[petsc-users] ex52_integrateElement.cu
    Matthew Knepley
    knepley at gmail.com
    Wed Mar 28 18:42:39 CDT 2012
On Wed, Mar 28, 2012 at 6:25 PM, David Fuentes <fuentesdt at gmail.com> wrote:
> Yes. This would work.
> I had trouble compiling in single precision using the some of the external
> package options I was using for double.
Okay,  getting on it now.
   Matt
> On Wed, Mar 28, 2012 at 4:57 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Mar 28, 2012 at 4:12 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>> works!
>> Excellent. Now, my thinking was that GPUs are most useful doing single
>> work, but
>> I can see the utility of double accuracy for a residual.
>> My inclination is to define another type, say GPUReal, and use it for all
>> kernels.
>> Would that do what you want?
>>    Matt
>>> SCRGP2$ make ex52
>>> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
>>> -I/opt/apps/PETSC/petsc-dev/include
>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/include
>>> -I/opt/apps/cuda/4.0/cuda/include -I/usr/include -I/usr/include/mpich2
>>> -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>> nvcc -G -O0 -g -arch=sm_10  -c --compiler-options="-O0 -g   -fPIC
>>>  -D__INSDIR__=src/snes/examples/tutorials/"  ex52_integrateElement.cu
>>>  ex52_gpu_inline.h(7): warning: variable "points_0" was declared but
>>> never referenced
>>> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but
>>> never referenced
>>> never referenced
>>> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
>>> never referenced
>>> never referenced
>>> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was
>>> declared but never referenced
>>> never referenced
>>> never referenced
>>> never referenced
>>> never referenced
>>> never referenced
>>> /usr/bin/mpicxx -O0 -g   -o ex52 ex52.o ex52_integrateElement.o
>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>  -lpetsc
>>> -ltriangle -lX11 -lpthread -lmetis -Wl,-rpath,/opt/apps/cuda/4.0/cuda/lib64
>>> -L/opt/apps/cuda/4.0/cuda/lib64 -lcufft -lcublas -lcudart -lcusparse
>>> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5
>>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
>>> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
>>> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
>>> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
>>> GPU layout grid(1,2,1) block(3,1,1) with 1 batches
>>>  N_t: 3, N_cb: 1
>>> Residual:
>>> Vector Object: 1 MPI processes
>>>   type: seq
>>> -0.25
>>> -0.5
>>> 0.25
>>> -0.5
>>> -1
>>> 0.5
>>> 0.25
>>> 0.5
>>> 0.75
>>> Residual:
>>>   type: seq
>>> -0.25
>>> -0.5
>>> 0.25
>>> -0.5
>>> -1
>>> 0.5
>>> 0.25
>>> 0.5
>>> 0.75
>>> On Wed, Mar 28, 2012 at 1:37 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>> sure. will do.
>>>> On Wed, Mar 28, 2012 at 1:23 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Wed, Mar 28, 2012 at 1:14 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>> thanks! its running, but I seem to be getting different answer for
>>>>>> cpu/gpu ?
>>>>>> i had some floating point problems on this Tesla M2070 gpu before,
>>>>>> but adding the '-arch=sm_20' option seemed to fix it last time.
>>>>>> is the assembly in single precision ? my 'const PetscReal
>>>>>> jacobianInverse' being passed in are doubles
>>>>> Yep, that is the problem. I have not tested anything in double. I have
>>>>> not decided exactly how to handle it. Can you
>>>>> make another ARCH --with-precision=single and make sure it works, and
>>>>> then we can fix the double issue?
>>>>>   Thanks,
>>>>>      Matt
>>>>>>  N_t: 3, N_cb: 1
>>>>>> Residual:
>>>>>>   type: seq
>>>>>> 0
>>>>>> 755712
>>>>>> 0
>>>>>> -58720
>>>>>> -2953.13
>>>>>> 0.375
>>>>>> 1.50323e+07
>>>>>> 0.875
>>>>>> 0
>>>>>> SCRGP2$
>>>>>> Residual:
>>>>>>   type: seq
>>>>>> -0.25
>>>>>> -0.5
>>>>>> 0.25
>>>>>> -0.5
>>>>>> -1
>>>>>> 0.5
>>>>>> 0.25
>>>>>> 0.5
>>>>>> 0.75
>>>>>> On Wed, Mar 28, 2012 at 11:55 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <fuentesdt at gmail.com
>>>>>>> > wrote:
>>>>>>>> The example seems to be running on cpu with '-batch' but
>>>>>>>> i'm getting errors in line 323 with the '-gpu' option
>>>>>>>> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
>>>>>>>> src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>> should this possibly be PetscScalar ?
