[petsc-users] (no subject)
Hong Zhang hzhang at mcs.anl.gov
Thu May 3 10:06:40 CDT 2012
Pham Van:
Added to petsc-dev
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c3403225fb48
Let us know if there is any problem with it.
Thanks for your contribution!
Hong
Dear Developers,
> I found the out of core parameter in the external solver MUMPS is
> important when using with cygwin because the default directory /tmp/ simply
> does not exist in windows. So you may consider putting:
>   ierr = PetscOptionsString("-ooc_tmpdir", "The Out of Core directory",
> "None", lu->id.ooc_tmpdir, lu->id.ooc_tmpdir, 256, PETSC_NULL);
>  in the function:
> PetscErrorCode PetscSetMUMPSOptions(Mat F, Mat A)
> in the file: mumps.c
> So that the users can enter the temporary directory of their choice.
> Kind regards,
> Pham Van Ha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120503/013d134a/attachment.htm>
