[petsc-users] GAMG issue
Matthew Knepley
knepley at gmail.com
Tue Mar 20 09:24:50 CDT 2012
On Tue, Mar 20, 2012 at 9:19 AM, John Mousel <john.mousel at gmail.com> wrote:
> Mark,
> Sorry for the late reply. I've been on travel and hadn't had a chance to
> pick this back up. I've tried running with the suggested options:
> -ksp_type bcgsl -pc_type gamg -pc_gamg_coarse_eq_limit 10
> -pc_gamg_agg_nsmooths 1 -pc_gamg_sym_graph -mg_coarse_ksp_type richardson
> -mg_coarse_pc_type sor -mg_coarse_pc_sor_its 8 -ksp_diagonal_scale
> -ksp_diagonal_scale_fix -ksp_monitor_true_residual -ksp_view
> -pc_gamg_verbose 1
> With these options, the convergence starts to hang (see attached
> GAMG_kspview.txt). The hanging happens for both -mg_coarse_ksp_type
> richardson and preonly. It was my understanding from previous emails that
> using preonly made it so that only the preconditioner was run, which in
> this case would be 8 sweeps of SOR. If I get rid of the
> -pc_gamg_agg_nsmooths 1 (see GAMG_kspview_nosmooth.txt), the problem
> converges, but again the convergence is slow. Without this option, both
> Richardson and preonly converge in 172 iterations.
> Matt, I've checked and the problem does converge in the true residual
> using GAMG, ML, HYPRE, and ILU preconditioned BiCG. I explicitly ensure
> that a solution exists by projecting the rhs vector out of the nullity of
> the transpose of operator.
Would you mind sending the matrix in binary format, -ksp_view_binary, to
petsc-maint at mcs.anl.gov? Then we can figure out what is happening here.
Matt
> John
> On Fri, Mar 16, 2012 at 2:04 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> John, did this get resolved?
>> Mark
>> On Mar 15, 2012, at 4:24 PM, John Mousel wrote:
>> Mark,
>> Running without the options you mentioned before leads to slightly worse
>> performance (175 iterations).
>> I have not been able to get run coarse grid solve to work with LU while
>> running ML. It keeps experiencing a zero pivot, and all the combinations of
>> shifting i've tried haven't lead me anywhere, hence the SOR on the course
>> grid. Also, the ML manual suggests limiting the number of levels to 3 or 4
>> and performing a few sweeps of an iterative method as opposed to a direct
>> solve.
>> John
>> On Thu, Mar 15, 2012 at 12:04 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> You also want: -pc_gamg_agg_nsmooths 1
>>> You are running plain aggregation. If it is Poisson then smoothing is
>>> good.
>>> Is this problem singular? Can you try running ML with these parameters
>>> and see if its performance degrades? The ML implementation uses the PETSC
>>> infrastructure and uses a very similar algorithm to GAMG-SA. We should be
>>> able to get these two to match pretty well.
>>> Mark
>>> On Mar 15, 2012, at 12:21 PM, John Mousel wrote:
>>> Mark,
>>> I ran with those options removed (see the run options listed below).
>>> Things actually got slightly worse. Now it's up to 142 iterations. I have
>>> attached the ksp_view output.
>>> -ksp_type bcgsl -pc_type gamg -pc_gamg_sym_graph -ksp_diagonal_scale
>>> -ksp_diagonal_scale_fix -mg_levels_ksp_type richardson -mg_levels_pc_type
>>> sor -pc_gamg_verbose 1
>>> John
>>> On Thu, Mar 15, 2012 at 10:55 AM, Mark F. Adams <mark.adams at columbia.edu
>>> > wrote:
>>>> John, can you run again with: -pc_gamg_verbose 1
>>>> And I would not use: -pc_mg_levels 4 -mg_coarse_ksp_type preonly
>>>> 1) I think -mg_coarse_ksp_type preonly and -mg_coarse_pc_sor_its 8 do
>>>> not do what you think. I think this is the same as 1 iteration. I think
>>>> you want 'richardson' not 'preonly'.
