[petsc-users] fill matrix using dynamic load balancing code
Wed May 2 19:56:30 CDT 2012
On Wed, May 2, 2012 at 7:55 PM, Gao Bin <bin.gao at uit.no> wrote:
>  Hi, all
> (1) I am using PETSc to perform, for instance matrix-matrix
> multiplication. But the numerical values of the matrix are calculated from
> my integral code. I guess, for matrix-matrix multiplication, it might be
> better to distribute the rows of matrix uniformly on processors, right?
It depends on the matrix.
> (2) If yes, I have a problem in my integral code. Since I need dynamic
> load balancing to calculate the matrix elements and then put them into
> correct places by using MatSetValues. But I have two questions regarding
> MatSetValues:
> (2.1) If one processor calculated a lot of elements belong to another
> remote processor, will this become a problem for the performance? Should I
> make all processors calculate as many local elements as possible?
It will raise the communication cost. This, of course, must be weighed
against the penalty for load imbalance in your case.
> (2.2) From the manual, I see MatSetValues only caches the values, but
> MatAssemblyBegin() and MatAssemblyEnd() assembles the matrix. Therefore, is
> there any memory limit for MatSetValues, or in other words, will it cost a
> lot of memory before assembling?
Yes, there is a limit to the stash space:
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatStashSetInitialSize.html
    Matt
> Thank you in advance.
> Cheers
> Gao
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120502/5c729061/attachment.htm>
