[petsc-users] Interations increase with parallelism
tibo at berkeley.edu tibo at berkeley.edu
Tue May 1 17:29:16 CDT 2012
Thank you for your answer,
I will then investigate more the topic of scalable preconditioners, as
well as try different preconditioners.
> On Tue, May 1, 2012 at 6:20 PM, <tibo at berkeley.edu> wrote:
>> Dear petsc users,
>> I am solving large systems of non linear PDEs. To do so, the most
>> expensive operation is to solve linear systems Ax=b, where A is block
>> tridiagonal. To do so, I am using petsc.
>> A is created using MatCreateMPIAIJ and x and b using VecCreateMPI, and I
>> do not modify default parameters of the KSP context for now (ie the
>> Krylov
>> method is GMRES and the preconditioner method is ILU(0) if I use 1
>> processor - sequential matrix - and Block Jacobi with ILU(0) for each
>> sub-block if I use more than 1 processor).
>> For any number n of processors used, I do get the correct result.
>> However,
>> it seems that the more processors I have, the more iterations are done
>> on
>> each linear solve (n = 1 gives about 1-2 iterations per solve, n = 2
>> gives
>> 8-12 iterations per solve, n = 4 gives 15-20 iterations per solve).
>> While I can understand the difference between n = 1 and n = 2, since the
>> preconditioning method changes from ILU(0) to Block Jacobi, I don't
>> understand why this is the case from n = 2 to 4 for example, since it
>> seems to me that the method used to solve Ax=b will be the same
>> (although
>> the partitioning is different) and so the operations will be the same,
>> even though there will be more communication.
>> My first question is then: Is this normal behavior or am I probably
>> wrong
>> somewhere ?
> Its not the same from 2-4. You have 4 smaller blocks in BJACOBI and less
> coupling.
> Also, since the increase in the number of iterations more than offsets the
>> decrease in time spent solving the system when n increase, my program
>> runs
>> slower with an increasing number of processors, which is the opposite of
>> what is desired...Would you have suggestions as what I could change to
>> correct this ?
> Scalable preconditioning is a research topic. However, the next thing to
> try is AMG.
>> I would be happy to provide more details about the
>> problem/datastructures
>> used if needed,
> The best thing to try usually is a literature search for people using
> for your kind of physics.
>     Matt
>> thank you for your help,
>> Tibo
> experiments lead.
> -- Norbert Wiener
