[petsc-users] Petsc Performance Help
Satish Balay
balay at mcs.anl.gov
Fri Mar 16 15:53:41 CDT 2012
On Fri, 16 Mar 2012, Jed Brown wrote:
> On Fri, Mar 16, 2012 at 14:52, <Nan.Jia at dartmouth.edu> wrote:
> > Dear PETSc Group,
> > I am tuning the efficiency of my PETSc code for a while, but get very
> > little progress. So can anyone help me to analysis the log? Any suggestions
> > will be appreciated.
> > My problem is time dependent. At every time step, two about 6000 by 6000
> > sparse matrices need to be solved, which come from a Poisson equation. I
> > use both sequential and parallel AIJ format to store matrices, but the
> > performances are both not very good.
> 1. You need to heed the huge warning
> # WARNING!!! #
> # This code was compiled with a debugging option, #
> # To get timing results run config/configure.py #
> # using --with-debugging=no, the performance will #
> # be generally two or three times faster. #
> 2. You only spend 18 of 880 seconds in the solver. What do you want?
> 3. The problem is too small to get significant parallel speedup.
> http://www.mcs.anl.gov/petsc/documentation/faq.html#slowerparallel
4. MatSetValues() is not logged by default - you should run with -info
and make sure there are no mallocs during assembly. Also check
http://www.mcs.anl.gov/petsc/documentation/faq.html#efficient-assembly
satish