>>>> 2) Why are you using sor as the coarse solver? If your problem is
>>>> singular then you want to use as many levels as possible to get the coarse
>>>> grid to be tiny. I'm pretty sure HYPRE ignores the coarse solver
>>>> parameters. But ML uses them and it is converging well.
>>>> 3) I would not specify the number of levels. GAMG, and I think the
>>>> rest, have internal logic for stopping a the right level. If the coarse
>>>> level is large and you use just 8 iterations of sor then convergence will
>>>> suffer.
>>>> Mark
>>>> On Mar 15, 2012, at 11:13 AM, John Mousel wrote:
>>>> Mark,
>>>> The changes pulled through this morning. I've run it with the options
>>>> -ksp_diagonal_scale_fix -pc_mg_levels 4 -mg_levels_ksp_type richardson
>>>> -mg_levels_pc_type sor -mg_coarse_ksp_type preonly -mg_coarse_pc_type sor
>>>> and it converges in the true residual, but it's not converging as fast
>>>> as anticpated. The matrix arises from a non-symmetric discretization of the
>>>> Poisson equation. The solve takes GAMG 114 iterations, whereas ML takes 24
>>>> iterations, BoomerAMG takes 22 iterations, and -ksp_type bcgsl -pc_type
>>>> bjacobi -sub_pc_type ilu -sub_pc_factor_levels 4 takes around 170. I've
>>>> attached the -ksp_view results for ML,GAMG, and HYPRE. I've attempted to
>>>> make all the options the same on all levels for ML and GAMG.
>>>> Any thoughts?
>>>> John
>>>> On Wed, Mar 14, 2012 at 6:04 PM, Mark F. Adams <mark.adams at columbia.edu
>>>> > wrote:
>>>>> Humm, I see it with hg view (appended).
>>>>> Satish, my main repo looks hosed. I see this:
>>>>> ~/Codes/petsc-dev>hg update
>>>>> abort: crosses branches (merge branches or use --clean to discard
>>>>> changes)
>>>>> ~/Codes/petsc-dev>hg merge
>>>>> abort: branch 'default' has 3 heads - please merge with an explicit rev
>>>>> (run 'hg heads .' to see heads)
>>>>> ~/Codes/petsc-dev>hg heads
>>>>> changeset: 22496:8e2a98268179
>>>>> tag: tip
>>>>> user: Barry Smith <bsmith at mcs.anl.gov>
>>>>> date: Wed Mar 14 16:42:25 2012 -0500
>>>>> files: src/vec/is/interface/f90-custom/zindexf90.c
>>>>> src/vec/vec/interface/f90-custom/zvectorf90.c
>>>>> description:
>>>>> undoing manually changes I put in because Satish had a better fix
>>>>> changeset: 22492:bda4df63072d
>>>>> user: Mark F. Adams <mark.adams at columbia.edu>
>>>>> date: Wed Mar 14 17:39:52 2012 -0400
>>>>> files: src/ksp/pc/impls/gamg/tools.c
>>>>> description:
>>>>> fix for unsymmetric matrices.
>>>>> changeset: 22469:b063baf366e4
>>>>> date: Wed Mar 14 14:22:28 2012 -0400
>>>>> description:
>>>>> added fix for preallocation for unsymetric matrices.