>>>>>>> No.
>>>>>>>> -  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>> sizeof(float));CHKERRQ(ierr);
>>>>>>>> +  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>> sizeof(PetscScalar));CHKERRQ(ierr);
>>>>>>>> SCRGP2$ python
>>>>>>>> $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 1 1 1
>>>>>>>> laplacian ex52.h
>>>>>>>> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
>>>>>>>> '2', '1', '1', '1', 'laplacian', 'ex52.h']
>>>>>>>> 2 1 1 1 laplacian
>>>>>>>> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]}, {(-1.0,
>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0: []}}
>>>>>>>> Perm: [0, 1, 2]
>>>>>>>> Creating /home/fuentes/snestutorial/ex52.h
>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu.h
>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>> Perm: [0, 1, 2]
>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
>>>>>>>> SCRGP2$ make ex52
>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>>>>>>>> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
>>>>>>>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>>>>>>>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>>>>> nvcc -O0 -g -arch=sm_20  -c --compiler-options="-O0 -g   -fPIC
>>>>>>>> -I/usr/include/mpich2    -D__INSDIR__=src/snes/examples/tutorials/"
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>> never referenced
>>>>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>>>>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib  -lpetsc
>>>>>>>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
>>>>>>>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>>>>>>>> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
>>>>>>>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
>>>>>>>> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>>>>> /bin/rm -f ex52.o ex52_integrateElement.o
>>>>>>>> Residual:
>>>>>>>>   type: seq
>>>>>>>> -0.25
>>>>>>>> -0.5
>>>>>>>> 0.25
>>>>>>>> -0.5
>>>>>>>> -1
>>>>>>>> 0.5
>>>>>>>> 0.25
>>>>>>>> 0.5
>>>>>>>> 0.75
>>>>>>>> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
>>>>>>>> src/snes/examples/tutorials/ex52.c
>>>>>>>> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
>>>>>>>> src/snes/utils/damgsnes.c
>>>>>>>> [0]PETSC ERROR: main() line 1021 in
>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
>>>>>>> This is failing on cudaMalloc(), which means your card is not
>>>>>>> available for running. Are you trying to run on your laptop?
>>>>>>> If so, applications like Preview can lock up the GPU. I know of no
>>>>>>> way to test this in CUDA while running. I just close
>>>>>>> apps until it runs.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <bourdin at lsu.edu>wrote:
>>>>>>>>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>>>>>>>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <
>>>>>>>>>>> Hi,
>>>>>>>>>>> I had a question about the status of example 52.
>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>>> Can this example be used with a DM object created from an
>>>>>>>>>>> unstructured exodusII mesh, DMMeshCreateExodus, And the FEM assembly done
>>>>>>>>>>> on GPU ?
>>>>>>>>>> 1) I have pushed many more tests for it now. They can be run
>>>>>>>>>> using the Python build system
>>>>>>>>>>   ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>>>>>>>>>   in fact, you can build any set of files this way.
>>>>>>>>>> 2) The Exodus creation has to be converted to DMComplex from
>>>>>>>>>> DMMesh. That should not take me very long. Blaise maintains that
>>>>>>>>>>      so maybe there will be help :) You will just replace
>>>>>>>>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>>>>>>>>>      it, I will bump it up the list.
>>>>>>>>>> DMMeshCreateExodusNG is much more flexible
>>>>>>>>>> than DMMeshCreateExodus in that it can read meshes with multiple element
>>>>>>>>>> types and should have a much lower memory footprint. The code should be
>>>>>>>>>> fairly easy to read. you can email me directly if you have specific
>>>>>>>>>> questions. I had looked at creating a DMComplex and it did not look too
>>>>>>>>>> difficult, as long as interpolation is not needed. I have plans to
>>>>>>>>>> write DMComplexCreateExodus, but haven't had time too so far. Updating the
>>>>>>>>>> Vec viewers and readers may be a bit more involved. In perfect world, one
>>>>>>>>>> would write an EXODUS viewer following the lines of the VTK and HDF5 ones.
>>>>>>>>> David and Blaise,  I have converted this function, now
>>>>>>>>> DMComplexCreateExodus(). Its not tested, but I think
>>>>>>>>> Blaise has some stuff we can use to test it.
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Blaise
>>>>>>>>>> Let me know if you can run the tests.
>>>>>>>>>>   Thanks
>>>>>>>>>>      Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> David
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> Department of Mathematics and Center for Computation & Technology
>>>>>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>>>>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
>>>>>>>>>> http://www.math.lsu.edu/~bourdin
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120328/fa386315/attachment-0001.htm>
