[petsc-users] Repacking/scattering of multi-dimensional arrays
Dag Sverre Seljebotn d.s.seljebotn at astro.uio.no
Mon Mar 26 13:53:03 CDT 2012
Hi list,
I'm wondering whether there's any code in PETSc that I can either use
directly or lift out and adapt for my purposes (which are described in
footnote [1]).
What I need to do is a number of different 2D array ("multi-vector",
"dense matrix") repacking operations, in order to make the data
available to different operations (spherical harmonic transforms, dense
linear algebra, sparse linear algebra, etc.).
There's a number of repacking operations I'm in need of:
  - From each process having a given contiguous set of rows of a 2D
array, to an element-cyclic distribution where one distributes over both
rows and columns (the distribution of Elemental [2])
  - Arbitrary redistribution of rows between processes (but each row is
kept in a process), potentially with overlaps.
  - More structured redistribution of rows between processes where
indices can be easily computed on the fly (but still a pattern quite
specific to my application).
While I found PETSc routines for arbitrary redistribution of 1D arrays,
I couldn't find anything for 2D arrays. Any pointers into documentation
or papers etc. explaining these aspects of PETSc is very welcome.
What I'd *really* like (and what I'll do if I end up doing it myself) is
something more generic: A small, focused library which, given two
descriptors of how an N-dimensional array is distributed, does the
redistribution from one to the other. What I'd imagine is that you for
each axis of the array pick an axis distribution ("chunked",
"(block-)cyclic", "provided by indices", "non-distributed"), and an MPI
datatype. (The array would have to be distributed on a process grid of
the same dimension as the array).
Then, given two N-dimensions descriptors which mixes structured and
unstructured information, the library can make and execute a
redistribution plan.
Perhaps too ambitious, which is why I'm hoping that somebody can point
me to at least something existing. I can imagine doing most of it from
scratch, but reusing PETSc for the unstructured axis-distribution type.
Comments of any kind welcome.
Dag
[1] What I'm doing is solving a linear system by CG where the LHS matrix
can only be written as a (rather large) symbolic equation, containing
lots of spherical harmonic transforms, Fourier transform, both dense and
sparse linear algebra, and so on.
[2] http://code.google.com/p/elemental/