>>>>> Mark
>>>>> my 'hg view' on my merge repo:
>>>>> Revision: 22492
>>>>> Branch: default
>>>>> Author: Mark F. Adams <mark.adams at columbia.edu> 2012-03-14 17:39:52
>>>>> Committer: Mark F. Adams <mark.adams at columbia.edu> 2012-03-14
>>>>> 17:39:52
>>>>> Tags: tip
>>>>> Parent: 22491:451bbbd291c2 (Small fixes to the BT linesearch)
>>>>> ------------------------ src/ksp/pc/impls/gamg/tools.c
>>>>> @@ -103,7 +103,7 @@
>>>>> PetscErrorCode ierr;
>>>>> PetscInt Istart,Iend,Ii,jj,ncols,nnz0,nnz1, NN, MM, nloc;
>>>>> PetscMPIInt mype, npe;
>>>>> - Mat Gmat = *a_Gmat, tGmat;
>>>>> + Mat Gmat = *a_Gmat, tGmat, matTrans;
>>>>> MPI_Comm wcomm = ((PetscObject)Gmat)->comm;
>>>>> const PetscScalar *vals;
>>>>> const PetscInt *idx;
>>>>> @@ -127,6 +127,10 @@
>>>>> ierr = MatDiagonalScale( Gmat, diag, diag ); CHKERRQ(ierr);
>>>>> ierr = VecDestroy( &diag ); CHKERRQ(ierr);
>>>>> + if( symm ) {
>>>>> + ierr = MatTranspose( Gmat, MAT_INITIAL_MATRIX, &matTrans );
>>>>> CHKERRQ(ierr);
>>>>> /* filter - dup zeros out matrix */
>>>>> ierr = PetscMalloc( nloc*sizeof(PetscInt), &d_nnz ); CHKERRQ(ierr);
>>>>> ierr = PetscMalloc( nloc*sizeof(PetscInt), &o_nnz ); CHKERRQ(ierr);
>>>>> @@ -135,6 +139,12 @@
>>>>> d_nnz[jj] = ncols;
>>>>> o_nnz[jj] = ncols;
>>>>> ierr = MatRestoreRow(Gmat,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>>>>> CHKERRQ(ierr);
>>>>> + if( symm ) {
>>>>> + ierr = MatGetRow(matTrans,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>>>>> CHKERRQ(ierr);
>>>>> + d_nnz[jj] += ncols;
>>>>> + o_nnz[jj] += ncols;
>>>>> + ierr = MatRestoreRow(matTrans,Ii,&ncols,PETSC_NULL,PETSC_NULL);
>>>>> CHKERRQ(ierr);
>>>>> if( d_nnz[jj] > nloc ) d_nnz[jj] = nloc;
>>>>> if( o_nnz[jj] > (MM-nloc) ) o_nnz[jj] = MM - nloc;
>>>>> @@ -142,6 +152,9 @@
>>>>> CHKERRQ(ierr);
>>>>> ierr = PetscFree( d_nnz ); CHKERRQ(ierr);
>>>>> ierr = PetscFree( o_nnz ); CHKERRQ(ierr);
>>>>> + if( symm ) {
>>>>> + ierr = MatDestroy( &matTrans ); CHKERRQ(ierr);
>>>>> On Mar 14, 2012, at 5:53 PM, John Mousel wrote:
>>>>> Mark,
>>>>> No change. Can you give me the location that you patched so I can
>>>>> check to make sure it pulled?
>>>>> I don't see it on the petsc-dev change log.
>>>>> John
>>>>> On Wed, Mar 14, 2012 at 4:40 PM, Mark F. Adams <
>>>>> mark.adams at columbia.edu> wrote:
>>>>>> John, I've committed these changes, give a try.
>>>>>> Mark
>>>>>> On Mar 14, 2012, at 3:46 PM, Satish Balay wrote:
>>>>>> > This is the usual merge [with uncommited changes] issue.
>>>>>> > You could use 'hg shelf' extension to shelve your local changes and
>>>>>> > then do a merge [as Sean would suggest] - or do the merge in a
>>>>>> > separate/clean clone [I normally do this..]
>>>>>> > i.e
>>>>>> > cd ~/Codes
>>>>>> > hg clone petsc-dev petsc-dev-merge
>>>>>> > cd petsc-dev-merge
>>>>>> > hg pull ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev #just
>>>>>> to be sure, look for latest chagnes before merge..
>>>>>> > hg merge
>>>>>> > hg commit
>>>>>> > hg push ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev
>>>>>> > [now update your petsc-dev to latest]
>>>>>> > cd ~/Codes/petsc-dev
>>>>>> > hg pull
>>>>>> > hg update
>>>>>> > Satish
>>>>>> > On Wed, 14 Mar 2012, Mark F. Adams wrote:
>>>>>> >> Great, that seems to work.
