[petsc-users] Solving a Linear System with two different Solvers (one each thread)..?
Jed Brown
jedbrown at mcs.anl.gov
Mon Mar 19 16:22:08 CDT 2012
On Mon, Mar 19, 2012 at 16:16, Pedro Torres <torres.pedrozpk at gmail.com>wrote:
> Ok, so the only way to implement that is coding by hand each algorithm for
> each thread, rigth?.
> Anyway, at least can I use petsc object like Vec/Mat on each thread?.
No, the threading model in PETSc does not allow you to call it
simultaneously from different threads. You can set locks around every call,
but this whole approach is almost certainly a waste of your time. Just
solve those systems one after the other. It will be much simpler code and
faster in many cases.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120319/a7d65549/attachment.htm>
