[petsc-users] Problem with fortran version of ex29 in ksp
Tue May 1 16:54:56 CDT 2012
On Tue, May 1, 2012 at 5:48 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> Do you mean my method is wrong?
> I am following the template of ex22f,
> where the variables are declared as :
> PetscScalar  v(5)
> MatStencil   row(4),col(4,5)
> Hence,
> for the neumann BC
> num = 1
>                if (j/=0) then
>                    v(num) = -rho*HxdHy
>                    col(MatStencil_i,num) = i
>                    col(MatStencil_j,num) = j-1
>                    num = num + 1
>                end if
>                if (i/=0) then
>                    v(num) = -rho*HydHx
>                    col(MatStencil_i,num) = i-1
>                    num = num + 1
>                end if
>                if (i/=mx-1) then
>                    v(num) = -rho*HydHx
>                    col(MatStencil_i,num) = i+1
>                    num = num + 1
>                end if
>                if (j/=my-1) then
>                    v(num) = -rho*HxdHy
>                    col(MatStencil_j,num) = j+1
>                    num = num + 1
>                end if
>                v(num) = ((num-1)/2.0)*rho*(HxdHy + HydHx)
>                print *, v
>                !num = num + 1
>                call MatSetValuesStencil(jac,i1,**
> row,num,col,v,INSERT_VALUES,**ierr)
> I do not get any more out of range error. However,my ans is still
> different from that of ex29 in C.
This is very simple. You have an error in your code. Checking it is very
simple: run the code and
break in MatSetValues(). Make sure ex29 makes calls with exactly the same
indices as your ex29f.
    Matt
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120501/4167ac1b/attachment.htm>
