Vec_0000000084000000_0 1 MPI processes
>>           type: mpi
>>         Process [0]
>>         0.25
>>         0.0205213
>>         1.135e-005
>>         0.0205213
>>         0.00168449
>>         9.31663e-007
>>         1.135e-005
>>         9.31663e-007
>>         5.15289e-010
>>         Vector Object:Vec_0000000084000000_1 1 MPI processes
>>           type: mpi
>>         Process [0]
>>         0.14924
>>         0.0242397
>>         -0.0260347
>>         0.0242397
>>         -0.0256192
>>         -0.0400102
>>         -0.0260347
>>         -0.0400102
>>         -0.0400102
>>         Press any key to continue . . .
>>         C:
>>           type: seqaij
>>         Vector Object:Vec_0x1d3b000_0 1 MPI processes
>>           type: mpi
>>         Process [0]
>>         0.25
>>         0.0205212
>>         1.135e-05
>>         0.0205212
>>         0.00168449
>>         9.31663e-07
>>         1.135e-05
>>         9.31663e-07
>>         5.15288e-10
>>         Vector Object:Vec_0x1d3b000_1 1 MPI processes
>>           type: mpi
>>         Process [0]
>>         0.139311
>>         0.0305751
>>         -0.0220633
>>         0.0305751
>>         -0.0135158
>>         -0.042185
>>         -0.0220633
>>         -0.042185
>>         -0.058449
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 1/5/2012 11:54 PM, Matthew Knepley wrote:
>>>         On Tue, May 1, 2012 at 5:48 PM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             Do you mean my method is wrong?
>>>             I am following the template of ex22f,
>>>             where the variables are declared as :
>>>             PetscScalar  v(5)
>>>             MatStencil   row(4),col(4,5)
>>>             Hence,
>>>             for the neumann BC
>>>             num = 1
>>>                            if (j/=0) then
>>>                                v(num) = -rho*HxdHy
>>>                                col(MatStencil_i,num) = i
>>>                                col(MatStencil_j,num) = j-1
>>>                                num = num + 1
>>>                            end if
>>>                            if (i/=0) then
>>>                                v(num) = -rho*HydHx
>>>                                col(MatStencil_i,num) = i-1
>>>                                num = num + 1
>>>                            end if
>>>                            if (i/=mx-1) then
>>>                                v(num) = -rho*HydHx
>>>                                col(MatStencil_i,num) = i+1
>>>                                num = num + 1
>>>                            end if
>>>                            if (j/=my-1) then
>>>                                v(num) = -rho*HxdHy
>>>                                col(MatStencil_j,num) = j+1
>>>                                num = num + 1
>>>                            end if
>>>                            v(num) = ((num-1)/2.0)*rho*(HxdHy + HydHx)
>>>                            print *, v
>>>                            !num = num + 1
>>>                            call
>>>             MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
>>>             I do not get any more out of range error. However,my ans
>>>             is still different from that of ex29 in C.
>>>         This is very simple. You have an error in your code.
>>>         Checking it is very simple: run the code and
>>>         break in MatSetValues(). Make sure ex29 makes calls with
>>>         exactly the same indices as your ex29f.
>>>             Matt
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120504/ed0eb2a7/attachment.htm>
