[petsc-users] [petsc-maint #107932] run a simple example ex19 in src/snes/examples/tutorials
Jed Brown
jedbrown at mcs.anl.gov
Fri Mar 16 10:00:29 CDT 2012
2012/3/16 Xiangze Zeng <zengshixiangze at 163.com>
> After I changed the Mat type for using GPU, can I still
> use MatMPIAIJSetPreallocation to set preallocation?
Yes, the code looks okay to me.
> I have add Petsc events in the code.The attachments are the outputs of
> log_summary (I'll configure --with-debugging=no later).
> The fileinterface.c is my code in which set preallocation and insert
> matrices values.
You are running in serial so you should also call
MatSeqAIJSetPreallocation(). The MPI allocation information is skipped
because it's not an MPI matrix. It is safe to call all the preallocation
routines, whichever matches will be used. Alternatively, you could call
this function which will do all the variants for you:
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatXAIJSetPreallocation.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/b186adc9/attachment.htm>
