[petsc-users] Multigrid
Tue May 1 18:04:36 CDT 2012
On Tue, May 1, 2012 at 7:00 PM, Karthik Duraisamy <dkarthik at stanford.edu>wrote:
> So as I understand it, GMRES is used as a preconditioner and as a solver
> when I use PCMG with defaults. If this is the case, I should be able to
> recreate this set up without the PCMG. Any pointers as to how this can be
> done?
You can use
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/PC/PCKSP.html to
stick your initial
solver inside another GMRES, however this is unlikely to be faster than
running more iterates.
   Matt
> Also, yes indeed, my mesh is completely unstructured, so I will have to
> use ml or boomeramg.
> The problems that I am attempting involve RANS of compressible turbulent
> combustion (finite volume, steady). The high condition numbers are because
> of the extreme grid stretching and stiff source terms (in the turbulence
> and combustion model). I have been trying a reduced problem in these 2D
> test cases, in which the condition number is only 1e7.
> Thanks,
> Karthik.
> From: "Mark F. Adams" <mark.adams at columbia.edu>
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Sent: Tuesday, May 1, 2012 3:50:31 PM
> Subject: Re: [petsc-users] Multigrid
> Also, note that PCMG can not create coarse grid spaces for an (MPI)AIJ
> matrix. If you use regular grids (DA?) then PETSc can construct geometric
> multigrid coarse grid spaces, although I don't know if PCMG will construct
> these for you (I don't think it will and I can see from your output that
> PCMG just used one grid). 'ml', hypre' and 'gamg' (a native AMG solver)
> will do real AMG solvers for you. All three can work on a similar class of
> problems.
> Also, you mention that you have a condition number of 1.e20. That is
> astronomical for such a small problem. How did you compute that number? Do
> you know where the ill-conditioning comes from? Is this an elliptic
> operator?
> Mark
> On May 1, 2012, at 6:31 PM, Matthew Knepley wrote:
> On Tue, May 1, 2012 at 6:27 PM, Karthik Duraisamy < dkarthik at stanford.edu> wrote:
> The following was output for the very first iteration whereas what I had
> attached earlier was output every iteration. I am still a bit perplexed
> because PCMG drops the residual like a rock (after the first few iterations
> whereas with no PCMG, it is very slow)
> Because the smoother IS the solver you were using before. Just like I said
> last time, what you are doing is
> wrapping up the same solver you used before, sticking it in another GMRES
> loop, and only looking at the
> outer loop. This has nothing to do with MG.
> Matt
> KSP Object: 8 MPI processes
> type: gmres
> GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=1, initial guess is zero
> using preconditioner applied to right hand side for initial guess
> tolerances: relative=0.01, absolute=1e-08, divergence=1e+10
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: 8 MPI processes
> type: mg
> MG: type is MULTIPLICATIVE, levels=1 cycles=v
> Cycles per PCApply=1
> Not using Galerkin computed coarse grid matrices
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_levels_0_) 8 MPI processes
> type not yet set
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> PC Object: (mg_levels_0_) 8 MPI processes
> type not yet set
> linear system matrix = precond matrix:
> Matrix Object: 8 MPI processes
> type: mpiaij
> rows=75000, cols=75000
> total: nonzeros=4427800, allocated nonzeros=4427800
> total number of mallocs used during MatSetValues calls =0
> using I-node (on process 0) routines: found 3476 nodes, limit used is 5
> From: "Matthew Knepley" < knepley at gmail.com >
> To: "PETSc users list" < petsc-users at mcs.anl.gov >
> Sent: Tuesday, May 1, 2012 3:22:56 PM
> On Tue, May 1, 2012 at 6:18 PM, Karthik Duraisamy < dkarthik at stanford.edu> wrote:
> Hello,
> Sorry (and thanks for the reply). I've attached the no multigrid case. I
> didn't include it because (at least to the untrained eye, everything looks
> the same).
> Did you send all the output from the MG case? There must be a PC around
> it. By default its GMRES, so there would be
> an extra GMRES loop compared to the case without MG.
> Matt
> Regards,
> Karthik
> type: gmres
> tolerances: relative=1e-05, absolute=1e-50, divergence=1e+10
> using nonzero initial guess
> using PRECONDITIONED norm type for convergence test
> type: bjacobi
> block Jacobi: number of blocks = 8
> Local solve is same for all blocks, in the following KSP and PC objects:
> KSP Object: (sub_) 1 MPI processes
> type: preonly
> maximum iterations=10000, initial guess is zero
> using NONE norm type for convergence test
> PC Object: (sub_) 1 MPI processes
> type: ilu
> ILU: out-of-place factorization
> 0 levels of fill
> tolerance for zero pivot 1e-12
> using diagonal shift to prevent zero pivot
> matrix ordering: natural
> factor fill ratio given 1, needed 1
> Factored matrix follows:
> Matrix Object: 1 MPI processes
> type: seqaij
> rows=9015, cols=9015
> package used to perform factorization: petsc
> total: nonzeros=517777, allocated nonzeros=517777
> using I-node routines: found 3476 nodes, limit used is 5
> type: seqaij
> type: mpiaij
> Sent: Tuesday, May 1, 2012 3:15:14 PM
> On Tue, May 1, 2012 at 6:12 PM, Karthik Duraisamy < dkarthik at stanford.edu> wrote:
> Hello Barry,
> Thank you for your super quick response. I have attached the output of
> ksp_view and it is practically the same as that when I don't use PCMG. The
> part I don't understand is how PCMG able to function at the zero grid level
> and still produce a much better convergence than when using the default PC.
> Is there any additional smoothing or interpolation going on?
> You only included one output, so I have no way of knowing what you used
> before. However, this is running GMRES/ILU.
> Also, for Algebraic Multigrid, would you recommend BoomerAMG or ML ?
> They are different algorithms. Its not possible to say generally that one
> is better. Try them both.
> Matt
> Best regards,
> Karthik.
> type: mg
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> type: bjacobi
> KSP Object: (mg_levels_0_sub_) 1 MPI processes
> type: preonly
> PC Object: (mg_levels_0_sub_) 1 MPI processes
> type: ilu
> 0 levels of fill
> type: seqaij
> type: seqaij
> type: mpiaij
> type: mpiaij
> From: "Barry Smith" < bsmith at mcs.anl.gov >
> Sent: Tuesday, May 1, 2012 1:39:26 PM
> On May 1, 2012, at 3:37 PM, Karthik Duraisamy wrote:
> > Hello,
> > I have been using PETSc for a couple of years with good success, but
> lately as my linear problems have become stiffer (condition numbers of the
> order of 1.e20), I am looking to use better preconditioners. I tried using
> PCMG with all the default options (i.e., I just specified my preconditioner
> as PCMG and did not add any options to it) and I am immediately seeing
> better convergence.
> > What I am not sure of is why? I would like to know more about the
> default parameters (the manual is not very explicit) and more importantly,
> want to know why it is working even when I haven't specified any grid
> levels and coarse grid operators. Any
> > help in this regard will be appreciated.
> First run with -ksp_view to see what solver it is actually using.
> Barry
> > Also, ultimately I want to use algebraic multigrid so is PCML a better
> option than BoomerAMG? I tried BoomerAMG with mixed results.
> > Thanks,
> > Karthik
> > Karthik Duraisamy
> > Assistant Professor (Consulting)
> > Durand Building Rm 357
> > Dept of Aeronautics and Astronautics
> > Stanford University
> > Stanford CA 94305
> > Phone: 650-721-2835
> > Web: www.stanford.edu/~dkarthik
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120501/9cb8c2b7/attachment.htm>