>>>>>> >> I did a 'hg commit tools.c'
>>>>>> >> and I want to push this file only. I guess its the only thing in
>>>>>> the change set so 'hg push' should be fine. But I see this:
>>>>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg update
>>>>>> changes)
>>>>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg merge
>>>>>> >> abort: outstanding uncommitted changes (use 'hg status' to list
>>>>>> changes)
>>>>>> >> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg status
>>>>>> >> M include/petscmat.h
>>>>>> >> M include/private/matimpl.h
>>>>>> >> M src/ksp/pc/impls/gamg/agg.c
>>>>>> >> M src/ksp/pc/impls/gamg/gamg.c
>>>>>> >> M src/ksp/pc/impls/gamg/gamg.h
>>>>>> >> M src/ksp/pc/impls/gamg/geo.c
>>>>>> >> M src/mat/coarsen/coarsen.c
>>>>>> >> M src/mat/coarsen/impls/hem/hem.c
>>>>>> >> M src/mat/coarsen/impls/mis/mis.c
>>>>>> >> Am I ready to do a push?
>>>>>> >> Thanks,
>>>>>> >> Mark
>>>>>> >> On Mar 14, 2012, at 2:44 PM, Satish Balay wrote:
>>>>>> >>> If commit is the last hg operation that you've done - then 'hg
>>>>>> rollback' would undo this commit.
>>>>>> >>> Satish
>>>>>> >>>> Damn, I'm not preallocating the graph perfectly for unsymmetric
>>>>>> matrices and PETSc now dies on this.
>>>>>> >>>> I have a fix but I committed it with other changes that I do not
>>>>>> want to commit. The changes are all in one file so I should be able to
>>>>>> just commit this file.
>>>>>> >>>> Anyone know how to delete a commit?
>>>>>> >>>> I've tried:
>>>>>> >>>> ~/Codes/petsc-dev/src/ksp/pc/impls/gamg>hg strip
>>>>>> 22487:26ffb9eef17f
>>>>>> >>>> hg: unknown command 'strip'
>>>>>> >>>> 'strip' is provided by the following extension:
>>>>>> >>>> mq manage a stack of patches
>>>>>> >>>> use "hg help extensions" for information on enabling extensions
>>>>>> >>>> But have not figured out how to load extensions.
>>>>>> >>>> Mark
>>>>>> >>>> On Mar 14, 2012, at 12:54 PM, John Mousel wrote:
>>>>>> >>>>> Mark,
>>>>>> >>>>> I have a non-symmetric matrix. I am running with the following
>>>>>> options.
>>>>>> >>>>> -pc_type gamg -pc_gamg_sym_graph -ksp_monitor_true_residual
>>>>>> >>>>> and with the inclusion of -pc_gamg_sym_graph, I get a new
>>>>>> malloc error:
>>>>>> >>>>> 0]PETSC ERROR: --------------------- Error Message
>>>>>> >>>>> [0]PETSC ERROR: Argument out of range!
>>>>>> >>>>> [0]PETSC ERROR: New nonzero at (5150,9319) caused a malloc!
>>>>>> >>>>> [0]PETSC ERROR:
>>>>>> >>>>> [0]PETSC ERROR: Petsc Development HG revision:
>>>>>> 587b25035091aaa309c87c90ac64c13408ecf34e HG Date: Wed Mar 14 09:22:54 2012
>>>>>> -0500
>>>>>> >>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>> >>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>> shooting.
>>>>>> >>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>> >>>>> [0]PETSC ERROR:
>>>>>> >>>>> [0]PETSC ERROR: ../JohnRepo/VFOLD_exe on a linux-deb named
>>>>>> wv.iihr.uiowa.edu by jmousel Wed Mar 14 11:51:35 2012
>>>>>> >>>>> [0]PETSC ERROR: Libraries linked from
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/linux-debug/lib
>>>>>> >>>>> [0]PETSC ERROR: Configure run at Wed Mar 14 09:46:39 2012
>>>>>> >>>>> [0]PETSC ERROR: Configure options --download-blacs=1
>>>>>> --download-hypre=1 --download-metis=1 --download-ml=1 --download-mpich=1
>>>>>> --download-parmetis=1 --download-scalapack=1
>>>>>> --with-blas-lapack-dir=/opt/intel11/mkl/lib/em64t --with-cc=gcc
>>>>>> --with-cmake=/usr/local/bin/cmake --with-cxx=g++ --with-fc=ifort
>>>>>> PETSC_ARCH=linux-debug
>>>>>> >>>>> [0]PETSC ERROR:
>>>>>> >>>>> [0]PETSC ERROR: MatSetValues_MPIAIJ() line 506 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>>>>>> >>>>> [0]PETSC ERROR: MatSetValues() line 1141 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/interface/matrix.c
>>>>>> >>>>> [0]PETSC ERROR: scaleFilterGraph() line 155 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/tools.c
>>>>>> >>>>> [0]PETSC ERROR: PCGAMGgraph_AGG() line 865 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/agg.c
>>>>>> >>>>> [0]PETSC ERROR: PCSetUp_GAMG() line 516 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/gamg.c
>>>>>> >>>>> [0]PETSC ERROR: PCSetUp() line 832 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/interface/precon.c
>>>>>> >>>>> [0]PETSC ERROR: KSPSetUp() line 261 in
>>>>>> /home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>>>>> >>>>> [0]PETSC ERROR: KSPSolve() line 385 in
>>>>>> >>>>> John
>>>>>> >>>>> On Wed, Mar 14, 2012 at 11:27 AM, Mark F. Adams <
>>>>>> >>>>> On Mar 14, 2012, at 11:56 AM, John Mousel wrote:
>>>>>> >>>>>> Mark,
>>>>>> >>>>>> The matrix is asymmetric. Does this require the setting of an
>>>>>> option?
>>>>>> >>>>> Yes: -pc_gamg_sym_graph
>>>>>> >>>>> Mark
>>>>>> >>>>>> I pulled petsc-dev this morning, so I should have (at least
>>>>>> close to) the latest code.
>>>>>> >>>>>> John
>>>>>> >>>>>> On Wed, Mar 14, 2012 at 10:54 AM, Mark F. Adams <
>>>>>> >>>>>> On Mar 14, 2012, at 11:08 AM, John Mousel wrote:
>>>>>> >>>>>>> I'm getting the following error when using GAMG.
>>>>>> >>>>>>> petsc-dev/src/ksp/pc/impls/gamg/agg.c:508: smoothAggs:
>>>>>> Assertion `sgid==-1' failed.
>>>>>> >>>>>> Is it possible that your matrix is structurally asymmetric?
>>>>>> >>>>>> This code is evolving fast and so you will need to move to the
>>>>>> dev version if you are not already using it. (I think I fixed a bug that
>>>>>> hit this assert).
>>>>>> >>>>>>> When I try to alter the type of aggregation at the command
>>>>>> line using -pc_gamg_type pa, I'm getting
>>>>>> >>>>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error
>>>>>> Message ------------------------------------
>>>>>> >>>>>>> [1]PETSC ERROR: Unknown type. Check for miss-spelling or
>>>>>> missing external package needed for type:
>>>>>> >>>>>>> see
>>>>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
>>>>>> >>>>>>> [1]PETSC ERROR: Unknown GAMG type pa given!
>>>>>> >>>>>>> Has there been a change in the aggregation options? I just
>>>>>> pulled petsc-dev this morning.
>>>>>> >>>>>> Yes, this option is gone now. You can use -pc_gamg_type agg
>>>>>> for now.
>>>>>> >>>>>> Mark
>>>>>> >>>>>>> John
>>>> <GAMG_kspview.txt><ML_kspview.txt><HYPRE_kspview.txt>
>>> <GAMG_kspview.txt>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120320/f53ad71e/attachment-0001.htm>
